Old 06-15-2009, 12:32 PM   #526
MacAttack
283 Drama Queen
MacAttack's Avatar
Re: The 283 Rebuild Begins
Originally Posted by jgh64pkup View Post
the cam needs a 20 minute break in at 2000 rpms before any load is put on it
Yeah, I've always heard the same thing - and that's what it will get once I get past this coolant exiting glitch.
On that note - the coolant was about 1/2" below the top of the upper tank when we started the motor, but I had the cap on during that cycle, and - grasping at straws(?) didn't wait to see if the coolant was flowing first.
Hoping this thing just belched and that POS cap with the silly gauge couldn't take it. I plan on putting the stock cap back on - next run.
Mac.
For about 12 years of my adult life I had a severe speech impediment.
My ex-wife never let me get a word in edgewise.
MacAttack is offline   Reply With Quote
Old 06-15-2009, 12:40 PM   #527
MacAttack
283 Drama Queen
MacAttack's Avatar
Originally Posted by jason65 View Post
Good to get that reward of hearing it run for all your hard work. I hope you got a pic of the thumb.
Thanks, Jason - got a couple of stills of the bloody digit and my boy had his video camera out - right up to the point dad attempted to take the pressure off the radiator by loosening the cap. Mouth full of 50/50 coolant. They haven't changed the recipe apparently, because it still tastes the same.
Originally Posted by 4dranch View Post
Nice Mac, Glad everything worked out
And glad no humans were injured in the drama..
Now that's just plain cruel! It was a pretty funny circus though. Just ask my neighbors.
Mac.
Old 06-15-2009, 05:32 PM   #528
joe231
joe231's Avatar
you never fail to entertain
and apparently the whole neighborhood got a show
CHEVY ONLY
Old 06-15-2009, 05:52 PM   #529
MacAttack
283 Drama Queen
MacAttack's Avatar
And there's still blood on the driveway!
Old 06-16-2009, 06:54 AM   #530
4dranch
Shloooooong bed member #2
4dranch's Avatar
[QUOTE=MacAttack;3361076] They haven't changed the recipe apparently, because it still tastes the same.QUOTE]
Can't wait to see the video....And I hope there's some sound with it..
Just Glad you can still count to 10 Mac..........
David,
Daughters 66 truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=484601
Learning to drive a 3 on the tree:
http://www.youtube.com/watch?v=CcCMvRgBo1Q
4dranch is offline   Reply With Quote
Old 06-16-2009, 09:57 AM   #531
MacAttack
283 Drama Queen
MacAttack's Avatar
Ordered the gages yesterday: Auto Meter / Oil pressure and Water Temperature.
Summit says it will be here by Friday - which is perfect for the relight next morning. I ordered another thermostat, but I'm planning on taking the current one out and leaving it out for the last 15 minutes of cam break in.
I'm also going to just fill the remainder of the radiator with water from the hose - just in case the motor pukes again. Also going to add an exit hose to the overflow bottle, in case things get crazy. Leaving the stock cap off to make sure the coolant is flowing and to see if the block needs anymore juice while running.
If this thing still has a blow-back problem then I've got to start looking at intake manifold or head gasket issues. Don't think so - but I don't do this enough to be sure. Followed the identical methods used on the Chevelle's Mr. Goodwrench crate motor - so theoretically it should be good to go.
Stopped by H.B. Transmissions yesterday on the way home from work and my guy's looking a little lean on work - so dropping my rig off next week should be a real hit at his shop. I asked what his capabilities (actually, what he feels like doing) were on this overhaul, and his short answer was, "Make me a list", which is exactly what I wanted to hear.
Mac.
Old 06-16-2009, 10:05 AM   #532
jason65
Registerd User
jason65's Avatar
Hope saturday is good to you Mac.
jason65 is offline   Reply With Quote
Old 06-16-2009, 10:13 AM   #533
MacAttack
283 Drama Queen
MacAttack's Avatar
Thanks Jason - already made my contribution to the SkinGod so I should be good.
Old 06-16-2009, 10:30 AM   #534
joe231
joe231's Avatar
so you are getting the trans rebuilt?
what transmission?
CHEVY ONLY
Old 06-16-2009, 10:40 AM   #535
MacAttack
283 Drama Queen
MacAttack's Avatar
what transmission?
The transmission (TH350) has already been rebuilt. It's the one I cracked the case on and had to get welded (Do'h!). This guy does just about everything drivetrain wise, so I'm commissioning him to do the following:
A./ New rear end (freeway friendly) gears.
B./ New brakes - including refab on the emergency brake bracket.
C./ Fab, install and adjust kick-down bracket assembly for the tranny - at the carb.
D./ Install 2" shorter front springs and replace rubber & parts while there.
E./ Lengthen the forward drive shaft and replace "U" joints.
Because of work going on at the house, I need him to keep the truck for two weeks - he's relatively slow right now - so the timing is nearly perfect.
Mac.
Old 06-16-2009, 10:47 AM   #536
4dranch
4dranch's Avatar
sounds nice.....
David,
Daughters 66 truck:
Old 06-16-2009, 10:59 AM   #537
MacAttack
283 Drama Queen
MacAttack's Avatar
sounds nice.....
Yeah, the guy is pricey, but thorough - so it's going to be strange to actually drive this old girl when this guy is finished.
Then I get to play with things that make sparks and fire while trying to learn the intricacies of body work. (I'll increase my home owner's policy coverage here shortly).
Old 06-16-2009, 11:29 AM   #538
1964C10
1964C10's Avatar
Mac, sorry to hear about your thumb! The things we bleed for right? lol. Just a quick question, do you have a thermostat in the cooling system? If so, how come you are seeing coolant flow in the radiator?
1964 Fleetside LWB
1995 Yellow Mustang convertible
1996 Camaro Z28
My build thread
Looking for help on completing the Disc Brake Upgrade Reference Thread
If you didn't build it, you don't really own it
1964C10 is offline   Reply With Quote
Old 06-16-2009, 11:38 AM   #539
4dranch
4dranch's Avatar
Just install a sprinkler system it might be cheaper..
David,
Daughters 66 truck:
Old 06-16-2009, 11:39 AM   #540
MacAttack
283 Drama Queen
MacAttack's Avatar
Yes - I've got a 180 degree thermostat in the motor and it's been my experience that with the cap off - with the engine at idle - you can see small bubbles and such floating by when the thermostat opens. I think in this initial case - with me leaving this very cheesy Mr. Gasket (with the heat gauge) cap on and not allowing the system to purge any air - the cap eventually let the pressurized coolant by, down the clear connector tube and into the catch bottle.
That's the way I'm telling the story, anyway.
Old 06-16-2009, 11:46 AM   #541
1964C10
1964C10's Avatar
Ok, I wasnt sure if you let the motor run hot enough for the thermostat to open up. I have had some issues getting the coolant on my Z28-LT1 to work properly and these cooling systems can be such a PIA lol
1964 Fleetside LWB
1996 Camaro Z28
My build thread
Old 06-16-2009, 12:10 PM   #542
MacAttack
283 Drama Queen
MacAttack's Avatar
For sure, and that's why I went with a brand new radiator and water pump. I already have countless hours of experience trying to correct blockages, leaks and scaldings - so I thought this rebuild was worth this extra expense, up to and including the purchase of hose clamps that would make NASA jealous.
Mac.
Old 06-16-2009, 12:26 PM   #543
1964C10
1964C10's Avatar
HAHAHA...close up pictures of the clamps?????
Let us know how you get it resolved though I am sure many of us are going to be faced with that same type of issue soon or later.
Diggin the long bed btw ;-)
1964 Fleetside LWB
1996 Camaro Z28
My build thread
Old 06-16-2009, 12:31 PM   #544
jgh64pkup
Sunburst C10!!!
jgh64pkup's Avatar
i would go ahead and go the full 20 minutes of break in just in case
do you know how to get your rings to seat
heres an article
http://www.mototuneusa.com/break_in_secrets.htm
Gage
1967 C10 Shortbed Stepside
jgh64pkup is offline   Reply With Quote
Old 06-16-2009, 12:33 PM   #545
MacAttack
283 Drama Queen
MacAttack's Avatar
David - you beat me to the punch!
Mac's venture into body work:
(it's amazing what I put myself through to entertain you guys)
Old 06-16-2009, 12:36 PM   #546
4dranch
4dranch's Avatar
it's definitly entertaining reading for sure..
David,
Daughters 66 truck:
Old 06-16-2009, 12:37 PM   #547
MacAttack
283 Drama Queen
MacAttack's Avatar
Go to around post #303 of this thread for some shots.
Old 06-16-2009, 12:44 PM   #548
MacAttack
283 Drama Queen
MacAttack's Avatar
Yeah - plan on running it for another 15 to complete that cycle, and on the ring seating issue - good catch on the link. Fortunately, I have a nice set of hills near my house, so when she comes back from the shop I'll take some blasts up and down those and get on the new binders to see how they work.
Mac.
Old 06-16-2009, 12:51 PM   #549
jason65
Registerd User
jason65's Avatar
Soon you will have a fresh, new, ready to go 1965 pick-up. I should say 1965 shlong bed.
Old 06-16-2009, 01:03 PM   #550
jgh64pkup
Sunburst C10!!!
jgh64pkup's Avatar
Mac.
you should probably go ahead and run it for another 20 minutes
Gage
