04-02-2009, 10:49 PM | #526 | ||
Re: LFD's 4dr Tahoe Build
Kevin LFD Inc. |
04-02-2009, 11:12 PM | #527 |
22 3/4" of rear rubber
I started working on the rear bag upper mounts. I decided to go with tube so I can tie it in with the upper diff web and then into the rear of the frame. I still have several mount braces to add to what you see as well as the upper mounting plates. But I did find one slight or major problem with the space limitations I have. I went to slide the tank in so I could see were to add the bends to the cross bar and found my tank and rear toe in bars are sharing the same space. So for now I just moved the toe in bars to the other side of the LFD mounting plate. Now depending on how the suspension cycles I will ether need to change the mount if I can or build another tank since I already sealed the inside of this one. I hope it is the tank because I was not as happy with this one as I wanted to be but it will never be seen but I do have a nice stash of SS. sheets that would do the job nicely. I think I am liking this idea Kevin LFD Inc. [IMG][/IMG] [IMG][/IMG] [IMG][/IMG] [IMG][/IMG] [IMG][/IMG] |
04-03-2009, 12:46 AM | #528 |
Im glad your buggy/cage building days have found a way into these trucks! its looks awesome! keep up the good work!
Bagged/Turbo 1970 GMC C-10 Crew Cab 1984 Chevy R-20 |
04-03-2009, 09:14 AM | #529 |
This thread kept me up till 2am . I am moving out to Northern California in a month. I would love to come check this bad boy out when things settle down. Your work is next level.
04-03-2009, 09:58 AM | #530 |
I hope you are planning on putting a plexiglass floor in that thing and not covering up all that work!
1972 Blazer body...need to get a thread started for the rest of the story |
04-03-2009, 06:35 PM | #531 |
X2! 1/2" Lexan! Put it on hinges so you can lift it up for cleaning. Who needs a third row? Think of it as a class room. Your son can watch the IRS function as you drive! Geometry in motion.
'70 GMC C1500 LWB Power disc brakes. WooHoo! Posi 6 Lug Dana 60 |
04-03-2009, 07:45 PM | #532 | |||
Kevin LFD Inc. |
04-03-2009, 11:36 PM | #533 |
04-03-2009, 11:53 PM | #534 |
The top mounts are done except for some braces that will go on once the body comes off. I should have it rolling by noon Saturday so I can get XXL's truck in the shop for a DropMember install. This will be the first DM with an I6 and should be sweet once it is done.
Kevin LFD Inc. [IMG][/IMG] [IMG][/IMG] |
04-04-2009, 05:39 PM | #535 |
67-72 parts collector,…
Kevin,... Did Nate build an I6 Dropmember? Or are you modifying one of his SBC Dropmembers?
I hope you are doing a thread on XXLs truck!
04-04-2009, 06:00 PM | #536 | |
Kevin LFD Inc. |
04-04-2009, 06:06 PM | #537 |
It rolls and moves up and down on AIR! I still have allot of work to go but that will happen after XXL's truck is finished and I get my DropMember installed. Then I will fit my 5.3/4L60 so I can pull the body off and finish the frame.
Kevin LFD Inc. [IMG][/IMG] [IMG][/IMG] [IMG][/IMG] |
04-04-2009, 07:36 PM | #538 |
Reminds me of the gassers of the late 50s/early 60s sitting that way.
Nice job Kevin. Can't wait to see what you do to XXL's wallet eater.
04-04-2009, 08:03 PM | #539 |
high-Tech Red Neck
You know Kevin, I am not a fan of lowered trucks, but I am damn impressed with how this thing is looking.
Allthough my biggest question is, why go with a 5.3 when this is going to be a tow rig? It would seem to me that the motor is a little light duty for the job. It could be just me, but I had a 99 1500 x cab short bed Z71 with a 5300 vortec in it, and when you hooked a trailer to it, it could barely get out of its own way. I even added a Chip, and removed the Cats and did a few other things to the truck, and still it didnt even come close to satisfying or impressing me. I wound up selling it and getting a 97 GMC 2500HD Xcab short bed, that truck impressed the heck out of me, it had the Vortec 454, and with the MSD ignition I added, the chip, and dual 3" exhaust and the Cat's removed, it was pulling over 16 mpg on the interstate, and I pulled my 71 Cutlass on a 18' car trailer from Seattle to Livingston Mt over the 5 mountan passes between and it kicked some serious tail, and still got about 9 mpg. I will also add that I have the 8100 vortec in the tow truck im driving now, it is far less than impressive, it is out right anemic. But it is a 2001, I dont know if they got better as time went on.
"He used to be a pretty nice feller, now he's a welder!" |
04-04-2009, 11:54 PM | #540 | |
Kevin LFD Inc. |
04-04-2009, 11:55 PM | #541 |
that is some tubing structure you have back there, looking really good Kevin, i don't think that a rear vette diff has ever looked so good.
James 1968 GMC "HAVOC" 1986 GMC "Frank" J.J.R.H. Design & Consulting My 68`Rebuild "HAVOC": http://67-72chevytrucks.com/vboard/s...d.php?t=316300 A 58' chev build thread: http://www.67-72chevytrucks.com/vboa...d.php?t=311238 1969 Camaro Pro Touring http://67-72chevytrucks.com/vboard/s...61#post3513361 Swiss Cheese: http://67-72chevytrucks.com/vboard/s...d.php?t=384390 Adjustable Trailing Arm How-To: http://67-72chevytrucks.com/vboard/s...d.php?t=321100 1968 Ford Farm Truck: http://67-72chevytrucks.com/vboard/s...=1#post6555587 |
04-05-2009, 12:58 AM | #542 |
Those tires/wheels look perfect on there. Your rear will def be lower than mine. Can't wait to see the front down.
On the 5.3, I had a 2001 Tahoe with a 5.3 and I towed my 61 on a full trailer over mountain passes and the Tahoe acted like there was nothing back there. Very impressive power even stock. |
04-05-2009, 01:20 AM | #543 | |
Yeah thanks for all the info on the wheels and tire's. I may still run some spacers to get the rear out just a bit because right now the wheels are touching my back seat. I do still need to adjust the camber on the rear at ride height and that will help out a bit. As far as a stock motor, who likes a stock motor right! Kevin LFD Inc. |
04-05-2009, 05:08 PM | #544 |
That is SWEET! Those rims look perfect on there. I like the pic with the wheels cambering in!
Tony from Norcal |
04-05-2009, 10:11 PM | #545 |
A guy with a truck
Hmmm... What are your plans for hood hinges?
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
04-05-2009, 10:52 PM | #546 |
I have not decided just what I want to do for that yet. I think their is some info on doing a forward flip hood but I might just build my own tubular cowl mounted units. Right now I don't have a clearance problem
Kevin LFD Inc. |
04-05-2009, 11:11 PM | #547 |
Wow! This thing looks better every time I check on it. Nice work, and you know I'll be looking forward to the I6 Dropmember!
04-06-2009, 02:16 AM | #548 |
Superbad
Wow, that saves a lot of floor space as apposed to using a solid rear axle. |
04-06-2009, 06:53 AM | #549 |
04-06-2009, 02:23 PM | #550 |
chevy only
NICE JOB KEVIN,THATS GOING TO BE A COVER TRUCK FOR SURE
CHEVY ONLY... Nothin Else ! |
