Old 01-13-2015, 09:51 PM   #526
Orangetonicclicc
Orangetonicclicc's Avatar
Re: 1967 C10 Urban Retro
Once I get my steering column connection I can check my turn signals and brake lights. Plus I still need to finish the back up light switch install but I first have to extend those wires!
Orangetonicclicc is offline   Reply With Quote
Old 01-13-2015, 09:59 PM   #527
Orangetonicclicc
My wife and daughter thought it was so cool to see the lights on. Personally I was more concerned nothing happened when I turned the key except for the dash clock coming on, I at least thought I would get a click sound from the starter? Any suggestion guys? I have the purple wite connected to the (S) on the Starter solenoid. I don't have a neutral switch, so I'm thinking do I need to find those purple wires in the cab and jumper them together? I'm lost had to walk away again! lol!
Old 01-13-2015, 11:21 PM   #528
sduckworth13
sduckworth13's Avatar
Nice work on the progress. Everything looks top notch.
Scott
sduckworth13 is offline   Reply With Quote
Old 01-13-2015, 11:24 PM   #529
Orangetonicclicc
Thanks Scott!
Still got a few bugs to work out. But we are chipping away on it piece by piece, little by little!
Old 01-13-2015, 11:25 PM   #530
kxmotox247
kxmotox247's Avatar
Yes. Run a jumper wire between them.
kxmotox247 is offline   Reply With Quote
Old 01-13-2015, 11:29 PM   #531
Orangetonicclicc
Okay i have a painless kit. I really only saw one purple? But I was a little tired and needed to step away from it. I will look again tomorrow and see if I can figure it out. I'm a little confused. But I figured once I connected my column wires, it would shed some light on my predicament!
Old 01-13-2015, 11:35 PM   #532
kxmotox247
kxmotox247's Avatar
There should be two purple wires in the steering column harness that have been terminated with connectors. I think both female. They are meant to hook into the neutral safety switch on the column. You have to connect them if you're not running a neutral safety switch on the column.
You could take a simple test light and test each terminal as you twist the key. It should light the test light on one of them. Then you'll know that the key switch wiring is working and when you hook the two ends together it'll send power to the starter solenoid.
Old 01-14-2015, 12:16 PM   #533
Orangetonicclicc
[/ATTACH]
Bingo!!! That did it! I can hear the starter engage! Thanks bro! The other purple was tucked. I couldn't see it! I hope my column connection comes in today!
Old 01-14-2015, 12:28 PM   #534
kxmotox247
kxmotox247's Avatar
Very cool. By the way, I went by my local interstate battery and they had a bunch of the Optima battery adapters laying around. I ended up using one of the blue ones and the red hold down in order to get it all snug in a stock battery tray.
Things are looking good on your truck!
Old 01-14-2015, 12:32 PM   #535
Orangetonicclicc
Ok cool! So get a blue one and a red one?
Old 01-14-2015, 01:02 PM   #536
kxmotox247
kxmotox247's Avatar
Yep.
Since they had a pile of leftover stuff from installing them they just gave them to me for free. I think the blue ones are designed to snap in "in pairs" for Ford battery applications. When I went to try the red single puck by itself, it was too tall so I used one of the blue tabs to take up some of the space (height). Maybe you can find some for free too.
Old 01-16-2015, 03:24 AM   #537
Orangetonicclicc
Saw these on Marverick Q build and fell in love with it! The price is another story! I wonder if I can bribe my mom wife?
Old 01-16-2015, 03:27 AM   #538
Orangetonicclicc
Looks like a good fit for the former gas tank area. I think one would be an efficient sound, but for the look 2 would be better.
Old 01-16-2015, 03:37 AM   #539
Orangetonicclicc
These are actually for a 2007-up Tundra. But he said they fit perfect for our trucks. I need to figure out how to repair my cut out dash. I wished I noticed that before I got my truck painted. How did I NOT see that! Sigh! Man! I want to put an authentic looking radio with upgraded technology. Is there anyone on the forum who makes custom CNC plates/frames to cover a butchered dash? I really don't want to put a newer model stereo in my dash...
Old 01-16-2015, 10:50 AM   #540
kxmotox247
kxmotox247's Avatar
I bought one of these unpolished and polished it myself to save a few bucks. The thread appears to be dead but if interested you should send him a PM.
http://67-72chevytrucks.com/vboard/s...d.php?t=624412
Old 01-16-2015, 10:53 AM   #541
Orangetonicclicc
Yeah... I'm familiar with those, but I'm working on getting a plate machined for the original look.
Old 01-17-2015, 09:59 PM   #542
Orangetonicclicc
Dash lights
Old 01-23-2015, 12:10 AM   #543
Orangetonicclicc
Fuel lines are ordered!
Old 01-23-2015, 01:13 PM   #544
WiggyHD
Gettin' closer! I can almost hear it now!
Mark
Retired Air Force/Disabled Vet
1969 Chevy C-10, On the way to greatness!
WiggyHD is offline   Reply With Quote
Old 01-24-2015, 08:59 PM   #545
Orangetonicclicc
Braided Nylon Hose and AN Fittings were delivered today. The fitting went on fairly easy. Hopefully I have no leaks. Now I need to measure and cut and add the the fitting that's spliced to the fuel filter.
Old 01-24-2015, 09:01 PM   #546
Orangetonicclicc
Measurement and cut is made mock fitting to see where and how I want to mount my fuel filter.
Old 01-24-2015, 09:06 PM   #547
Orangetonicclicc
Need to get an adapter fitting to go from the tank to the AN fitting. Can anyone tell me if I need to plug that other hole of make it a vent and if I need to make it a vent. What do I use? Do I use a check valve or add a hose and run it higher than the tank? Oh it's all mechanical, no electric fuel pump nor a fuel cell.
Old 01-24-2015, 10:11 PM   #548
Orangetonicclicc
Never mind! I forgot it had a vent plug! I bought that tank almost 9 years ago!Name:  image.jpg
Old 01-26-2015, 10:15 PM   #549
Orangetonicclicc
Adapter fitting for the tank fit great!
Old 01-26-2015, 10:18 PM   #550
Orangetonicclicc
Ready to drill the mounting holes for the fuel filter
1967 c10, chevy truck, classic truck, short bed
