#5501 |
![]() Join Date: Feb 2002
Re: What did you do to your truck today.The 3rd chapter
And I've used the plastic split tube looms. Use what you got.
#5502 |
Ram-A-Lam-A-Ding-Dong
![]() Join Date: Jan 2013
#5503 |
Had to remove the washer fluid reservoir to finish the vacuum pump install on my 68 and found a key zip tied to the mount . Looks to be an original GM key . I left it there its been there so long no need to move it . And if I lose a key I know where to look .
#5504 | |
Have you tried it to be sure it unlocks the door or fits the Ignition? |
#5505 |
![]() Join Date: Jul 2000
My truck has been without a spare tire for 15 years or more. Got a new tire a few weeks ago, so I'm working to make the carrier as secure as possible. Also rounded up a bottle jack, lug wrench, and a small 4x4 to keep behind the seat. Gotta make sure I can get the wheels off the ground before I'm good to go.
Mike 1969 Custom/10 LWB -- owned for 37 years. 350/TH350, 3.08 posi, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. Hedman stainless headers. Old Air installation in progress. 1982 Custom Deluxe 10 SWB -- converted from 250-six to roller cam 350 w/ Vortec heads -- sold 1981 C10 Silverado LWB, 305, TH350C -- sold, but wish I still had it! 1969 C10 (not the current one) which I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 26 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! |
#5506 |
Didnt even move it . But maybe I should check to see if it works .
#5507 |
70+ ( Old Skool Club )
![]() Join Date: Nov 2003
Got some pics now. So I posted a pic of me installing the AAW Headlite Relay Harness in my 72 a few weeks ago. I thought I may have to cut/trim the headlite buckets to get the LED Headlites installed but they fit perfect. Got em installed and aimed properly and they work great for me. I get lots of clear white light and no one flashing their high beams at me.
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " In the end, we only regret the chances we didnt take " " Time is the only currency we spend without knowing the balance, use it wisely ." .. |
#5508 | |
#5509 |
![]() ![]() Join Date: Jan 2005
Had a reproduction chrome dome light in my truck for the last few years, but the lens made a buzzing noise from road vibrations. Got tired of listening to it, so I replaced it with a NOS unit.
#5510 |
Besides the carb rebuild, I’m doing a general tune up. I replaced the distributor cap, rotor, points and the spark plugs. Two of the plugs don’t look good. It’s the original 350 in the truck with 76k miles. I’m going to recheck the timing and run it for a bit and check the plugs to see if cylinders 1 and 2 still look bad. The plugs are R45ts and that’s what I’m replacing them with. I believe initial timing was 8 degrees at idle. I don’t know want total timing is, I never checked it since owning the truck, 8 years now. It ran well so I felt no need to mess with anything. Dwell last time I checked 1k miles ago was 29.5.
#5511 |
Finally dove into the pinion seal on my 72 LWB. Had to remove the carrier bearing mount bolts to get the room to get the u joints out of the yoke.
Once everything was marked, I noticed the old pinion seal had a 1/4" gap...no wonder it was leaking. The OG nut was also HAND TIGHT...like finger tight. The seal puller was better served as a seal destroyer but got it out. New one tapped on and snugged up. I marked the nut before removal and turned it one extra revolution which felt barely snug but too tight is bad I presume. Back together and no more leak! No whining or odd sounds out of the rear end. |
#5512 |
#5513 |
picked up a new windshield today from market place, just 9 miles from home, sweet.
LIL ERV the 50-3600 396 BBC stroked to 415 cid Richmond 6spd over drive C4 rear Porter built a arms Never give the Devil a ride,because he'll want to Drive! |
#5514 |
I finally finished taking my truck a part and started moving in the other direction. Shouldn't be long now LOL
#5515 |
![]() Join Date: Mar 2011
.....been there done that X2......do you have a build thread?
Grand Theft Auto https://67-72chevytrucks.com/vboard/...d.php?t=855961 Doc & Kim build http://67-72chevytrucks.com/vboard/s...d.php?t=722288 I am from the desert http://67-72chevytrucks.com/vboard/s...d.php?t=650332 basket case build SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=648557 |
#5516 |
I thought about it but I'm terrible with doing updates. I did take plenty of pics before disassembly. Looks to me like the truck was "refreshed" in the 90's with a homemade lift kit with plenty of other sins from a PO. Luckily I don't think the drivetrain was played with. The 305E's serial number is on the POP. The SM465 and T221 seemed to be undisturbed. It took me a few years to find SWB K10 and when I found this rust bucket I fell in love.
#5517 | |
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. ![]() RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
#5518 |
Designed this little fluorescent red decal to restore the color of the hot band on the temperature gauge.
#5519 |
BlahBlahBlah
That’s a good fix. Those cutting machines sure come in handy
#5520 |
#5521 |
accidental double post. Please remove.
#5522 |
My backup flash drive failed and I lost all my photos, including all of my build photos, except the most recent ones and the ones I've posted online. I'm so bummed! Here's my steering wheel I refinished over the weekend. I used silver leaf on the spokes and then antiqued it to let the red show through underneath. I'm going to use the same treatment on the gauge bezel chrome trim, the double din radio bezel (going to install a double din cd radio with backup camera), and on the glove box door. I'm going to do a custom painting on the glove box. The abstract light blue shapes on the door are the original body color which I will paint with my new frost blue body color, and the original painting will go in the light grey negative areas. I use that same fragmentation and disintegration in my oil paintings to convey change and the passage of time, so it tracks, especially on a vintage truck. I'm going for a mix of old and new, so basically a resto mod. You can also see the transfer case lever I got from a 1990 Suburban, which is the running gear I'm using in general.
#5523 |
This photo shows the brand new old stock 1990 vintage tbi throttle body I got off ebay. It had been sitting on a shelf for decades in the box. Score! My old one had a wobbly throttle shaft and was causing a major vacuum leak.
#5524 |
Finally got my steel wheels back from powdercoat last week, got them mounted last weekend, and got a nice set of blue dog dish caps in today from eBay.
Vince 1970 Chevy C20 350/SM465 1967 Chevy C10 283/3OTT (sold) |
#5525 |
| Bookmarks |
