06-26-2017, 12:40 PM | #5526 |
Old member
Re: What did you do to your truck today? Chapter II
Thanks man!
They are easy to install. They come with a small hole saw bit to mount them. Here are the ones I got. http://www.ebay.com/itm/2x-LED-Car-D...53.m2749.l2649
06-26-2017, 12:44 PM | #5527 |
I will have to consider that soon once I get some medical issues out of the way ,thanks for the info ,you are always great about sharing your projects .
Thanks John |
06-26-2017, 06:11 PM | #5528 |
Whew. I missed this last line & was worried that you might have used that flapper wheel or some other grinder to dig down to the layer of white. The thin white line looks good. You could go with a red line too.
1969 GMC 2500. 250 I6, 4-speed w/ granny low |
06-26-2017, 08:45 PM | #5529 |
I did some trimming on the front coils to get the rake I like so much.
http://67-72chevytrucks.com/vboard/s...d.php?t=698292 |
06-26-2017, 08:50 PM | #5530 |
I ziptied a USA-1 plate to the grille (not bolted on but in place) and painted the front bumper white to match the top and rear bumper.
06-26-2017, 09:47 PM | #5531 |
I pulled a set of electric fans out of a 04 Monte Carlo and with some minor fab work and two temperature controls I got them in today. I set one fan to come on at 180 and the other at 200. I drove it around in traffic this afternoon when it was about 85 outside and the truck never broke 210 degrees.
06-27-2017, 09:33 PM | #5532 |
I love those ol school rakes. Looks great.
MyToys: Goldilocks the "Ol School Survivor" 1968 C10, SWB Stepside, 08/15 TOTM, 250 CI 6 cylinder, 3 on the tree, 3.73 rear, 3/5 static drop, 23,500 original miles. Samson the 1970 CST10, LWB, 462Ci, Turbo 350 tranny, 3.08 rear gear, PB, PS, A/C, AM/FM, 2/4 Drop. Brutus the 1998 Camaro Z28, 33,500 original miles, LS1, 519 RWHP/497 RWTQ. Member of the Louisiana Classic Truck Club, LCTC Member of the Louisiana C10 Club Member of the Baton Rouge Drifters Car Club |
06-27-2017, 09:47 PM | #5533 |
06-28-2017, 06:31 AM | #5534 | |
Old member
06-28-2017, 10:22 AM | #5535 |
Thanks for the tip, I'll definitely look into that.
06-28-2017, 04:35 PM | #5536 |
I went to Brothers Truck Show last Sunday
Glenn 1960 Burro Corvair/VW Buggy - Factory made in Santa Ana, Ca 1929 Ford Model A Roadster - traditional pre-war banger hot rod |
06-28-2017, 05:02 PM | #5537 |
70+ ( Old Skool Club )
Removed my alternator and took to our local Starter/Alternator rebuild shop. Its a 37amp and the owner tells me he can make it a 55 amp which will be good for my purposes. Another item off the checklist before I do the Power Tour in 2019..
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
06-28-2017, 06:13 PM | #5538 |
Old member
I have done 3 HRPT in my C10. I hope to make my 4th in the 64 SS Impala next year.
06-28-2017, 09:21 PM | #5539 |
I thought you were goona ay you want to do it in with the ramp truck
06-29-2017, 08:43 PM | #5540 |
installed a new tach cluster. installed new headliner. kind of mocked up rest of interior to see how it looks.trying to decide on whether to go with the white or black. still trying to decide on what color to paint truck
06-30-2017, 12:26 PM | #5541 |
Yesterday, installed a thermostatic fan controller. Works Great!
Azle |
06-30-2017, 03:37 PM | #5542 |
Big Block
Put in my new carport.
06-30-2017, 04:31 PM | #5543 |
Not today, but the other day I replaced the "stock" carb mounting gasket on my 402 with a 1/4" thick insulator gasket, and now the fuel does not boil out of my Edelbrock carb after it sits for more than 10 minutes while hot. Hard to believe such a small thing could make such a huge difference. I am running the stock cast iron intake with a 1" aluminum spacer/adapter. If you have an Edelbrock carb and have this issue, get an insulator gasket and your problem will be solved. I used Fel-Pro p/n 1908.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast" 200,000 Mile Club Disc Brake Club Owner installed options: Front Sway Bar Power Steering Power Brakes Cigar Lighter Courtesy Lights Deluxe Side Markers Wiper Delay Power windows Power Locks Sniper EFI 2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear |
06-30-2017, 05:06 PM | #5544 |
The previous owner had the center link on backwards, and the tie rods had seen better days. So, got all the old stuff removed and got the center link off. Now to put it back together the right way with new parts tomorrow. Should handle a little better once done...
07-01-2017, 12:03 AM | #5545 |
I finally finished the new wood floor in the truck this week!
Now I just need tho work on a new "rest of the truck"... |
07-01-2017, 11:06 AM | #5546 |
After searching Ebay, I found that dually caps had logos with a black background. I didn't like that as much as I liked the silver back of the caps I already had. So, I joined everyone else & got spacers.
07-01-2017, 01:40 PM | #5547 |
Went to a Saturday get together at garage one pro shop in Tampa. Met a fellow 67-72chevytrucks.com guy in his awesome Blazer. On the way home passed this awesome back drop and had to take some photos.
07-01-2017, 01:56 PM | #5548 |
@ syfygi : yes these were very common military trucks when new .
lots and lots of good works here ! . me, i badly crashed my moto monday and have been in he hospital all week . still dreaming and planning to finish and drive/work/enjoy my truck though .
-Nate Geezer '49 3100 235 W/ Muncie SM420 SOLD '69 C/10 shortbed sidemount survivor 250 L6 W/ 350TH |
07-04-2017, 02:45 PM | #5549 |
I bought a transfer case shift boot from Custom/10 last August, and finally got around to installing it today. I cleaned and painted both rings, and ran the screws under the wire wheel. For vintage hardware they cleaned up pretty good and have no rust on them. My F*rd had rusting hardware before it left the lot in 2008.
Also installed a new firewall wire gutter. I will start installing new front leaf springs next weekend. |
07-04-2017, 04:29 PM | #5550 |
Was in Melba Idaho 4th of July Parade
1968 4x4 Frame, with a 67 Cab and Bed A Shorter Step 1999 Dodge 2500 Cummins Diesel |
