Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1960 - 1966 Chevrolet & GMC Pickups Message Board > 60-66 Suburbans
Old 03-07-2019, 12:21 AM   #526
piratexpress1369a
piratexpress1369a's Avatar
Re: Our "What are we going to do?" 66 Suburban Build
Really changing that up
..WOW that's going to be a beast
My 63 GMC Panel Slow Build
http://67-72chevytrucks.com/vboard/s...=1#post5457281
63
piratexpress1369a is offline   Reply With Quote
Old 03-07-2019, 02:23 AM   #527
RockTonka
RockTonka's Avatar
Hey PE, good to hear from ya! Yea, it was fun before...but it's gonna be a LOT more fun soon!
1958 Chevy 1 ton dually 4X4 dump/flat bed
My build thread
1966 "Not-So-Original" Chevy Custom Trim Suburban
My Time-Killing Project Truck
1966 GMC Extended cab 1 1/4 ton 4X4
My Son's build thread
RockTonka is offline   Reply With Quote
Old 03-10-2019, 01:17 AM   #528
RockTonka
RockTonka's Avatar
We've finished most of what we wanted to do on the chassis...
My build thread
Old 03-12-2019, 12:50 AM   #529
RockTonka
RockTonka's Avatar
Well, maybe a bit more...repaired a couple body mounts at the rear and then plated all of them.
My build thread
Old 03-18-2019, 11:50 PM   #530
scotts62
One day...
scotts62's Avatar
Im going to have to come check that out. im sure the pics arnt doing much justice.
Scott
93 crew cab build
Project 62
Old 03-19-2019, 11:27 PM   #531
RockTonka
RockTonka's Avatar
You should...I might put you to work though!
My build thread
Old 03-19-2019, 11:58 PM   #532
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Man....
Scott actually has time to be here !?!?
Frame looks good...
Not nearly enough Okie Dimple Die holes though..
John
What the Heck is that ??
CURRENT BUILDS:
62 BurbMaster
Other Builds:
My '63 C-10,LWB,CC,BBW
'06 HD StrAight Axle Swap
Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build
AMERICAN CUSTOMS & CLASSICS (831) 630-1965
www.ACCHOLLISTER.com
ACC on FACEBOOK
"Rest in Peace, Mom & Dad ... I will see you again someday!"
ChiefRocka is offline   Reply With Quote
Old 03-20-2019, 12:12 AM   #533
RockTonka
RockTonka's Avatar
A bit on the motor...540 ci w/Carillo rods, Wiseco forged 8.5 to 1 pistons, Kryptonite crank(LA Enterprise) going into a 10.2 tall deck BBC with "Big Brodie" Brodix heads. We're still working on cam choice, but this motor was originally a 900SC from Mercury Racing.
We're pairing it with a 671 Weiand blower and a couple 650 Edelbrocks. The plan is to run around 8-10 lbs boost on pump gas.
We may run a couple hundred shot of NOS since we have most of the set-up from the last motor.
My build thread
Old 03-20-2019, 12:18 AM   #534
RockTonka
RockTonka's Avatar
Originally Posted by ChiefRocka View Post
Man....
Frame looks good...
Hey John...good to hear from ya! I seriously have had to restrain myself from dimpling crap on this go around...it would never get done!
My build thread
Old 03-20-2019, 12:32 AM   #535
RockTonka
RockTonka's Avatar
We want to be a little obnoxious with this, so we chased down a 4" tall intercooler (gutted) to use as a spacer between blower and intake...make it stick out of the hood more.
The only problem was that it was for a 871. We sectioned/machined/welded the rear of the cooler to fit our shorter (lengthwise) 671 intake.
The heads had been painted in their prior life...poorly. We had the heads vatted and then bead blasted them. We wanted to powder coat them clear, but after discussions with Brodix decided not to.
Brodix is a couple hundred miles away in Mena, AR...so we ran the heads, lower intake, and spacer to them for a quick refinishing...looks brand new and is the finish we were after.
My build thread
Old 03-23-2019, 08:59 AM   #536
piratexpress1369a
That going to be a beast...how long before you are able to fire this up
63
Old 03-24-2019, 11:59 PM   #537
RockTonka
RockTonka's Avatar
The first fire/break-in/tune will be on the dyno at the machine shop...I'm hoping in the next month or so.
My build thread
Old 04-11-2019, 10:43 PM   #538
RockTonka
RockTonka's Avatar
Working on putting the chassis back together...cleaning, painting, and upgrading where we can.
Changed up the wheels and went with a little bigger 31x16.5x15s, also switched over to coil overs on the rear.
My build thread
Old 04-12-2019, 12:32 AM   #539
Captainfab
60-66 Nut
I like it!
What width are those wheels?
Old 04-14-2019, 02:13 AM   #540
RockTonka
RockTonka's Avatar
Originally Posted by Captainfab View Post
I like it!
Thanks Capt., 15x12 on the wheels.
We hung a new gear box on Capt.'s mount...upgrading the steering a bit.
Also ran the brake and fuel lines...
My build thread
Old 04-17-2019, 02:33 AM   #541
RockTonka
RockTonka's Avatar
Scott swung by to get us started on a bit of patching...well, mainly cutting cancer out!
My build thread
Old 04-17-2019, 02:35 AM   #542
RockTonka
RockTonka's Avatar
We did get one patch in though...
My build thread
Old 04-17-2019, 09:08 PM   #543
piratexpress1369a
Nice work...love the skates makes moving thing around much easier
63
Old 04-18-2019, 12:37 AM   #544
RockTonka
RockTonka's Avatar
Thanks PE...dollies are mandatory now!
My build thread
Old 04-18-2019, 12:45 AM   #545
RockTonka
RockTonka's Avatar
Picked up a set of mounts for the block, felt like we needed something stouter than stock...fabbed up the frame side mounts tonight.
Dropped a size on the front tires...275/60R-15 to 255/60R-15 on 8" wheels. We wanted a bit more room for the fenderwell headers at full lock and bump.
My build thread
Old 04-18-2019, 07:57 PM   #546
scotts62
One day...
scotts62's Avatar
Hey i like those.
Firewall came out nice!!!
Scott
93 crew cab build
Project 62
Old 05-03-2019, 01:15 AM   #547
RockTonka
RockTonka's Avatar
Hey i like those.
Thanks Scott!
My build thread
Old 05-03-2019, 01:21 AM   #548
RockTonka
RockTonka's Avatar
Went by the machine shop today...short block is coming together! This piece of the puzzle will move along faster now.
My build thread
Old 05-03-2019, 02:17 AM   #549
RockTonka
RockTonka's Avatar
We've been gathering other parts up too...
BTE HD T400 w/RMVB, transbrake, 36 element Pro Mod Sprag, Vasco steel input shaft, Vasco steel intermediate shaft...built for north of 1500HP (we won't have quite that, but good insurance.)
BTE 11" Race Torque Converter, flash stall around 4K, (spragless w/mechanical diode)...again, good for 1500HP+.
JetHot extra high temp coated Schoenfeld fenderwell headers, 2.25 primaries into 4" collectors w/V-band flange.
NOS blower injector plate...will keep it around a 200 shot.
Kilduff "lightning rod" shifter
My build thread
Old 05-06-2019, 02:09 AM   #550
RockTonka
RockTonka's Avatar
Scott broke away and spent some quality time with us this weekend!
My build thread
