Old 02-12-2026, 07:32 PM   #5651
brandnew72
Re: What did you do to your truck today.The 3rd chapter
Not a C10, but semi fab-ish/repair work. My mom's 2000 Avalon has some issues, this front Catalytic converter being one. When I went to remove it, the rear manifold looked like this.....
And drilled out the busted bolts and fixed the flange using some 3/8 ID copper tubing to keep the hole from filling with weld. New parts coming this week.
brandnew72 is offline   Reply With Quote
Old 02-12-2026, 11:27 PM   #5652
zicc1835
zicc1835's Avatar
Originally Posted by rust_never_sleeps View Post
i didn't want to discourage the less gifted
lol
zicc1835 is offline   Reply With Quote
Old 02-13-2026, 12:06 AM   #5653
Rust_never_sleeps
Rust_never_sleeps's Avatar
My fab skills are only equalled by my Quadrajunk tuning abilities and my Pulitzer-worthy photography
Look upon my works ye mighty, and despair!
1970 C10 Custom longbed 350/350
“Carburetors are forgiving, timing is not” — Thunderhead289
Rust_never_sleeps is offline   Reply With Quote
Old 02-13-2026, 04:01 AM   #5654
3757chevy
3757chevy's Avatar
I got the doors completed and one installed. Dog noticed the change.
'67 Stepside (bought 1997-sold 2021-partially bought back 2024) '96 Bronco Eddie Bauer (inherited 2010)
MIKE
3757chevy is offline   Reply With Quote
Old 02-15-2026, 09:17 PM   #5655
zicc1835
zicc1835's Avatar
cleaned it up installed new water pump... next new thermostat was 160 going to 190
Old 02-18-2026, 03:56 PM   #5656
Cooter!
The stock rear needed an axle bearing... escalated quickly:/
Cooter! is offline   Reply With Quote
Old 02-18-2026, 03:58 PM   #5657
Cooter!
1157's just aren't bright enough today on the road with everyone and their laser blinders on high But I never like the look of the dots that LED lights have so I fitted some diffuser panels in the lens and I think they turned out great!
The pic has a hot spot in it, but they really are just a smooth solid block of light, fronts are next!
Old 02-18-2026, 10:37 PM   #5658
zicc1835
zicc1835's Avatar
nice work
Old 02-19-2026, 09:19 AM   #5659
HO455
HO455's Avatar
They look good! Show us how you did the diffusers.
RIP Bob Parks.
Old 02-19-2026, 08:31 PM   #5660
zicc1835
zicc1835's Avatar
Originally Posted by ho455 View Post
they look good! Show us how you did the diffusers.
x2
Old 02-22-2026, 10:47 AM   #5661
Furno68C20
Today I installed a couple shims behind my newly installed water pump pulley. After smelling burnt rubber and breaking a belt I looked closer to the accessory belt alignment. The cooling fins on the alternator were touching the bet.
If you’re changing out a water pump, pay attention to the water pump shaft length. Aftermarket parts press the shaft in at different lengths.
Here are the shims I used.
Furno68C20 is offline   Reply With Quote
Old 02-24-2026, 01:55 PM   #5662
trapdoor2
trapdoor2's Avatar
Just a little update, I haven't been here on the forum in a while.
The C10 has been in storage for a while but last month we finally found a good local speed shop and had her rollbacked off for reinstatement, updates and rework.
The job: update distributor to HEI. Update brakes to power discs on all 4 corners. Install 3:53 diff and posi. Install 2" hitch. Modernize A/C. Install upgrade headlight harness with relays, etc. New 15" steering wheel. New "orignal look" instrument panel, added tach.
What happened: all of the above + new wiring harness in cab (found shade-tree household wiring, duct-tape repairs and a general mess). New wiring aft of cab, same issues...+ added hitch wiring. New Holley carb...the original had worn shafts, linkages, etc. New shoes (radial T/As again).
Miz Diane is just back from her test drive in the picture. It's her truck...she just lets me drive it.
===Marc
'69 Chevy C-10 CST/10 396 LWB, auto, air, PS, PB.
'31 Ford Model A Deluxe Coupe...bone stock.
trapdoor2 is offline   Reply With Quote
Old 02-25-2026, 10:26 PM   #5663
Rust_never_sleeps
I went to make a quick adjustment on the air door before a test drive....and ended up taking the air horn off, replacing the tension spring, dropping the secondary rod off the bracket(which seems impossible), then popping it off again to spear the internal lever with the choke shaft
No test drive,
I should probably stake the internal lever onto the choke rod. One less PITA
Old 02-25-2026, 11:21 PM   #5664
'68OrangeSunshine
'68OrangeSunshine's Avatar
No test drive,
I hope you're talking about a carburetor.
Old 02-25-2026, 11:48 PM   #5665
Rust_never_sleeps
If you don't hear from me for a few years, you'll know why
Old 02-26-2026, 02:20 PM   #5666
ohboy321
ohboy321's Avatar
Today I decided to start the process of reupholstering and repairing my seat. I bought a new cover from Ricks Custom Upholstery 2 years ago, and CUSTOM/10 supplied a seat with the springs I need to replace 4 broken ones.
Steve/NH
1967 K10 327 Short Bed Stepside
ohboy321 is offline   Reply With Quote
Old 02-28-2026, 08:24 PM   #5667
Rust_never_sleeps
Took advantage of a sunny day to poke into the wiper electrics and determined the motor is bad
A real PITA for a big guy with big hands to get in there, wish I had done this when I replaced the ducts and had easier access
Old 02-28-2026, 08:45 PM   #5668
Casper42
Casper42's Avatar
took off the 54 year old bumper and sent to the shop for replating
'72 C10 Cheyenne SWB North Carolina kept for 50 years, 75k original miles, Medium/Hawaiian Blue paint, 3 owners - one for 40 years & garaged kept. Original: sheetmetal, undercarriage, moldings, glass, immaculate unrestored bed.
New - rebuilt engine at 65k in 2015, one frame-on respray in 2010, front bumper, blue houndstooth seat, carpet, 8 inch rally wheels on 275-60R-15, LED lighting. - Semper Paratus!
Casper42 is offline   Reply With Quote
Old 02-28-2026, 08:51 PM   #5669
Casper42
Casper42's Avatar
yup! the aftermarket LED's look reallllyyyyy cheap. I cringe everytime I see them on a truck. I was able to find really good LED 1157 equivalent bulbs that are brighter, great performance and still carry the OEM look. I've been using these for about 2 years.
https://www.amazon.com/Alopee-Extrem..._0_1_ec_t&th=1
Old 03-01-2026, 10:48 AM   #5670
72c20customcamper
72c20customcamper's Avatar
Very nice setup
Mark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
Old 03-01-2026, 10:09 PM   #5671
zicc1835
zicc1835's Avatar
bedsides came out of my attic today ..purchased SWB fleet side entire bed parts in 2016 a decade ago hard to believe been tucked away that long
Old 03-01-2026, 10:13 PM   #5672
wpsharpshooter
wpsharpshooter's Avatar
Crazy how time flies right... Mines been going on for 4 years now
wpsharpshooter is offline   Reply With Quote
Old 03-01-2026, 10:19 PM   #5673
zicc1835
zicc1835's Avatar
I put this one on hold for 2 years to finish my step side ...so 6 years ...I hope to be driving it mid summer
Old 03-02-2026, 08:46 PM   #5674
'68OrangeSunshine
Probably better quality than you can get today.
Old 03-02-2026, 10:13 PM   #5675
zicc1835
zicc1835's Avatar
took measurements from where the cab ends up past the cab mount and the bed side starts drilled through the frame for the positive cable and used a PCV valve cover grommet to protect it ...battery box installed..... finally
