08-28-2012, 08:28 AM | #526 | |
Re: Project "What was I Thinking" 68 SWB
94 k2500 EXCab Long Bed 350ci New Toy 95 K2500 Suburban New PlowTruck 454ci Support our Troops @ http://anyairman.com http://www.woundedwarriorproject.org/ |
08-28-2012, 10:38 AM | #527 |
I'm trying to keep my spirits up and not let this rust conquer me. It is the last of the rust left to fix.
Keith 66 Suburban Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361 IG: bennett68c10 |
08-28-2012, 10:49 AM | #528 |
A guy with a truck
Then it's all downhill and you get to do more of the 'fun' stuff. There's something truly gratifying about knowing that your truck is completely rust free. Just drop your head and trudge through--it'll be over soon enough
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
08-28-2012, 01:32 PM | #529 | |
08-28-2012, 02:35 PM | #530 | |
Man of Mini-Talents
I know how you feel. Sometimes for every step forward, you have to take two back. I know when I go to car shows now after having built a few, I have a whole new appreciation for the blood, sweat, tears, time and money that goes into these rascals. Keep it up, your reward is going to be awesome.
Steve Project - Ruth 66 Skylark Project - Lola 60 Biscayne Project - Iron Ox 54 GMC 100 Project - Darth 69 Camaro |
08-28-2012, 03:21 PM | #531 | |
08-28-2012, 03:27 PM | #532 |
I'M ALMOST THERE BUT i HAVE TO KEEP KICKING MYSELF IN THE BUTT TO KEEP GOING
So just keep on TRUCKIN
08-28-2012, 06:54 PM | #533 |
Thanks I will
08-29-2012, 10:33 PM | #534 |
Yep it will be worth it ! Keep up the great work Keith
Chris click here to see my buildpage http://67-72chevytrucks.com/vboard/s...d.php?t=394656 ---------------------------------- 1979 C10 Silverado Big10 SWB Factory 454/400 Cardinal Red/Santa Fe Tan (original paint) 1969 Camaro X44 LS swap 1968 C10 SWB Fleetside (SOLD) 468BBC MultiPort TPI / Dynamic EFI P4 Black/Black 1963 Nova SS convertible (SOLD) 194 I6/ PowerGlide |
08-30-2012, 03:00 PM | #535 |
Hey Keith didn't you have your Coys for sale? The link I sent a buddy is now dead.
Thanks,
Brett 67 Camaro SS Build:http://67-72chevytrucks.com/vboard/s...d.php?t=751594 72 Cheyenne/10 Super 115" Fleetside (Waiting it's turn.) 72 Cheyenne/K30 Super 133" DRW SOLD Build:http://67-72chevytrucks.com/vboard/s...d.php?t=645614 YouTube: https://www.youtube.com/@6dee7-7dee2 |
08-30-2012, 03:13 PM | #536 |
Thanks Chris
09-02-2012, 01:47 PM | #537 |
A guy with a truck
Quick question, as I'm soon to be needing them, too: what did you use for lower shock mounts up front?
09-02-2012, 09:53 PM | #538 |
I used the lower shock studs that came with my porterbuilt arms and shocks. The stud bolted to the arm and the shock bolted on the stud. Did you get your arms yet? Your using different shocks right?
09-03-2012, 09:35 AM | #539 |
A guy with a truck
Arms should be here tomorrow. I did not order their shocks, as I'm using Bilsteins- dunno if they sent the studs or not. Was just curious, as I noticed that the mount is single shear, but hadn't seen any mention of how the shock mounts...
Thanks again for the info- you are most helpful Posted via Mobile Device
09-03-2012, 06:45 PM | #540 | |
09-03-2012, 07:34 PM | #541 |
Well this weekend I worked on switching out my stock trailing arm crossmember for the Porterbuilt tubular 2pc driveshaft one. I have to say I hate rivets, a total of 14 in the stock crossmember, boy it sucked. I will be running a 2pc driveshaft so it gave me the reason to switch over.
Also my brother welded up the bottom of my rear window channel and also started shaving my firewall by welding in most of my porterbuilt kit. Forgot to take pictures again, I will get some next weekend. Posted via Mobile Device
09-03-2012, 09:47 PM | #542 |
A guy with a truck
You should try it with the cab on! Bring on the pics...
09-03-2012, 10:10 PM | #543 | |
09-06-2012, 10:49 PM | #544 |
How hard is it to swap the rear axles? dont have to mess with resetting the carrier unit do you?
SOLD -77 CHEYENNE SWB, LS SWAPPED -1976 SILVERADO YUBA GOLD/NEUTRAL (2-TONE) |
09-06-2012, 11:31 PM | #545 | |
09-06-2012, 11:32 PM | #546 |
Just what I wanted to hear!......Thanks for the response.
09-06-2012, 11:37 PM | #547 |
keith im looking forward to the picts.......
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild |
09-06-2012, 11:41 PM | #548 |
Man of Mini-Talents
X2.
09-07-2012, 08:12 AM | #549 |
I'll make sure I get some this weekend for you guys
09-07-2012, 08:57 AM | #550 | |
Tags |
bbc, dropmember, intro wheels, porterbuilt |
