01-10-2013, 02:23 PM | #526 |
Re: Slosh Tubz new company project "Square Peg" frame laying 1987 GMC Jimmy
I see your bringing up the "GOLD" controversy again.
72 Blazer 69 Stepper (sold) 72 Burb |
01-10-2013, 02:27 PM | #527 |
A guy with a truck
Baller!
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
01-10-2013, 02:36 PM | #528 |
Ha No, seriously that ***** rocks
01-10-2013, 02:40 PM | #529 |
67cheby
LOL.....guess i wont be needing any SLOSH TUBZ for this one !
01-10-2013, 02:40 PM | #530 |
67cheby
LOL....luv me some GOLD !
01-10-2013, 02:49 PM | #531 |
Moderator
Here we go! My lips are sealed this time I promise! All I'm gonna say is I bet that truck comes with free Alize and Black & Milds.
'20 Silverado Trail Boss ~ '17 Tahoe ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '71 Cheyenne swb ~ '55 Pontiac Safari ~'50 3100 bagged ~ '80 Wife ~ Late model kids
01-10-2013, 02:50 PM | #532 |
67cheby
lol......
01-10-2013, 03:13 PM | #533 |
I am away from this thread for a few days and THIS is what happens?!???
01-10-2013, 03:16 PM | #534 |
wow....
my build threads '86 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415628 '67 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=635078 '63 GMC http://67-72chevytrucks.com/vboard/s...d.php?t=674682 |
01-10-2013, 03:37 PM | #535 |
01-10-2013, 03:55 PM | #536 |
67cheby
i told you , you needed to check on your thread ! BLING, BLING....
01-11-2013, 04:03 AM | #537 |
The conversation alone on Square peg is enough to make it the thread of the year so far
Project NewType 1972 Chevy C/10 Cheyenne Super ( Daily Driven Showtruck ) http://67-72chevytrucks.com/vboard/s...d.php?t=507903 Project Great Grandpa's Legacy 1973 Chevy C/10 Cheyenne ( Current daily driver collecting big time parts ) http://67-72chevytrucks.com/vboard/s...89#post7084289 - Dylan (209)-985-7721 |
01-11-2013, 10:05 AM | #538 |
67cheby
LOL, thanks man !
01-11-2013, 10:08 AM | #539 |
67cheby
one of Chip's friends has access to a water jet and he cut out our paper pattern to a galvanized pattern for us to test fit and make any changes.....we are changing it just a little , here is a couple pics
01-11-2013, 10:13 AM | #540 |
67cheby
on another note, i am looking at hood hinge plans and i am considering just modifying the factory cowl mounted part and welding the top of the earlier style hinge to this one to make it bolt to the early hood ? I think that should work and i also think that this would be a pretty simple way to solve the earlier truck hood hinge problem , couldnt you just cut this hole in the early cowl for this hinge to sink into and bolt it on ? (with some reinforcement ?)
01-11-2013, 10:20 AM | #541 |
67-72 parts collector,…
Is your notch wide enough to incorporate exhaust, bag mounts and shock mounts?
Looks tiny to me.
01-11-2013, 10:32 AM | #542 |
67cheby
i am trying to keep everything as tight as possible to save all of the cabin room i can, the notch is 3 and 3/4 inches wide, the rear bag and shock mounts will probably hang off the back a little
01-11-2013, 10:33 AM | #543 |
Happy to be here
I agree. Its too narrow, and too tall. You dont need that much notch unless your planning on dragging frame with 24's.
01-11-2013, 10:53 AM | #544 |
67cheby
i am going to go back and re-look at all this the height is probably going to stay the same according to my calculations i will have 1 1/2 left which i plan on build and adjustable bump stop to add to that area to keep it from laying out if something happens when my wife is driving it ...since it is hers ! I hadnt thought much about making it wider but with your guys input i think i might add an 1 1/2 to it to make sure i have room for my bag and shock mounts ! Thats why i put stuff up here, thanks guys for your input !
01-11-2013, 10:54 AM | #545 |
67cheby
my plan is 22x12's but i want a decent sized sidewall on them, and i am doing the Stock floor body drop
01-11-2013, 10:59 AM | #546 |
Going to have to keep watch on this project!
01-11-2013, 11:06 AM | #547 |
Must be nice to know someone with a water jet!
01-11-2013, 11:06 AM | #548 |
Since your Scotts stuff has the 4-link bars inboard,... I would mock it up first prior to making the notch.
Keep the 4-link bars parallel to the ground at ride height is going to be a small issue. (with that much kick to the frame, in front of the axle). Your front 4-link mount may be up in the floor, depending on where your ride height is set. And that depends on where full dump is to lay flat with your tires. With the 4-link tacked in place, you will easily be able to see where the cross bars need to be for the bag mounts and shock mounts. This will dictate where the sides of the notch need to be. You also need added height for the center section of the rearend.
01-11-2013, 11:13 AM | #549 |
See how the front 4-link mounts are straight out in front of the axle tube when they are parallel with the ground?
You might have to fab some new rear 4-link axle mounts with some height built into them to allow you to lower the front mounts.
01-11-2013, 11:13 AM | #550 | |
67cheby
thanks man
LOL, actually i know Chip and Chip knows Nathaniel ! LOL Quote:
