#5351 |
Re: What did you do to your truck today!
It'll be a bit before I get everything together to install it, but I will post the improvements, if any.
'67 C20 LBW |
#5352 |
Junior Member
We took the stepside bed up to my son's house since we are now ready to start getting it ready for painting.
Washed it down good, removed the tailgate and the chains. Tomorrow we will weld in the roll pan, then see what else we have time to do.
'67 Chevy C-20 short stepper - build complete, 454/SM-465. '75 C-30 Single Cab DRW-350 small block/NP-435. '77 GMC-6500 Dump Truck, 427 Tall Deck. '92 GMC K-3500 Duallie, 454/4L80E. |
#5353 |
Big Block
#5354 |
![]() Join Date: Mar 2011
Well, I finally got the under side of the cab finished today.
We did alot of welding to the cab floors while it was still on the chassis, then I put it on the rotissary to finish up the bottom. Got all the pcs welded in on the bottom, seam sealed every joint and seam underneath, two coats of por 15. Now its time to lower it back down and seal/coat the floors top side. Not too far from getting the cab in epoxy primer like the front clip and bed. Very soon it will be time to play mechanic instead of bodyman. On to the frame!!
1997 shortie stepside 1968 short stepside 1966 mustang 1966 chevelle ss Dont always go the cheapest route--You can save yourself into the poorhouse! My Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=489030 |
#5355 |
![]() Join Date: Jul 2007
put some under dash lights and a glove box light in.
Chuck 68 ![]() ![]() http://67-72chevytrucks.com/vboard/s...d.php?t=374892 My trailer redo http://67-72chevytrucks.com/vboard/s...69#post5893869 Chuy my 59 bug http://67-72chevytrucks.com/vboard/s...d.php?t=653798 Putnam 87 GMC Shop truck http://67-72chevytrucks.com/vboard/s...d.php?t=707687 |
#5356 |
After I purchased my 72 GMC back in August and got it home, I discovered I had no horn. Everything else was there so I started thinking about what to buy.
I stumbled across an ebay auction last week for horns off of an 87 Cadillac. Not 1, not 2, not 3 but 4 horns. So, this afternoon I got around to mounting them. ![]() My little stepper sounds like a West bound train at a railroad crossing. Sweet!
1969 RS/SS Z10 Camaro Pace coupe 1972 GMC Short Step buildhttp://67-72chevytrucks.com/vboard/s...=1#post6356218 1979 Mazda RX7 1979 Pontiac Trans Am WS6 & 1979 Pontiac Trans Am 10th Anniversary 1999 Honda Valkyrie 2006 Corvette Z06 2010 BMW 650i |
#5357 |
Well this past week, water pump went out so I swapped a new one in and then headed home and the damn belt busted, so now thats getting replaced tomorrow. Also found out I have 3.73 posi trac rear end. Ready to get it back running.
#5358 | |
#5359 | |
#5360 |
RAT1968 '68 Cab/'71 Parts
Thanks, dliving69
In the Vintage Air kit. The seats are out of a 2004 Blazer.
M17 Coarsegold, CA RAT's shiny now. But always a rat. |
#5361 |
Asked the machine shop wtf is taking so long to put my motor together…
#5362 |
Collector of Projects
Test fit the NP205 to the 4L80e and had my friend Russ (the robot) tig weld the adapter...
#5363 |
Nice adaptor! I was going to go the same route, 4l80e and 205, but had my transmission guy talk me out of it (that and the cost of the electronics needed). Now trying to sell the 80.
#5364 |
![]() Join Date: Jul 2009
Got my frontend aligned after swapping all the brakes, drop suspension and steering. The guy did a very thorough job considering the change in stance and all
#5365 |
![]() Join Date: Oct 2012
finished dads bed floor, put the hood and tail gate on, just about done, will put the exhaust on tomorrow then dad has to do some finishing touches, turned out to be a cool old truck
#5366 |
PROJECT 7DEUCE
![]() Join Date: Dec 2002
Welded some bump stops on yesterday.........
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
#5367 |
Booya! Got the first layers of epoxy on! Special thanks goes out to JRE (Justin). Now on to the details and slicksand.
#5368 |
Junior Member
We cleaned and straightened my son's garage, since we are done with building my '67 swb stepper. Then we pushed in his next project.
#5369 |
![]() Join Date: Aug 2012
Shyguy, looks like you and your son did an amazing job on that stepper. Can't wait to see his c10 project! Love the stripes on cowl. Did you guys have a build thread anywhere? I'm curious what the rest of it looks like
#5370 |
Built me a box and installed to test it out
DON'T BUILD IT IF YOUR NOT GONA DRIVE IT!! ![]() |
#5371 |
cleaned it and took it out to beat on the tires
#5372 |
changed the fuel tank float in our dogs truck
#5373 |
Tip: Make sure that is fully out before you put it back in the tank. Otherwise, you run the risk of having a hot dog.
#5374 |
pretty cool, pitched it in some water then it went in the trash can
#5375 |
The rear end was leaking so I pulled the cover off, cleaned it, re-painted it and re-installed. Also painted the master cyclinder since I am finally getting to drive it and it was starting to show a little rust. Lastly I fixed the shifter. I had hooked up 1st and reverse backwards. It was interesting the first time I started to pul off. Now it is time to go to the in-laws to eat. Happy Thanksgiving to all. I'll ask everyone to take a minute today and really think about what you are thankful for. Tell the people you love how much you are thankful for them!!
