#5576 |
Re: What did you do to your truck today? Chapter II
#5577 | |
Good luck on the build, Derek |
#5578 |
![]() Join Date: Nov 2014
Got painted yesterday morning. Getting color sanded, cut and buffed, then assembled early next week.
07' Extcab Silverado Z71 Silver Birch, 5.3L HO 71' Cheyenne C10 Hugger Orange on Saddle SWB Besides these two, too Many to count |
#5579 |
![]() Join Date: Feb 2011
'68 Chevy....looks great...gonna need to see more pics of this one!!
![]() '05 RCSB Sierra 2WD '71 Sierra 2WD Longbed '98 Silverado K1500 Xcab...sold '72 Highlander"Raymond"...sold |
#5580 |
![]() Join Date: Aug 2015
I have been busy the last few days. Finished installing my new front springs. Someone had used blocks in the front to raise it 1.5 inches so I needed to get rid of them. Went with Tuff Country EZ-Ride 2”lift. Changed the fluid in my front differential and painted the cover. Did a driveway alignment using a method I read about in Skinned Knuckles. I had tried doing one last year with string, but it obviously didn’t work out so well because I found that toe was out 1/2 inch!!
I am a long way from replacing sheet metal so I riveted in a patch to cover a hole in my floor to get it ready for state inspection. Also painted my front emblem. I hope to get it inspected next week! |
#5581 |
Nothing exciting, just filed title paperwork.
Jake |
#5582 |
Looked at it, thinking I should do something
#5583 |
![]() Join Date: Feb 2009
Pulled the exhaust and probably won't use any of it. Though I'm hoping for a rear hanger, just in case
![]() Looks great SoCoC10
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 07-16-2017 at 12:14 AM. |
#5584 |
Put in new bed wood. I used pressure treated southern yellow pine boards. I had a hard time finding boards that were wide enough. Had to by 1 x 10 x 16' boards from a dock supply place. Painted both sides with POR15 and finished the tops with Rustoleum Hunter Green. I used the dimensions from the GMC Paul website, and the boards don't seem wide enough. the gaps between them are very wide. Looks good though, definitely better than it was before. I used gloss paint, probably should have gone with Satin.
Still have to bolt down the bed, and tighten up the 4553 bolts that are in it. ![]()
71 Chevy C10 Shortbed Stepside. LT1 with 4l60E. Just got back from painter, in assembly now. Last edited by FL71C10; 07-15-2017 at 11:20 PM. |
#5585 |
The gaps are supposed to be very wide so the wood can swell in the rain.....
Look nice to me in green .
-Nate Geezer '49 3100 235 W/ Muncie SM420 SOLD '69 C/10 shortbed sidemount survivor 250 L6 W/ 350TH ![]() |
#5586 |
New steering column bearings. Lower one was fragmented. So smooth now.
1969 c-10 Step Side Long Bed. I-6 250cid = ![]() |
#5587 |
Moderator
![]() Join Date: Jun 2017
Spent the day angle lifting the bed on my daily driver...
2006 Silverado,,,new fuel pump, charcoal canister and fuel vent valve system... Could not believe the amount of CRUD on top of the fuel pump unit....what genius decided to put the pump there???? Removed the four drivers side bolts, loosened the four passenger bolts, tailgate off, drivers side tail lamp wire plug and used my gantry lift to lift the drivers die of the bed up about 18 inches...wood blocks as safety pins... Needed to replace the metal frame the charcoal canister sits in...GM wants $ 118...for a piece of sheet metal...yeah right.... 30 minutes with the sheet brake and its as good as new...painted it up with Bed Liner...Sweet... Now back to working on my 67 long bed...a real truck... ![]() ![]() ![]() |
#5588 |
Old member
Actually it was yesterday!
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
#5589 | |
#5590 |
Maybe I'll try that, thanks.
71 Chevy C10 Shortbed Stepside. LT1 with 4l60E. Just got back from painter, in assembly now. |
#5591 |
Pulled the front drive shaft and replaced the front axle pinion seal. Removed the u-joints from the drive shaft. Tomorrow after work shall be clean, reassembly and reinstallation.
Thanks to GM that the high hump is bolted in. Removing that made it a LOT easier to get at the bolts attaching the driveshaft to the transfer case yoke. Certainly easier than dropping the crossmember.
72 K2500 Sierra Longbed Wideside 350/TH350/NP205 66 Plymouth Barracuda 225 Slant6 |
#5592 |
![]() Join Date: Dec 1999
Getting Closer!
Smitty '71 Short Fleetside Spring Valley, Ca. |
#5593 |
A couple more! Richard doing the body and paint with my brother Dale's help. Looking real good.
#5594 |
Took mine camping last weekend, think she liked it.
#5595 |
If I may ask. What is reason for painting wood with POR15?
#5596 |
Did you tow that big camper with that truck? I'm curious to hear how well that rig goes down the road.
Meet "Old Roy": http://67-72chevytrucks.com/vboard/s...d.php?t=707801 |
#5597 |
![]() Join Date: Jul 2015
#5598 |
No the campground is close to home so I brought the firewood out in the old truck but I think I may install a hitch and brake controller and give it a shot sometime. I think it would do ok but that would be with careful driving and the load leveller setup properly and I'm good at getting things adjusted right so for me it may work but I do think it pushes the limit on the truck as it was designed but I don't go more than 45 miles from home and not in a hurry so that helps too.
#5599 |
![]() Got the suspension stuff gathered up for powder coating. Hopefully I can find someone to do it for me reasonable. |
#5600 |
Mar-k did a study on what finishes held up best over several years. The boards that were painted with POR15 and topcoated with regular paint were the only ones that didn't have any damage at all. That's where I got the idea.
