Old 11-16-2012, 08:04 AM   #526
XxCHEVYMANxX
XxCHEVYMANxX's Avatar
Re: Project: Turbo 250
You have a nice long winter to get things wrapped up. looking forward to progress pics when you have em.
John
Mild Custom 68' Work Truck Build
Facebook LoL
1977 Trans Am (Project)
1965 Chevelle (Project)
XxCHEVYMANxX is offline   Reply With Quote
Old 11-17-2012, 10:04 AM   #527
kyull67
kyull67's Avatar
Was just looking at you carb and intake setup. Does the clifford four barrel adapter plate mount the carb lengthwise? (as apposed to sideways).
If you look at my most current build picture, you can see that I have mine sideways with a cheap carb adapter. It's presenting some fuel line and throttle difficulties.
BUT, I've heard it's better to mount the carb sideways for fuel distribution on the inlines. What do you think?
kyull67 is offline   Reply With Quote
Old 11-19-2012, 12:08 AM   #528
longbed67
longbed67's Avatar
Originally Posted by paintman View Post
hey longbed! Just so you know....I just got off the phone with the guy making the new harmonic dampners over on inliners.org. He told me they are going into production in about 2 weeks and he is only making enough to cover what is pre-ordered. So if you want one you better get on the list. The steel 2 groove is $411 plus $20 shipping.
Holy crap! I think I will stick with stock for now... thats a little steep for me right now. Thank you for the info!!! Maybe He will make another run down the road.
There isnt salt on the roads yet! I still might get my drive in this year
I am running about a 1.125" NOS billet nitrous plate spacer between the 1/2" clifford adapter and the bottom of the carb for a total of 1-5/8" of spacer. The billet clifford adapter can be run either direction, And with that much space I am not concerned about the fuel distribution issue in my setup, and yes turning your carb in any direction but what I have will make your fuel lines and your throttle cable a PITA! I can see that on a n/a setup that turning the carb MIGHT help, but on a blow through the physics are a little different, and would diminish the benefits of rotating the carb. I personally would run it in the direction is was easiest to mount the fuel lines and the throttle linkage if I was you. thats my .02
Adam
My 1967 C10 - Turbo 250 Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=485843
(608) 214-8706
longbed67 is offline   Reply With Quote
Old 11-21-2012, 09:50 AM   #529
kyull67
kyull67's Avatar
OK. That's kind of what I figured being under boost. I will have to order that Clifford adapter, It'll be much easier to route everything.
Thanks again!
Old 11-21-2012, 12:43 PM   #530
longbed67
longbed67's Avatar
Kyull, as a heads up once you turn your carb the throttle arm on the carb will hit the intake manifold. You will have to get an additional carb spacer to put in there to gain enough clearance.
Adam
(608) 214-8706
Old 12-07-2012, 04:00 PM   #531
longbed67
longbed67's Avatar
Just thought I would post up a little teaser... Finals week in my final semester of class work for my Doctorate so not much time for the truck right now but soon!
Adam
(608) 214-8706
Old 12-07-2012, 05:45 PM   #532
hgs_notes
GEARHEAD
hgs_notes's Avatar
Classic. Are they 17's?
hgs_notes is offline   Reply With Quote
Old 12-07-2012, 05:47 PM   #533
67cheby
67cheby
67cheby's Avatar
Doctorate.....WOW, IMPRESSIVE !! CONGRATS !
67cheby is offline   Reply With Quote
Old 12-07-2012, 06:15 PM   #534
longbed67
longbed67's Avatar
YEP! And I will be running 245/65 17's on all 4 corners.
Thanks! Its been 8 years coming!
Adam
(608) 214-8706
Old 12-07-2012, 07:39 PM   #535
NewType72
NewType72's Avatar
Congrats brother I wish you the best on your finals
Project NewType 1972 Chevy C/10 Cheyenne Super ( Daily Driven Showtruck ) http://67-72chevytrucks.com/vboard/s...d.php?t=507903
Project Great Grandpa's Legacy 1973 Chevy C/10 Cheyenne ( Current daily driver collecting big time parts ) http://67-72chevytrucks.com/vboard/s...89#post7084289
- Dylan
(209)-985-7721
NewType72 is offline   Reply With Quote
Old 12-26-2012, 12:09 PM   #536
sprint_9
sprint_9's Avatar
Great build, wondering where you got the rear speaker panels from? I've seen kick panel setups but never anything in that location behind the seat.
Item in question is in post 400. Thanks.
sprint_9 is offline   Reply With Quote
Old 12-26-2012, 08:22 PM   #537
longbed67
longbed67's Avatar
http://67-72chevytrucks.com/vboard/s...d.php?t=476976
BigBlock73 on the forum here can hook you up! He is a great guy and very helpful! And the quality of his product is top notch!
Adam
(608) 214-8706
Old 12-27-2012, 03:18 PM   #538
sprint_9
sprint_9's Avatar
Cool, Thank You
Old 01-29-2013, 12:33 PM   #539
circa73
circa73's Avatar
How do you adapt your trailing arms to accept the bags? Is there another bolt on adapter you use in place of the old spring retainers?
circa73 is offline   Reply With Quote
Old 02-02-2013, 05:10 PM   #540
longbed67
longbed67's Avatar
Depending on the ride height that you want to run, you can bolt the bag directly to the top of the arm if you want it low, or place a cup on the arm to add some height to reach the desired ride height. I bolt everything in place with American made grade 8 bolts.
Adam
(608) 214-8706
Old 02-02-2013, 08:44 PM   #541
NewType72
NewType72's Avatar
How's the doctorate coming along haven't seen you on here in awhile?
- Dylan
(209)-985-7721
Old 02-03-2013, 11:25 PM   #542
longbed67
longbed67's Avatar
Keeping me 105 miles away from my build is what it is doing! LOL I'm working pediatrics at a private practice clinic right now south of where my build is going on.... I made it back this past weekend and had to put a new rear end in my s10 as the pinion gear blew up... so that took friday night and part of sat morning... and so sat. night and this morning josh and I got most of the interior wiring done and got the carpet and seat installed and bolted down. Ran some testing with the gauges and powered up most of the systems in the truck and so far all systems go... No pics were taken but will get some next weekend... Working on a 4 bar flip out design for the suspension control systems touch screen to go into where the ash tray is.... A lot of small loose ends were tied up on the truck this weekend and it turned out nice... I also started to nib down any small sags in the clear and starting to wet sand the clear... pics will have to wait till next weekend as I am already back down south at my apartment that is more like a jail as all I can do is work for free and pay rent to stay down here.
Adam
(608) 214-8706
Old 02-04-2013, 01:36 PM   #543
NewType72
NewType72's Avatar
Oh man that would be killing me to have to wait when it's this close to finished but it's good to hear how you're doing at the P.P. clinic and sounds like you're doin a lot better off in the wiring dept compared to me
- Dylan
(209)-985-7721
Old 02-05-2013, 04:48 PM   #544
superflysteiny
superflysteiny's Avatar
congrats that is huge
superflysteiny is offline   Reply With Quote
Old 02-06-2013, 10:01 AM   #545
longbed67
longbed67's Avatar
Thanks guys! Its really good to have friends that are as good as Josh is at wiring! It helps a lot! and lord knows I wouldnt be half as far on it if it werent for him!
Adam
(608) 214-8706
Old 02-25-2013, 03:48 PM   #546
longbed67
longbed67's Avatar
Some interior pics as promised. I still have a couple wires to tie up, one bracket to secure on the steering column, clean the steering column rubber, and refinish the steering wheel... I am happy about how high I was able to tuck the vintage air up under the dash, took a lot of finagling and some different brackets, but was worth it as I now have more foot room on the passenger side and it looks a little cleaner. Hopefully the weather will keep improving here as the days continue to get longer, and I can get her done. Oh yeah, I kept all of the interior colors original, except for the floor, it originally had a black rubber mat, i switched it out for ultra plush carpet to match the dash pad and the dark midnight fawn of the top of the dash.
Adam
(608) 214-8706
Old 02-25-2013, 04:10 PM   #547
NewType72
NewType72's Avatar
- Dylan
(209)-985-7721
Old 02-25-2013, 06:43 PM   #548
cAlvis165
cAlvis165's Avatar
Good to see some updates. Interior looks nice and clean!
Success is not final, failure is not fatal: it is the courage to continue that counts. Winston Churchill
DD 2000 Chevy Suburban 4x4/5.3 Vortec/4L60E/4:10s, 18" Escalade rims, Electric fans
Project Dooley One-Ton 4x4 on 38.5s Corn-binder build
cAlvis165 is offline   Reply With Quote
Old 02-25-2013, 07:52 PM   #549
jlsanborn
jlsanborn's Avatar
Looking sharp man! That color combo is really cool
'77 K30 3+3 - "The Crummy"
http://67-72chevytrucks.com/vboard/s...d.php?t=640134
'67 C10 L/SWB - Soon to be daily driver!
http://67-72chevytrucks.com/vboard/s...d.php?t=471776
jlsanborn is offline   Reply With Quote
Old 02-25-2013, 08:16 PM   #550
cubber
Hey, Adam! I was wondering about you the other day. I really like your interior!! Also, I am really excited for you to get your doctorate. I know all the schooling has been a tremendous undertaking, and I am so happy to see that you will end it soon with success!
=MATTHEW
69 Stepper...Stroked & Bagged GONE BUT NOT FORGOTTEN
2003 Chevrolet Z71 Ext. Cab
1995 Cavalier gas saver!
cubber is offline   Reply With Quote
