Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > Vendors Marketplace
Old 09-26-2011, 07:19 PM   #526
Daveboyd
Daveboyd's Avatar
Re: Boyd Welding-67-72 Rear Mount Aluminum Tank
Originally Posted by 68C10HotRod View Post
I'd like to suggest 2 changes to the current design.
1) Side Fill Tank, Make the filler tube 1.25" taller so it clears the frame rail without issues. My frame is roughly 4.375 tall but the bottom of the filler tube is 3.625" from the mounting bracket which runs it into the top of the frame rail.
I still don't have this fixed or the tank mounted.
2) The rollover valve is positioned almost directly under a bed floor support. If it was moved forward 2" toward the cab, I might have been able to mount the tank INSIDE the frame rails & shim so the filler would clear the rail.
My tank also fit very snug front-to-back when clamped down but seemed to have a very reasonable amount of play side-to-side. Consequently, I moved the rear frame brace back.
Just some ideas I hope you consider. I was expecting way more "bolt-in" than this has become. I "expected" to deal with a filler in the bed side but not the rail. Beautiful tank, just wish I was using it.
brian, what is the year and make of your chassis? I thought that you had requested another piece of pipe to fix the filler that we shipped recently. I have not had anyone else come to me with this issue on the side fillers so i am hesitant to revise the design. I will do the repairs to the tank if you want me to.
Dave Boyd
View Our 63-72 C10 Tank options https://fueltankparts.com/collections/63-72-c10-tanks
Boyd Welding Main Site : http://www.boydwelding.com/
Boyd Online Shop: https://fueltankparts.com/
E: Sales@boydwelding.com
Daveboyd is offline   Reply With Quote
Old 09-27-2011, 12:26 AM   #527
68C10HotRod
68C10HotRod's Avatar
Nope, never asked for or received a new piece of filler tube to get this fixed.
My truck is a 68 C10 LWB 2WD. Maybe the more direct way to look at this is, what dimension for side fill above the tank mounts do you make the neck stand up? Please note I included measurements in my post so you could compare the tank I got with the way you are currently building them. Also note in your post 409 (last pic) the side fill neck stands up noticeably higher than mine. Is there a chance that mine was simply done wrong? Were the mounting brackets placed too high, the filler tube cut too short?
I spent $100 to get this fixed Friday. If you want to do something to make that right, LMK. Would make me feel better about the whole deal.
Picture of the original tank. Notice bottom of filler tube is 3.625" above the mounting bracket.
Picture of tank AFTER FIX - BIG difference. Notice bottom of filler tube is now 4.875" above the mounting bracket.
Bryan
'52 Bel Air 2dr HT - in pieces
'68 C10 - 6cyl/4spd REMOVED, LT1/T56 to be installed
Any society that would give up a little liberty to gain a little security will deserve neither and lose both.” - Benjamin Franklin
"And those who know what's best for us, Must rise and save us from ourselves" - RUSH lyric (mockery)
68C10HotRod is offline   Reply With Quote
Old 09-27-2011, 09:03 AM   #528
Daveboyd
Daveboyd's Avatar
I was up half the night lastnight trying to understand why you are having problems with your tank and noone else is. I studied the dimensions that you supplied and the mounting tabs are in the correct position (3" down from the top of the tank) however your 2" filler pipe is only 2.5" up from the top of the tank and it should have been 3".
I am glad that you were able to get it fixed either way. Email me your name and mailing address and I will pay for your repairs.
Dave Boyd
Old 09-27-2011, 10:08 AM   #529
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
Stand up guy there Dave!
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 09-27-2011, 12:29 PM   #530
68C10HotRod
Guessing something just got cut wrong & didn't get caught. I REALLY appreciate you standing behind your product & work because THIS IS a fantastic tank!! Great vendors like you are part of this sites success. Continued success!!
PM sent.
Bryan
Old 09-28-2011, 01:06 PM   #531
Daveboyd
Daveboyd's Avatar
PM sent.
Kristin in accounts processed your repair refund this morning, I signed the check and put it in the mailbox so it is on its way to you. let me know if you have any more issues.
Dave Boyd
Old 10-02-2011, 12:19 AM   #532
68C10HotRod
Received the check today Dave. Stand up thing to do & I really appreciate it. I look forward to using your tank SOON.
Bryan
Old 10-18-2011, 01:57 PM   #533
70-Chevy
-Chris
70-Chevy's Avatar
Just ordered my tank today from Boyds. Cannot wait to get it!
1970 Chevy C-10 P/U, Shortbed, Fleetside - 5/7 drop, 496, TH400, 12 bolt.
BUILD THREAD - http://67-72chevytrucks.com/vboard/s...d.php?t=404481
2012 F250 Super Duty P/U - intake, exhaust, tuner, 4" lift with 35's
2017 Chevy Suburban (Wifes Car)
- Fully Loaded & Stock
"Some people spend an entire lifetime wondering if they made a difference in the world. But, the Marines don't have that problem."
Ronald Reagan, President of the United States; 1985
70-Chevy is offline   Reply With Quote
Old 10-20-2011, 11:39 AM   #534
eagleuh1
eagleuh1's Avatar
Dave, I believe that was me that ordered the extra filler tube to make my filler taller. And I apologize for not getting those pics and measurements to you. I was called back to work right after getting back from vacation and haven't got my bed pulled and tank mounted. I did cut and rebuild the filler to be taller though. Just wish I had the time to get it installed. As soon as I can, will get those pics. Jim. Thanks for the quick shipping of the filler tube as well. Great tank, great support and customer service. Thanks again.
eagleuh1 is offline   Reply With Quote
Old 10-24-2011, 11:08 PM   #535
BossHogg69
motor exploder
BossHogg69's Avatar
Got the bed set on the frame this weekend, figured I'd post some pics in case anyone was wondering what the Boyd tank looked like installed with a rollpan.
Adam
1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac
1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's
1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac
2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80
2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac
Use the SEARCH function on this forum - it is your friend!!
BossHogg69 is offline   Reply With Quote
Old 10-30-2011, 06:54 PM   #536
70-Chevy
-Chris
70-Chevy's Avatar
Thanks to Boyd Welding for a beautifal tank. The tank fit like a glove and looks fantastic! Will highly recommened to anyone looking for a tank!
Old 11-01-2011, 07:51 PM   #537
70-Chevy
-Chris
70-Chevy's Avatar
What have you guys done for an access panel to the filler in a steel bed? Any recommendations?
Old 11-05-2011, 06:57 PM   #538
trenz68
Damage Inc
trenz68's Avatar
what sending unit is used for this tank
05 CC- magnacharged,LTs,Gt-2 cam,3.73s,tru-trac,tuned-sold
01 ECSB- caddy-clipped,22/24 intros,cammed,layin-frame
04 RCSB-joe gibbs clone,22in billets
68 stepper build
http://67-72chevytrucks.com/vboard/s...d.php?t=332337
trenz68 is offline   Reply With Quote
Old 11-08-2011, 05:08 PM   #539
chopnchaneled
chopnchaneled's Avatar
Dave,,,
I've tried to read all 22 pages of this thread and so probably missed this,
but will the hidden hitch also work with your tank? 68 short bed, sport bumper?
I don't think we get smarter as we get older. We just run out of Stupid things to do.
chopnchaneled is offline   Reply With Quote
Old 11-08-2011, 09:58 PM   #540
c10seconds
c10seconds's Avatar
When will the group buy price be offered again?
c10seconds is offline   Reply With Quote
Old 11-15-2011, 04:43 AM   #541
Yobyllib
Yobyllib's Avatar
If there is a group buy in the near future put me down for a side fill tank.
Yobyllib is offline   Reply With Quote
Old 11-15-2011, 12:08 PM   #542
Clyde65
Clyde65's Avatar
Usually in the spring and fall.
Clyde65
Rebuild of Clyde
support our troops!
Old 11-22-2011, 09:57 PM   #543
Daveboyd
Daveboyd's Avatar
Sooooo If we were to make revisions to this current tank. Does anyone have any suggestions? Can be anything. Structure, pump options, Cap options. Please PM me any suggestions.
-dave
Dave Boyd
Old 11-23-2011, 08:02 AM   #544
rob32472
On the EFI tanks the you can here the pump whine maybe insulate or something...... I have heard several and they are all same.......
rob32472 is offline   Reply With Quote
Old 11-26-2011, 03:13 AM   #545
automagic67
All the pics I see in this thread have the tank rigidly bolted to each frame rail. What if I decide to take a fast turn or if I jack one corner of the rear up to change a tire(or any other reason) and the frame flexes. With the tank rigidly attached, it would have to withstand these forces. Did anybody mount this thing with straps or rubber bushings etc. to isolate the tank from the frame flexing?
automagic67 is offline   Reply With Quote
Old 11-27-2011, 01:34 PM   #546
automagic67
Another issue not addressed with this tank is galvanic corrosion where the steel frame contacts the aluminum flange. I plan to spray a coat or two of that rubberizer paint on the frame and on the flange to eliminate the chance of the flange pitting out. Still no responses to my last post about mounting the tank rigidly.
Old 11-27-2011, 05:42 PM   #547
Daveboyd
Daveboyd's Avatar
this is pulled from our website's standard installation instructions.
- TANK MUST BE MOUNTED WITH A RUBBER INSULATOR OF A MINIMUM THICKNESS OF 1/8″ BETWEEN MOUNTING SURFACES TO PREVENT WEAR TO THE TANK STRUCTURE
Doing this will keep your warranty valid and solve any concerns of corrosion.
Dave Boyd
Old 11-27-2011, 06:23 PM   #548
automagic67
Thanks Dave, could you please post a link to those instructions, I can't seem to find them on the site.
Old 11-28-2011, 01:23 PM   #549
Daveboyd
Daveboyd's Avatar
http://www.boydwelding.com/about Midway down the page. These are not really installation instructions but requirements to keep your warranty valid. we expect all customers to use common sense while installing these tanks and to keep them safe and secure as best as possible.
to address your concern on rigid mounting the tank.. I have alot of customers that do rigidly mount the tank to the chassis without any issues. If your tank cracks and you have the rubber insulator in between the frame and mounting angle that would be considered a warranty issue That we will take care of. If you would like to do more, i would suggest using a Rubber bushing backed by washers to absorb any flex you may experience.
Hope that helps
-dave
Dave Boyd
Old 11-28-2011, 04:55 PM   #550
Custom 68
Custom 68's Avatar
A couple things. First mine is EFI and the pump seems to be quiet enough for me. I had an external before that was much louder.
Secondly, the above height thing. I had to remove my rear cross support and slide my tank from the rear to sit the mounting "wings" on my frame. If I mounted it to the bottom I would have had the interference also. By placing it inside the frame it clears the top jsut barely. I would agree it would not hurt for it to be a little taller. I am waiting for my computer retune but have driven it some this tank looks and works super.
You mention "instructions" I honestly cant remember if I got any or not. if not I would suggest including this with these "must do" items like the rubber pad and the fittings.
A bigger more gph EFI pump would be a nice option this was not available when I purchased so I have the 255.
Thanks for the great product
Dave
Dave
1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap
1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?)
"A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome".
"If it doesn't fit force it...If it breaks then it needed to be replaced anyway!"
Custom 68 is offline   Reply With Quote
67-72 truck, aluminum tank, boydwelding.com, fuel tank, tank relocation
