#526 |
Re: my 80 build
sounds good! i couldn't help but to watch him slam the door into something a few times
"Dennis the Menace" 1978 Silverado (2wd, 1/2 ton, short bed)complete nut & bolt frame off restomod LQ9/4L80E MY LS SWAP/FRAME OFF BUILD BOOK 2006 TBSS way too much to list ![]() |
#527 |
Re: my 80 build
where did you get those leaf spring bushings?
1979 c30 3+3 dually 1946 GMC |
#528 |
6.0 powered square
Re: my 80 build
classic parts of America
Aaron 1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326 |
#529 |
![]() Join Date: Dec 2008
Re: my 80 build
cam sounds awesome. this thing is gonna be a beast.
#530 |
6.0 powered square
Re: my 80 build
With my plans in performance parts it should be are real wild ride
#531 |
I have car A.D.D.
Re: my 80 build
![]() ![]() Posted via Mobile Device
-Gerald Building vehicles in memory of the first "car guy" I ever knew, my Grandpa. Bob Dunham 1935-2009. Rest in peace. 61 GMC Suburban SOLD The 86 build thread SOLD Are you a Colorado member?Click here. |
#532 |
6.0 powered square
Re: my 80 build
well I ordered from summit a h3 oil pan kit, fuel line adapters, a/n fittings, poly mounts, and gauge adapters
#533 |
6.0 powered square
Re: my 80 build
the cam, push rods, and valve springs came today
#534 |
Re: my 80 build
sweet
#535 |
6.0 powered square
Re: my 80 build
#536 |
Re: my 80 build
#537 |
6.0 powered square
Re: my 80 build
thanks Dennis, but the parts sure do add up quickly.
Well I got good news all the parts I ordered should be here today or tomorrow and if I get some to help me with the cam, pushrods, and springs the week, I going trying and pick and junk 4l80 so I can mock every thing up since I plan on adding a 3200 stall converter an they cost nearly as much as a used 4l80 around here
#538 |
6.0 powered square
Re: my 80 build
the brake lines came today
#539 |
Re: my 80 build
Looking good man
#540 |
Re: my 80 build
hey Aaron... just wanted to give you a little tip before you get too far along with those brake lines. stainless steel brake lines are a much harder metal than the regular steel lines. i used ss lines on the front system. THEY ALL LEAKED! the only lines that didn't leak were the factory lines that i re flared myself. once your truck is together it is a *itch to fix them and very frustrating when you buy pre bent lines that are already flared and ready to go and they leak like a sieve.
so here's the tip ![]() ![]() i probably will never use pre bent stainless lines again after all the trouble i had but if i do i will be heating those babies up before i install them for sure!
#541 |
Re: my 80 build
Coming along man!
Great tid bit Dennis! ![]() |
#542 | |
6.0 powered square
Re: my 80 build
#543 |
6.0 powered square
Re: my 80 build
thanks guys, got the order from summit today I will get some pics after wile
Aaron 1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326 Last edited by flamingbig10; 11-18-2010 at 09:05 PM. |
#544 |
6.0 powered square
Re: my 80 build
#545 |
Re: my 80 build
Aaron this thing is coming along great man. it amazes me for someone of your age to have the knowledge and the talent you do. keep up the good work and of course, all the pics that you can upload.
#546 |
6.0 powered square
Re: my 80 build
thanks
I got the cam pulled today ![]() ![]() ![]()
#547 |
Re: my 80 build
Is it just the pic or are the cam bearings worn bad?
2004 z71, 96 z71 on 38s, 88 Chevy k5 blazer, 4in lift. 84 swb project, 82 SWB project , 84 chevy 4x4 lwb project, 88 Jimmy beater/highschool ride. 79 c30. 99 tahoe 4x4 project. and a bunch of parts trucks.. |
#548 |
6.0 powered square
Re: my 80 build
its oil
#549 |
6.0 powered square
Re: my 80 build
slid in the cam today and picked up a ls2 timing chain from gm
#550 |
6.0 powered square
Re: my 80 build
![]() ls2 chain on left, 6.0 chain on the right, the links are thinker on the ls2 chain ![]() chain dampener ![]()
Aaron 1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326 Last edited by flamingbig10; 11-30-2010 at 01:23 AM. |
