Old 11-30-2010, 02:20 PM   #551
3r!c84
Badass
3r!c84's Avatar
Re: my 80 build
Looking good
Think outside the box?
-84c10 (1stcar)→My Build
-00 Saturn 5spd
drop a gear and disappear!
1/4:13:90
3r!c84 is offline   Reply With Quote
Old 11-30-2010, 04:59 PM   #552
v502
v502's Avatar
Re: my 80 build
Keep up good work Aaron. Its going very nicely.
v502 is offline   Reply With Quote
Old 11-30-2010, 11:30 PM   #553
flamingbig10
6.0 powered square
flamingbig10's Avatar
Re: my 80 build
thanks guys, I plan on having the motor buttoned up by next week and maybe I can get a core trans mission so I can mock every thing up and order some headers
Aaron
1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot
Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326
flamingbig10 is offline   Reply With Quote
Old 12-01-2010, 10:08 AM   #554
JohnC
JohnC's Avatar
Re: my 80 build
Making good progress....Keep plugging away at it.
JohnC is offline   Reply With Quote
Old 12-03-2010, 11:37 PM   #555
flamingbig10
6.0 powered square
Re: my 80 build
thanks john
got a little done today, but still need to torque the bolts, I planed on getting a junk 4l80e so I can mock up the motor But the trans shop my work does business said the 4l80s are stout and they haven't worked on many
Aaron
Old 12-07-2010, 09:34 AM   #556
flamingbig10
6.0 powered square
Re: my 80 build
well I got the camshaft retainer plate and sprocket torqued down, but I decided I'm going to get a new pump, and maybe I'll get it today and button up the bottom of the motor, timing cover, and possible valley cover, every part wheel get a new seal or o ring
Aaron
Old 12-07-2010, 11:41 PM   #557
flamingbig10
6.0 powered square
Re: my 80 build
I got the oil pump, wind-age tray, pick up tube, oil pan, timing cover, and valley cover installed and torqued down
Aaron
Old 12-09-2010, 12:29 AM   #558
flamingbig10
6.0 powered square
Re: my 80 build
I'm thinking about getting some dirty dingo motor mounts
Aaron
Old 12-10-2010, 09:39 AM   #559
flamingbig10
6.0 powered square
Re: my 80 build
this should be on there way
http://cgi.ebay.com/ebaymotors/ws/eB...m=180598301252
Aaron
Old 12-10-2010, 09:51 AM   #560
JohnC
JohnC's Avatar
Re: my 80 build
Looks good man!
Old 12-10-2010, 01:10 PM   #561
Puglia10
Re: my 80 build
can you run the factory LS ac with those?
1979 c30 3+3 dually
1946 GMC
Puglia10 is offline   Reply With Quote
Old 12-10-2010, 01:28 PM   #562
nbpro
Re: my 80 build
Looks sweet Aaron
nbpro is offline   Reply With Quote
Old 12-10-2010, 09:59 PM   #563
flamingbig10
6.0 powered square
Re: my 80 build
I'm not for sure but I won't be running a/c, the heat doesn't bother me just the cold does
thanks nbpro and John
Aaron
Old 12-15-2010, 01:01 AM   #564
flamingbig10
6.0 powered square
Re: my 80 build
got my dirty dingo mounts today they look great there even powder coated and might be getting a trans tomorrow from lkq
Aaron
Old 12-15-2010, 02:59 AM   #565
nbpro
Re: my 80 build
sweet man
Old 12-15-2010, 10:25 AM   #566
JohnC
JohnC's Avatar
Re: my 80 build
Nice!
Old 12-15-2010, 10:39 PM   #567
flamingbig10
6.0 powered square
Re: my 80 build
thanks guys called Larry at lkq and got the trans coming 4l80e with 107,000 and torque converter with 6 month warranty for 950
Aaron
Old 12-16-2010, 09:53 PM   #568
flamingbig10
6.0 powered square
Re: my 80 build
got the motor off the stand and bolted up the fly wheel
Aaron
Old 12-17-2010, 03:03 AM   #569
harnalien
TruckincrazY
harnalien's Avatar
Re: my 80 build
Did you get your motor through LKQ? Do they work with you on pricing or is it firm? That's where I'm thinking of getting mine from.
harnalien is offline   Reply With Quote
Old 12-18-2010, 08:55 PM   #570
flamingbig10
6.0 powered square
Re: my 80 build
I got it from bow auto in New Hampshire
well I got my transmission but the pan is full of metal so I'll send it back Monday and see what happens and also I have another problem my fly wheel has a 3 bolt pattern and the torque converter is a 6 bolt
Aaron
Old 12-18-2010, 09:59 PM   #571
Jonboy
Slots go on anything!
Re: my 80 build
950 sounds a little high for the 4l80E. If they don't come through, call Robert at RCS in Tyler. 1.800.259.4020. They deliver here daily.
1974 Jimmy- 5.3/4L80e/NP241
Old 12-18-2010, 10:36 PM   #572
flamingbig10
6.0 powered square
Re: my 80 build
I couldn't wait
Aaron
Old 12-18-2010, 10:39 PM   #573
flamingbig10
6.0 powered square
Re: my 80 build
it ended up be over 1200 with the core and taxes so, if I have any trouble sending trans back and getting one that doesn't have a pan full of metal I'll send it back and give them a call
Aaron
Old 12-19-2010, 02:19 AM   #574
flamingbig10
6.0 powered square
Re: my 80 build
well it looks like I need to get a fly wheel and spacer from a 6.0 that came with 4l80, then I need to get a arp crank pulley bolt and torque converter bolts, when I get another trans I'll check the pan if good then a new filter which I do have, degrease the trans and bolt it to up to the motor, mock up to the trans cross member and install the valve springs and bolt up the accessories
Aaron
Old 12-20-2010, 12:48 AM   #575
flamingbig10
6.0 powered square
Re: my 80 build
I yanked out the passenger side floor pan cover panel, and I going to replace it with a weld in floor pan, I ordered both sides from capt and also ordered a arp crank pulley bolt and torque converter bolts
Aaron
