08-19-2017, 08:14 AM | #5701 |
Re: What did you do to your truck today? Chapter II
Yep...I didn't see the depth of roller. I don't have that type on my year.
1970 C10 Short Stepper with 71/72 front clip. |
08-19-2017, 06:09 PM | #5702 |
Replaced both rubber fuel lines on my 67 chasing a vapor lock issue. The one from the frame to the pump I know had been replaced when I did the pump. The one from the tank to the frame... Original 1967, complete with undercoating and spring type fasteners. Here's to hoping...
Justin '67 C20 CST Custom Camper '04.5 LLY Duramax CCSB...sold |
08-19-2017, 06:35 PM | #5703 |
I replaced the tail/stop lamps in my 68. They were some a friend gave me, LED style, Chinese made. I got home from the local cruise in at about dusk last night and decided to walk around the truck to check the tail lights before putting it in the garage. And to my surprise I had no tail lights! I knew I had power back there as I had a license light. So this morning I pulled out two new 1157s and we're back in business. The LED lamps had come loose in the sockets. Both of 'em, go figure.
Phil "Money is only a tool to create and achieve what you want most in life" PayPal: rodnrudy@comcast.net |
08-19-2017, 09:30 PM | #5704 |
Big Block
Installed courtesy lights. Simple up grade that makes a huge improvement to lighting in your cab. Thanks to Board member Roger Koop. Check out his wiring harness on the parts board.
08-19-2017, 10:29 PM | #5705 |
http://67-72chevytrucks.com/vboard/a...1&d=1503196081
My new functional air cleaner.. wanted something a bit different |
08-19-2017, 11:12 PM | #5706 | |
Big Block
08-20-2017, 07:31 PM | #5707 |
08-20-2017, 08:01 PM | #5708 | |
Greg
________________ 1970 GMC Sierra Grande, 2500 133" wb, 402, 4spd. 2007 GMC 3500 SRW 4x4, Crew cab, Duramax/Allison. (Sold} 1987 Chevy Suburban 2500, Silverado, 2wd, 454, t-400 2023 Chevy Silverado LT 3500, crew cab, longbox, 4x4 Z-71 Duramax. |
08-21-2017, 07:19 AM | #5709 |
08-21-2017, 09:30 AM | #5710 |
70+ ( Old Skool Club )
Put a 211 LED bulb ( in your under dash lights too ) in your interior dome light and it'll be like daylight when you open a door at night.
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
08-21-2017, 10:42 AM | #5711 |
Big Block
08-21-2017, 12:25 PM | #5712 |
added a 1 inch spacer under my carb chasing a hot start issue, installed a daytime running light kit, and installed jute padding on my firewall. What a job that last one is, I should have done that first instead of last.
08-21-2017, 01:40 PM | #5713 |
Big Block
Where did you order the jute padding for your firewall? Did you get pre cut? If you did how well did it fit? Thanks
08-21-2017, 06:30 PM | #5714 |
Think I fixed the vapor lock issue, so I gave her a much needed bath.
08-21-2017, 08:25 PM | #5715 |
laying low
flip.
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
08-21-2017, 09:30 PM | #5716 |
Thanks Boog!
Justin '67 C20 CST Custom Camper '04.5 LLY Duramax CCSB...sold Last edited by Orange67; 08-21-2017 at 09:31 PM. Reason: Stupid auto correct. |
08-21-2017, 09:52 PM | #5717 |
error please delete
08-21-2017, 09:54 PM | #5718 | |
Got them from repops. Got the left firewall, center, and righ side firewall, they all fit extremely well, only had to tear apart half the dash to get them installed. Hardest part though was inserting the plastic plugs into the firewall holes. All precut. |
08-22-2017, 08:03 AM | #5719 |
Big Block
Thanks for the information. Getting ready for this project.
08-22-2017, 11:57 AM | #5720 | |
1969 GMC 2500. 250 I6, 4-speed w/ granny low |
08-25-2017, 03:46 PM | #5721 |
I'm a day late but it shouldn't matter. 2 days ago I installed the Classic Gauge and Cluster (Member TBONE1964) voltage gauge replacing the original ammeter gauge. Yesterday I swapped out the original 7/8 inch front sway with its tired bushings for a 1 /1/4 bar from a 1985 C30 truck and Energy Suspensions Polyurethane bushing. I should have taken before and aft pics of the sway bars but forgot.
08-25-2017, 03:56 PM | #5722 | |
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop |
08-25-2017, 03:58 PM | #5723 |
This morning I changed my trans filter and pan gasket to fix some leakage
08-26-2017, 03:06 PM | #5724 |
Picked up some honda civic door opening sills.$20 They are the perfect length. Will paint the gray area to match the interior i go with. Couldn't find black. Also saw what was left of this probably 68 in the yard.
08-26-2017, 04:49 PM | #5725 |
laying low
turnd
