Re: What did you do to your truck today!
I ordered white gauges for my 67 and rebuilt my brake Cylinders!! Getting ready to teach my son how to bleed brakes, after our four brake rebuild project.
![]() Join Date: May 2012
first let me say welcome to the board, and i think its great that you and your son is working together on your truck. who knows he just might start loving these old trucks also......
Picked up my seats from upholstery shop! Black with perforated red inserts. Of course its imitation leather. Can't afford real leather....
Thanks olo dollor. Can't wait to get my interior back together!
This would probably fall under "What I did to my truck this weekend". I located a whole front clip that was for sale cause the guy only needed the cab. The cab and The PO had purchased it from somebody else who had started to restore the truck. Not bad for $500 at least I didn't think so, new hood fenders and core support. Changed it out this last weekend.
He has found his love of restoring cars and trucks. Joining the service next year and is using his GI bill to pay for trade school. This is a father son project.
Posted via Mobile Device |
Pulled the windshield this morning before work. Yeah, I finally found a piece that doesn't have rust holes hiding under it.
![]() Installed some led curtesy lights but now my gauge cluster lights look really bad so time to change those to LEDs also Posted via Mobile Device |
RAT1968 '68 Cab/'71 Parts
Cleaned up the engine bay a little before I started the A/C fan install.
I decided to run a pusher electric fan (from the outside into the bay) strictly for the condensor that will switch on whenever the air goes on... ...because I wasn't getting enough air flow over the condenser with the two primary sucking fans (into the bay mounted on the engine-side of the radiator). The pusher on the condensor will go in... probably tomorrow.
M17 Coarsegold, CA RAT's shiny now. But always a rat. |
#11 | |
What valve covers are those.....very nice!
SOLD -77 CHEYENNE SWB, LS SWAPPED -1976 SILVERADO YUBA GOLD/NEUTRAL (2-TONE) |
Re: magwakeenercew2jh
Thanks.
E-Slay. Fairly inexpensive, if I remember correctly. I think they came out of Arizona. It was three years ago, but I'll look back on my Paypal account and see if I can find better info. Got it. Different seller, but these are the ones: http://tinyurl.com/b9r83bm
#13 |
Installed a new dash pad, and painted the dashboard behind it
![]() Posted via Mobile Device |
#14 | |
Thanks so much.....look alot like the ones I had on my 67 SS/RS back in 1982
#15 |
#16 |
![]() Join Date: Mar 2010
Took the cover off and cruised the plaza in 50 degree temps! Spring isn't that far away!
#17 |
Sunny and nice outside today.
Finished the A/C fan...I have it set up to come on when the A/C switch is activated. With a whole add'l set of relays and wiring on top of the dual fans and thermostat, it makes for a messy stash of wires. I may hide them if I get squirrley for another project sometime after the REAL projects run out (if ever), but I guess if I want colsd air in our hot summer months, the extra fan will be a big help. And, possibly, it will keep the dual radiator fans from working quite so hard. We'll see. I want to spend the $119 for the chunk of sheet metal that covers the space between the grill and the rad support. But I'm feeling cheap after I had my little date with the Tax Man yesterday. ![]() ![]()
#18 |
![]() Join Date: Nov 2008
My 14 year old son and my brother's 14 year old step son rebuilding my brothers step sons uncle's truck.
Rust frame Painted With Rustolum Cab With new body mounts Bed New Body Mounts Front Clip Just set on for easy removal Alot of work to still do but boy did they have fun.
1970 ![]() 1971 ![]() 1971 ![]() 1972 ![]() 1972 ![]() 1999 ![]() Last edited by orangek5; 02-18-2013 at 08:02 PM. |
#19 |
nice engine !
'70 C10 shortbed - 350 Edelbrock equipped - 4/1 headers - 3" flowmaster exausts '07 MUSTANG V8 convertible - CAI Spectre - Brembo's - 3" flowmaster exhausts |
#20 |
Installed CPP 2.5" drop spindles.
![]() ![]() Posted via Mobile Device ![]() Posted via Mobile Device Posted via Mobile Device
1970 C10 Short Stepper with 71/72 front clip. |
#21 | |
![]() Join Date: Mar 2012
Sold the 63 and have a 68 now. 63 ![]() LT1/4L60E, PS, PB, Disk Brakes, CPP 4" drop coil rear, 2.5" drop spindle w/ 1" drop coil. slotted rotors, front and rear sway bars. 18"x8" Cragar SS w/ 245/45R18 http://67-72chevytrucks.com/vboard/s...d.php?t=544174 |
#22 | |
#23 |
Today I got most of the bottom end of the new power plant assembled, If I could get my other
68 ![]() My other ride ,,, 07 Streetglide.. |
#24 | |
#25 |
Oil Change
