#526 |
Re: Knomadd '71 SWB C-10
Thanks Duane for the information on the hood.
Scott |
#527 | |
![]() Join Date: Jul 2010
![]() DeWayne
www.nsanehotrodz.com customerservice@nsanehotrodz.com 865-761-0460 Tennessee's #1 HotRod Shop! |
#528 |
6>8 Plugless........
![]() Join Date: Sep 2007
The new hood looks great! I was really surprised how nice my tri-plus hood fit from all the horror stories I kept hearing about others.
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
#529 |
Thanks guys!
I was able to get some more of the air management installed and buttoned up. Please excuse the dirt and rust underneath. This one is used often, and parked outside. On with the pics... VU4 and computer mount: ![]() Water trap mount, and some electrical and air line routing: ![]() Electrical and other water trap mount: ![]() Gauge air line routing into cab using old fuel line hole: ![]() Air pressure gauges installed: ![]() I haven't connected the bags to the VU4 yet. I wanted to test it and make sure the tanks and everything held pressure first. It's a good thing I did because the compressors wouldn't shut off. Not sure if it's a wiring thing, or a bad pressure switch. I've been over my wiring multiple times and I can't see anything wrong, so I'm thinking it's the switch. Have one ordered and on its way here. Just in case, I reached out to Travis at Pro Performance and he's going to get me some wiring schematics for the Accuair with Viair pressure switch. Neither set of instructions from either manufacturer show connection between the two systems, so we'll see if there's something wrong with my blending of the two later. Either way, I hope it's a simple fix. I also have a small leak in one of the water trap fittings. I think I'll pull it and redo the thread sealant and re-cut the air line.
-Duane C/10 Club Texas member 1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project) 1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby) Last edited by knomadd; 07-13-2017 at 05:13 PM. |
#530 |
The wife let me put her car outside for the weekend so I pulled the truck in and got the air lines ran for all four corners. The Accuair SwitchSpeed is finally up and running!!! Works great too! I need to drive it a bit, check the ride height and get used to the air pressures I should expect, but I'm sure that will all work out just fine.
It took me way too long to get it done. I should have started this a long time ago. Can't believe I didn't do this sooner!
-Duane C/10 Club Texas member 1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project) 1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby) |
#531 |
Still Learning
Very nice work Duane! Looking good buddy. Keep up the good work. Hope to see some new pictures or video of the air setup in action.
#532 |
I'll try to get the wife to take a video. It's frigid here today though so I'm not sure how likely I'll be to convince her to get video this evening.
#533 |
![]() Join Date: Oct 2012
Nice clean install, I've been checking progress but haven't commented a lot. Looks awesome though.
#534 |
I will stop by to see it this weekend.
Great Progress.
Rincon |
#535 |
Well, here are a couple of pics from today...
![]() ![]() I left it at work tonight... ![]() ![]()
#536 | |
///Relaxed Atmosphere
71-Cheyenne Super (E.C.E Static Drop 4.5/7". Intro Rally's 20X8.5 5" B.S 255/35/20 (F) 20X10 5.25 B.S 275/35/20 (R) 87-Silverado Static Drop 5/7" Raceline Explosion 5 22X8.5 (F) 22X10 (R) hector _________________________________ 1971 Chevrolet Cheyenne Super 1987 Chevrolet Silverado 2006 Ford Mustang GT 2012 Toyota 4-Runner 2014 Dodge Ram 1500 Sport Crew Cab |
#537 |
![]() Join Date: Nov 2010
Sucks
#538 | |
Yeah, tell me about it. That's not even the worst part. Read on... I did get it fixed today. Well I have a couple of new parts anyway. I replaced the starter and still had nothing. Since I never replaced the ignition switch with the one from the American Auto Wire kit, I thought that might be the culprit, so I ran home and grabbed the new switch, replaced it and still nothing... ![]() After some discussion with my dad on the phone, we thought about the neutral safety switch. Turns out, the shifter had moved a bit and was not allowing the neutral safety switch to send the start signal through to the starter. This might have been the problem from the get go. ![]() I now have a new starter and ignition switch that I may not have needed in the first place. I still need to adjust the neutral safety switch a bit, but it works again. ![]()
#539 |
Its home now!
-Duane C/10 Club Texas member 1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project) 1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby) Last edited by knomadd; 07-13-2017 at 05:14 PM. |
#540 |
truck looks damn good laying down. You need to come by and see the truck, cold beer in the fridge!
#541 |
![]() Join Date: Jul 2012
Glad you were able to fix your truck. Man, it looks really good there!
#542 |
When it's something like the shifter just moving outta place at some point after being really pissed off you just gotta sit back and laugh your ass off.
#543 |
![]() Join Date: Oct 2013
Glad you got it home and have a good idea what the culprit is.
- Robbie UNITED BY TRUCKS - classic truck video content YouTube: www.youtube.com/c/unitedbytrucks Instagram: @united_by_trucks Paw Paw '68 508 Dark Blue Custom C10 Teddy '68 GMC SWB 503 Light Green LS Build Mississippi Mud '75 Skyline Blue Patina SBC Build |
#544 | |||
![]() Me too. I'm also glad it's something pretty easy to fix. I was afraid for a little bit that I was going to need to solve a wiring issue. Glad it wasn't that!
#545 |
Got new billet light and wiper knobs installed. These are some nice pieces made by a board member. I got lucky and got the last set he plans on making.
#546 |
I also took a couple pics with the Christmas lights at night. Sorry, all I had was my crappy cell phone. This is "enhanced" from photobucket. Best I could do.
![]() original pic ![]() Parking lights off... Enhanced ![]() Original ![]()
-Duane C/10 Club Texas member 1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project) 1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby) Last edited by knomadd; 07-13-2017 at 05:15 PM. |
#547 |
Got the cowl hood painted and on the truck!
![]() ![]() It makes the rest of the truck look bad though. ![]() Now I need to get started on panel alignment, and bodywork so I can get the rest of the truck painted.
-Duane C/10 Club Texas member 1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project) 1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby) Last edited by knomadd; 07-13-2017 at 05:16 PM. |
#548 |
Wow .... that looks really good man. It gives it a tough look.
-Mike 1970 C10 Stepside 350/700r4 Build: http://67-72chevytrucks.com/vboard/s...d.php?t=632707 |
#549 |
ooohhhh shiny!!!!
#550 |
![]() Join Date: Dec 2006
New hood looks great! I've always been a fan of cowl hoods.
Keith 66 Suburban Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361 IG: bennett68c10 |
