Closed Thread
Old 05-27-2012, 09:18 PM   #5451
dantimdad
dantimdad's Avatar
Re: What did you do to your truck today?
my son and I fabbed up the upright channel pieces for the core support and welded them on. I dropped off the lower channelwiht my friend for him to fab. I just have to replace a fan in a laptop for him.
Steven
“Life is and will ever remain an equation incapable of solution, but it contains certain known factors.” - Nikola Tesla
Matt. 6:27 "Who of you by worrying can add a single hour to his life?”
http://www.67-72chevytrucks.com/vboa...=507266&page=2
dantimdad is offline
Old 05-27-2012, 09:41 PM   #5452
Rich 5150 69
Rich 5150 69's Avatar
Originally Posted by 66-PMD-GMC View Post
What 350 heads would someone use for this?
Any 350 heads, any combustion chamber size and shape or would someone need to look for something specific?
What would the compression issues be if any?
They could use any year, even the 64 cc heads as long as they are matched valve size and compression, the 400 motors were all 8.5 compression at the piston with 25 cc dished pistons so they have a lot to pick from. The 400 heads had a chamber volume of 75 or 76, this was done for the truck motors for better low end torque.
`64 C10 vortec 350/350/373 posi
`69 RS/SS 350/350/308
`37 Ford 406/350/324 traclock
`68 Dart 370/904/323 suregrip
Rich 5150 69 is offline
Old 05-28-2012, 12:55 AM   #5453
StepAside
StepAside's Avatar
Its not...just looks as if it is from that angle...It really isnt even close to the headers...Thanks for the heads up though.
StepAside is offline
Old 05-28-2012, 01:03 AM   #5454
StepAside
StepAside's Avatar
Ummm....
If that braided hose is laying on top of that header tube like it looks in the photo...
You are going to have some .. major problemas senior..
Just saying..
Here is a better picture of what is going on...
Old 05-28-2012, 01:10 AM   #5455
suzq044
Resident Photoshop Nerd
suzq044's Avatar
.. walked by it and went "grrrrrrrr" ... lol
PJ - 1966 C10 Panel --
Max˛ - 1964 Jeep Wagoneer Panel-delivery -- Waiting his turn
suzq044 is offline
Old 05-28-2012, 08:44 AM   #5456
63burban4x4
63burban4x4's Avatar
First chance I've had in a while to do more than dream about it done!
Installed PS box & front axle from '78 K10. Disc brakes, and a bit higher gears (3:90 to 3:73) still gotta install the rear to match. Glad I did the work with no sheetmetal on the front and no engine!
Pulled all the driveshafts to replace the u-joints, since I had a rare opportunity on a lift. Realized the 4-speed shifter wont move.....if someting's wrong with the trans, it's history.....really want OD anyway.
Next up, PB booster and all new lines.
Found a very cool grille in the junkyard Saturday...C60 cab headed for the crusher pretty quick....I've been planning to use something different....seems like you see a lot of the 65-66 aluminum (or that style, painted or chromed) , no matter what the truck is...I like that, and I have the dinged-up original alum, but wanted different. Have a grille I think is from a larger 63, has 2 round horizontal bars through the center opening, pretty cool, but I like this one better! (Sorry no pics, cant seem to locate my camera, and my old school $25 Wal-Mart phone is useless as a camera!) Truck is stock height 4x4, Suburban, painted bumpers and grille, will have a front winch also. Still a lot to do. If I can get this truck done right, my 04 Silverado 2500HD "warning light queen" will be GONE!!
63burban4x4 is offline
Old 05-28-2012, 11:58 AM   #5457
62 Barnfind
62 Barnfind's Avatar
Painted my instrument frame and numbers.
John Z
1962 Chevy C10 Stepside
62 Barnfind
My build tread: http://67-72chevytrucks.com/vboard/s...d.php?t=507513
62 Barnfind is offline
Old 05-28-2012, 12:36 PM   #5458
CRGRS 66
CRGRS 66's Avatar
[QUOTE=62 Barnfind;5404026]Painted my instrument frame and numbers.
that looks very nice, well done!
Craigerrr
My build thread, CRGRS 66 Winter Build: http://67-72chevytrucks.com/vboard/s...09#post5638709
CRGRS 66 is offline
Old 05-28-2012, 01:06 PM   #5459
62 Barnfind
Thanks! I have been working and painting on my interior all weekend. I am trying to get something accomplished. I used enamel and a small brush.
John Z
62 Barnfind
Old 05-28-2012, 01:25 PM   #5460
shrunken66stroker
shrunken66stroker's Avatar
Where did you get the frame from, 62??
shrunken66stroker is offline
Old 05-28-2012, 01:27 PM   #5461
63burban4x4
managed to get a pic of the new grille I found. Pretty sure the donor was a 65, def was a C60 even had the T3 headlights
Old 05-28-2012, 01:29 PM   #5462
62 Barnfind
It is the original frame that I sanded primed and painted. Here is the before picture.
John Z
62 Barnfind
Old 05-28-2012, 08:41 PM   #5463
Sneaux
Sneaux's Avatar
Pulled the motor.
Sneaux is offline
Old 05-30-2012, 08:56 AM   #5464
Jolby
Jolby's Avatar
I sat rebuilt motor in frame utilizing new junkyard mounting system, didn't want to use the mounts that came in the truck. Used the old tranny so that I would only have to deal with one new task at a time. After the motor mounts are done, I will move the crossmember for the freshly built 2004R. I wanted overdrive since my Nova only gets about 8 mpg. Warn me of any issues I may run into.
Jolby is offline
Old 05-30-2012, 10:16 AM   #5465
66-PMD-GMC
The 60-66 GMC/Pontiac guy....
66-PMD-GMC's Avatar
TOO COOL!
A rocket powered truck!
I for one love it and it is a direct bolt in....
Did you use the Olds mounts out of a late 70's truck?
Building Genuine Pontiac Firepowered cars and trucks for several decades.
Why Pontiac?? That's just me daring to be different.
Projects..
63 C10 Short Wheel Base fleetside (The Pro-Street) currently under reconstruction.
440CID 2X4 Pontiac
66-PMD-GMC is offline
Old 05-30-2012, 11:31 AM   #5466
Jolby
Jolby's Avatar
TOO COOL!
I used the bracket from a suburban and frame pads from a 75 Olds 442. The engine is a 403 bored 30 over due to broken rings when I got. Had to drill holes for everthing, could not find any 350 diesel mounts around here. They crush the old stuff quick.
PS; my trucks name is Frankie due to the Frankenstein effort to complete, I noticed your LWB sig.
Jolby is offline
Old 05-30-2012, 01:40 PM   #5467
66-PMD-GMC
66-PMD-GMC's Avatar
Too bad, I have several sets.
Projects..
440CID 2X4 Pontiac
Old 05-31-2012, 09:14 AM   #5468
Raked 64
Raked 64's Avatar
Installed the 406 small block and 350 auto trans for the second time. (had a smoking issue the first go around)
So I dressed up a few things while I had it out
New Edelbrock Powdercoated intake and a aluminum oil pan.
Raked 64 is offline
Old 05-31-2012, 03:56 PM   #5469
CdM
CdM's Avatar
drilled dash for tweets.. installed motor mounts finished bondo on ds rocker.. cleaning and sealing the seams today.. sand sand and more sanding on cab for primer tomorrow.. its about time!!!
Build Thread 66 custom cab lwb http://67-72chevytrucks.com/vboard/s...d.php?t=465726
66 fleet lwb- In process
64 k10 10inch lift 38.5's- In process
92k1500 400hp on 38.5-parts truck now 8(
CdM is offline
Old 05-31-2012, 04:57 PM   #5470
Slow Build
Slow Build's Avatar
Nothing physically done but last week I made mine my DD. Sold my 2003 Audi A6 Avant just in time for my wife to get laid off. Now we can't get a loan to buy anything for me to drive so I'll be sweating in my truck this summer. As Curly from the Three Stooges would say "I was a victim of soycumstance".
Current Ride: 1964 C-10 Short Fleetside
Daily Driver: 2005 GMC crew cab short fleetside /2001 Chevy Tahoe
Past GM Trucks:
1959 GMC short stepside
1968 GMC short stepside-4x4
1973 Chevy short stepside
1989 Chevy short fleetside-reg cab
1993 Chevy short fleetside-Xcab
2002 Chevy short fleetside-Xcab
Save the dinosaurs, use synthetic oil.
Slow Build is offline
Old 05-31-2012, 09:17 PM   #5471
stony66
I removed all my brakes to replace,had to order shoes,cut one coil off the front springs.I also removed rear cover to replace leaking axle seals,figured I might as well do bearings while I'm there.I hope to have it all back together this weekend.Still need to order drop springs for rear wanted to do front,then measure.Trying to get it roadworthy for now.
stony66 is offline
Old 05-31-2012, 09:41 PM   #5472
a37lesalle
a37lesalle's Avatar
Got some more interior work done. Should get seats intalled next weekend. Picked up some gauges...dont trust idiot lights. Also installed slide hitch to pull a 75 Terry trailer. Just need to get battery and fire it up
a37lesalle is offline
Old 05-31-2012, 10:39 PM   #5473
Ta2Don
Ta2Don's Avatar
Got my Ebay find carb in, ordered piston, rings, and HEI Dist.
Ta2Don is offline
Old 05-31-2012, 11:35 PM   #5474
1enick72
1enick72's Avatar
Gas pedal had been sticking and found that the throttle shaft was loose. Replaced throttle body and adjusted TPS, much better.
1enick72 is offline
Old 06-01-2012, 09:48 AM   #5475
Chad215
Welded one of the several holes I keep finding in my firewall...
'64 GMC in progress
http://67-72chevytrucks.com/vboard/s...d.php?t=484861
Chad215 is offline
Closed Thread
