Old 09-15-2013, 07:11 PM   #526
Xeen
Xeen's Avatar
Re: 1968 Chevrolet SWB Stepside Restomod
Hey all;
I finished up the Fuel pump wiring today.
I took advantage of the stock +12v accessory block.
I'm very happy with how it turned out it looks like it was that way from the factory.
Wiring at the tank.
Please call me Brian.
Check out My 1972 SWB Fleetside 5.3L Vortec Restomod Build
Xeen is offline   Reply With Quote
Old 09-15-2013, 10:38 PM   #527
Xeen
Xeen's Avatar
Hey all;
I found this relay pinout with key while I was installing the wiring for the fuel pump and I thought it might be usefull to you guys.
Old 09-15-2013, 11:27 PM   #528
El Campo
El Campo's Avatar
Wiring turned out looking great! Loom that you used sure does do the trick right.
72 Chevy blue LWB, 99% original Oklahoma truck, 28,000 miles
72 Chevy SWB: http://67-72chevytrucks.com/vboard/s...d.php?t=486626 (Attempt/Mistake #2)
2003 Harley Davidson Dyna Superglide with 2007 Street Bob front end
2000 Ford F350 Powerstroke 4WD CCLB, 310,000 miles running great (STOLEN St. Patricks Day 2014 AND NEVER RECOVERED)
2002 Ford F250 Powerstroke 4WD CCLB (To replace stolen one)
Hook em Horns!!!
El Campo is offline   Reply With Quote
Old 09-16-2013, 05:31 PM   #529
Xeen
Xeen's Avatar
Hey all;
No work done on the truck today on account of the weather, it's raining.
Old 09-17-2013, 08:18 PM   #530
Xeen
Xeen's Avatar
Hey all;
Today I designed a mounting bracket for the battery tray.
Tomorrow I will fabricate it, paint it and get it installed.
Old 09-18-2013, 01:29 PM   #531
gdavis
gdavis's Avatar
Hey guy. Just thought to say hello and say thank you. Are you going to paint the brackets silver also. Can't wait till it is in the truck where I can see it. You are getting close there man. George
Check out Patches
Cars I owned in the past.
1962 chev II Nova - 1965 Chevelle SS - (2)1966 Chevelle SS 1965 chev C10 57 belair chev
1967 Chevelle SS - 1969 Chevelle SS - 1972 Chevelle SS
1967 Buick electra 225 1995 Harley Davidson bager
What does not kill you will make you stronger
1968 c10 short wheel base stepper
gdavis is offline   Reply With Quote
Old 09-18-2013, 08:14 PM   #532
Xeen
Xeen's Avatar
Hey all;
I got a late start today so I only got the bracket fabricated and painted, it's hanging to dry right now.
I will instal it tomorrow.
Old 09-19-2013, 06:19 PM   #533
Xeen
Xeen's Avatar
Hey all;
Today I did a test fit on the battery tray, I knew I was going to have problems with the angle of the radiator bracket on the core support and to find out just how much compensation was needed I had to bolt it in.
It decided to storm today so tomorrow I will drill a hole in the radiator bracket and get a spacer the right length to put in there to make up the difference.
Despite the angle problem the bracket I fabricated seems to be plenty strong enough to do the job.
As you can see the angle is way off at the mounting point.
Old 09-19-2013, 06:47 PM   #534
Vic1947
Vic1947's Avatar
Looking good!
Victor
57 Chevy Wagon - California Dreamin'"Mecum'd" 9/2022 Dallas, TX
Crusty Rusty Leaky Squeaky 67 Consigned 4/2019 Dresden, Germany
Maybelline - my '57 Ford 2dr Sedan "Mecum'd" 3/2016 Location unknown
Silver Streaker "Mecum'd" 4/2013 Somewhere in Texas
Vic1947 is offline   Reply With Quote
Old 09-20-2013, 10:48 AM   #535
Xeen
Xeen's Avatar
Hey all;
This morning I got an early start and fixed the radiator bracket angle issue.
I used a nut as a spacer, the simplest solution is sometimes the right one.
That bad boy is just like a Chevy should be "Like a Rock!"
Old 09-20-2013, 06:39 PM   #536
oldman3
oldman3's Avatar
Alright...Jim
oldman3 is offline   Reply With Quote
Old 09-20-2013, 07:50 PM   #537
gdavis
gdavis's Avatar
It looks solid enough. keep up the good work there man.
Check out Patches
Old 09-21-2013, 09:46 AM   #538
Xeen
Xeen's Avatar
The case of the missing jackstand.
I went out early this morning to drill the new holes for the transmission crossmember and couldn't find the second jackstand and after 30 min of looking for it I gave up.
I guess work is halted untill I can either find it or get new jackstands.
Old 09-21-2013, 10:56 AM   #539
Xeen
Xeen's Avatar
Missing jackstand found.
It turns out I didn't need to drill new holes in the frame for the transmission crossmember, I just needed to flip the mount around to gain the extra little bit of room to get the bolts holes to line up.
Monday I will measure for driveshaft length and take it in to get shortened.
Old 09-21-2013, 12:46 PM   #540
SeTx67
SeTx67's Avatar
Brian, come on man. You can't just tell us you lost a jackstand, found it and not tell us where! We need deatails. Lol
You've been making steady progress lately. Keep it up
SeTx67 is offline   Reply With Quote
Old 09-21-2013, 01:18 PM   #541
Xeen
Xeen's Avatar
It was where all lost things are that get found, in the last place you look.
Naw but seriously though, I dropped it down behind a ladder and completely forgot I did it, out of sight out of mind, you know how that goes.
Old 09-21-2013, 08:09 PM   #542
gdavis
gdavis's Avatar
First that goes is memory. Then everything else seems to follow. Buy what the hey it is all fun isn't it.
Check out Patches
Old 09-23-2013, 08:57 AM   #543
gdavis
gdavis's Avatar
Hello there man. I need to call you so you want think I fell off of the earth.
Check out Patches
Old 09-23-2013, 10:59 AM   #544
Xeen
Xeen's Avatar
Hey all;
This morning I took my driveshaft in to get shortened and ballanced.
I'm stoked!
Old 09-23-2013, 06:55 PM   #545
Xeen
Xeen's Avatar
Hey all;
I got the driveshaft installed.
4x4 Land cut it 1/4" too short, apparently they don't know how to read a tape measure but I will live with it considering I doubt very seriously they are going to make me a new driveshaft over 1/4" heh.
1/4" too short.
Old 09-23-2013, 07:26 PM   #546
oldman3
oldman3's Avatar
Shouldn't be a problem, and now the seal has a new surface to work with...Jim
Old 09-24-2013, 06:57 AM   #547
Xeen
Xeen's Avatar
1/4" is quite a bit, I expect it to come back exactly how I ordered it, maybe I could have tollerated 1/8" but 1/4" is just too much.
Granted I only have about 315 horse but the input shaft is under quite a bit of stress even when it's done correctly.
Old 09-24-2013, 07:25 AM   #548
Xeen
Xeen's Avatar
Hey all;
I found out the weatherpack connector for a 2001 camaro electric fan is different then the one on the 2003 silverado so I need to hunt down a harness or at the very least some correct weatherpack connectors.
Things on the punch list for this week.
1) Wire up the electrical at the ignition switch.
2) Connect the coolant hoses/overflow and fill up the engine coolant.
3) Purchase and instal a battery.
4) Modify the electronic throttle assembly.
5) Instal and hook up the brake/cruise switch.
6) Wire up the cruise control.
Old 09-24-2013, 05:29 PM   #549
SeTx67
SeTx67's Avatar
Here's a link for the ls1 fan connectors. There's quite a few others there also but they are on page 1
http://tpiparts.net/harness_repair_connectors1?b=1
Old 09-24-2013, 07:51 PM   #550
gdavis
gdavis's Avatar
so it looks like yu have a lot of yoke showing where the seal rides is there enough.
Check out Patches
1968, chevrolet, restomod, stepside, swb
