Old 04-26-2013, 11:42 PM   #551
ryanroo
ryanroo's Avatar
Re: 72 k20 project
Ive done a bunch of stuff with a mig, and er70s2 is pretty decent filler for mild to cast too. i am always skeptical until i prove myself. still never had any parts come back cracked. i still prefer to use the heliarc if i dont use the nickel rod for a little better heat input and control. but i think these manifolds are pretty good castings, and that also helps.
72 K20 12v build
72 K20 "parts truck"
ryanroo is offline   Reply With Quote
Old 04-28-2013, 05:08 PM   #552
ryanroo
ryanroo's Avatar
Re: 72 k20 project
Nothing real exciting lately.
i decided to pull the backing plates off the dana 70 and put them on the 80. the 80 only had backing plates, nothing else when i bought it.
yanked the whole set up off, hauled it to the carwash and gave it a good washing. then painted the outsides black
new seals!
got to the other side and found that the bearings felt a little icky. decided to run a different hub i had laying around because this one was ugly. not real sure it would have mattered but hey, whats the use of spare parts anyhow.
back together. ill have to pull the wheel cylinders but i havent ordered them yet. hopefully i can do it without totally disassembling everything. i also need to order some new drums
today i crossed over.
72 K20 12v build
Old 04-28-2013, 07:06 PM   #553
jbclassix
Junk Yartist
jbclassix's Avatar
Re: 72 k20 project
Oh man! Now you're ready for colored transparent speaker wires, wire nuts, and a twisted ground wire under a sheet metal screw!!
-Jeremy
YOU ONLY FAIL IF YOU STOP TRYING
70 Crew Cab Build Link
70 GMC Suburban 4X4 build thread
95 Yukon Daily Driver
Rebuilding an NP205
jbclassix is offline   Reply With Quote
Old 04-28-2013, 07:54 PM   #554
woodwright
Enjoying left field
woodwright's Avatar
Re: 72 k20 project
I just caught up on your thread, looks awesome. I have a question about cast welding though. On my 6.5TD, the turbo manifold has a straight section about 4" long near the inlet.
If I can cut that section out, then my turbo downpipe will fit past it. My plan is to put a good bevel on the cut, preheat the manifold in the barbeque, and tig weld it with nickle rod. Hows that sound? What about using the cut out cast metal as filler?
Clint
70 Chevy 4WD "Ultimate Work Truck" SOLD
woodwright is offline   Reply With Quote
Old 04-28-2013, 10:05 PM   #555
ryanroo
ryanroo's Avatar
Re: 72 k20 project
that will work well. let it all come up to temp. only needs to be 200 or so. weld it and put it back in the barbeque. cool it slowly. do not attempt to use the cast material as filler. it wont work worth a ****.
72 K20 12v build
Old 04-28-2013, 11:08 PM   #556
jbclassix
Junk Yartist
jbclassix's Avatar
Re: 72 k20 project
Ryan, Did you make that dash bling? If so, how about some pictures.
-Jeremy
Rebuilding an NP205
Old 04-29-2013, 08:01 AM   #557
ryanroo
ryanroo's Avatar
Re: 72 k20 project
No, i bought it. a member here, Mahanian sells them. great deal for the money.
Ryan
72 K20 12v build
Old 05-06-2013, 10:13 PM   #558
ryanroo
ryanroo's Avatar
Re: 72 k20 project
tacked the hot pipe flange on the new plate i bought. and cut the turbo mount flange
top of the flange
bottom of the same piece of metal
in position... sort of.
there are few things to consider, but its going to be mounted like this. i biffed and cut the part an 1/8th of an inch thinner than it was programmed for, so its getting re-cut to make my inlet flange pattern match better.
i need to cut a relief in the frame rail for the primary compressor housing.
i need to do some machining on the mount plate to allow for an external gate.
i have to figure out exactly what i am doing with the gate on the primary. it can be done a few different ways.
72 K20 12v build
Old 05-06-2013, 10:32 PM   #559
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Re: 72 k20 project
Looking real good! It must getting warm up there also. Come down for a visit if you get time. Pete
Old 05-07-2013, 06:51 AM   #560
RatRod68
RatRod68's Avatar
Re: 72 k20 project
Lookin awesome Ryan.
build Threads:
Nasty 68 C10. My lil hotrod
Leftovers 68 C20
D-Ranged Ford Ranger on steroids
Semper Fi
RatRod68 is offline   Reply With Quote
Old 05-07-2013, 03:01 PM   #561
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Re: 72 k20 project
Looking pretty nice. When you coming over to weld up my rear suspension and frame?
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 05-07-2013, 09:19 PM   #562
ryanroo
ryanroo's Avatar
Re: 72 k20 project
thanks!
well, i will be in the state in 10 days...
anyhow, i didnt get my replacement flange plate cut tonight, but i scrounged a bit of tube to weld in the frame where i have to clearance for the compressor housing.
AND... i got my jeep running correctly for the first time since mid april last year! already got one dirty look just cruising up the street in my neighborhood.
72 K20 12v build
Old 05-07-2013, 09:40 PM   #563
6lcummins
Re: 72 k20 project
Originally Posted by ryanroo View Post
thanks!
Bring your tape measure and pad of paper....
1996 Dodge 2500 Ext Cab Long Bed P24V Cummins Turbo Diesel 5 speed 4x4
"STOCK"
ASSEMBLY THREAD
6lcummins is offline   Reply With Quote
Old 05-07-2013, 10:48 PM   #564
ryanroo
ryanroo's Avatar
Re: 72 k20 project
ill do my best. not exactly sure what my schedule is. i am actually flying in and out of chicago and riding to IA with my older sister and her family. not sure yet what my schedule will be
72 K20 12v build
Old 05-08-2013, 10:06 AM   #565
RatRod68
RatRod68's Avatar
Re: 72 k20 project
wahoo!!!
build Threads:
Leftovers 68 C20
Semper Fi
Old 05-08-2013, 09:52 PM   #566
ryanroo
ryanroo's Avatar
Re: 72 k20 project
so, i re-cut my turbo flange. it now fits the inlet on the Hx55 much better. outwardly it looks no different, so i didnt take any pics of the new one. i have a little machining to do to it then it'll be done.
i did take a short video of the 3D flow in action for those interested
just so you all know, it is .750" plate steel the mounting holes for the secondary turbo are cut at .385" .010" oversized for the the fastener (.375") with studs threaded into all 4 holes on the manifold flange the waterjetted part slips over the studs with 0 clean up after cut. awesome.
72 K20 12v build
Old 05-08-2013, 10:24 PM   #567
Mattman2010
Mattman2010's Avatar
Re: 72 k20 project
Twin setup is looking really good bud! That waterjet is sweet
1980 K10 - 6.2L Diesel/SM465/NP205
Build Thread
1984 K30 CC Dually - "The Tank"
12V Cummins/Nv4500/Np205/D60/D70HD 4" lift & 37's
Build Thread
1960 C-60 Dump Truck
Make it road worthy!
Thread
Mattman2010 is offline   Reply With Quote
Old 05-08-2013, 11:14 PM   #568
jbclassix
Junk Yartist
jbclassix's Avatar
Re: 72 k20 project
Why did you buy the outlet plate and not cut it yourself out of curiosity?
-Jeremy
Rebuilding an NP205
Old 05-08-2013, 11:21 PM   #569
ryanroo
ryanroo's Avatar
Re: 72 k20 project
it was 18 bucks. all i needed to do was get out the credit card. i was already ordereing from the place i got it, so i just did it. seemed easier than reinventing the already round wheel. after getting it and finding out how well it fit, or didnt. i would have rather drawn and cut my own. but, its on there now, so all is well.
72 K20 12v build
Old 05-09-2013, 01:49 AM   #570
woodwright
Enjoying left field
woodwright's Avatar
Re: 72 k20 project
Is that a 5 axis waterjet? COOL! I programmed a little for a local guy with an older Flow waterjet.
Clint
Old 05-09-2013, 07:56 AM   #571
ryanroo
ryanroo's Avatar
Re: 72 k20 project
Yessir!
it can do some really cool stuff but its way slower than the plasma for sure. we are waiting for the Flow guys to finish up on the laser mapping device/software. right now it doesnt have any way to locate the surface of the material so if you have a sheet with a little hump in it, it can blow the water back into the abrasive and clog the crap out of it. hopefully they get that stuff done sometime soon.
we cut some cedar with it the other day, that was pretty interesting.
72 K20 12v build
Old 05-09-2013, 09:20 PM   #572
ryanroo
ryanroo's Avatar
Re: 72 k20 project
so i cut some slots in the turbo plate for the external wastegate.
you can see how the cut matches the flange better now that it is the correct thickness
just to show how the wastegate ports are
got a 90 degree silicon elbow. it will probably need to be trimmed, but it is the best way to make the corner quick and stay out of the alternator. it is also a 4"-3.5" reducer.
also the downpipe flange is on there. it will need to be grafted to an ell very close to the exhaust housing, but it fits!
72 K20 12v build
Old 05-09-2013, 10:34 PM   #573
woodwright
Enjoying left field
woodwright's Avatar
Re: 72 k20 project
Yessir!
I would LOVE to run that......Hint hint.
Clint
Old 05-10-2013, 12:26 AM   #574
jbclassix
Junk Yartist
jbclassix's Avatar
Re: 72 k20 project
So was your first stage originally an internal waste gate? If so how did you close the port? Is the external going to dump pre or post secondary turbo?
-Jeremy
Rebuilding an NP205
Old 05-10-2013, 08:18 AM   #575
ryanroo
ryanroo's Avatar
Re: 72 k20 project
we already have about 4 guys and the owner who can operate it, so you are welcome to try, but i dunno if they'll bite. right now its more of a toy than a money maker. i assume that will change as we get better at programming and all that. they were looking at new 3D software yesterday, so who knows.
both turbos are internally gated. i will be blocking off the internal passages for the gates in one way or another. most likely i will be tapping the ports and using a pipe plug. depending on how this set up runs and if i feel like it will spool with it, i may step up to a 14cm exhuast housing on the 35. they are not internally gated, so i will be ready for that. according to my friends at low budget diesel, i probably will not need a gate fro the primary. if i do, it will be an easy add on. the gate on the secondary will dump into the hotpipe to help drive the primary.
72 K20 12v build
