04-02-2012, 10:14 AM | #551 |
Happy to be here
Re: No Limit's "K-10"
It got a little loose on that one turn. Its hard to tell if he crossed the line, or the exhaust dusted it as it went by.
04-02-2012, 11:18 AM | #552 |
That is the sweetest truck I have seen in a long time. I keep checking back to hear from Rob!
1972 Blazer body...need to get a thread started for the rest of the story |
04-02-2012, 11:46 AM | #553 |
GOOD MORNING MUTHA TRUCKERS!!!! we're still pretty tired around here this a.m., but we had a great weekend. Between the thrash to get the truck up and running and our annual track day on thursday, last week didn't offer much sleep. Thursday night the truck was finally loaded at 3 a.m., and then a 2+ hr drive to Del-Mar. Marcel and Edwin were still buffing as we were loading the truck. The shop is a mess. I slept from 6:30 till noon on friday morning, and then got up and cleaned the truck. After tech, we got one check out pass friday afternoon. After some good pizza and beer with friends and the crew, we crashed early. Saterday we made five more runs, then three more sunday. Here's the good and bad. The gears in the quickchange are set too tight, way too tight, it will have to come apart and be fixed. The springs, 500 frt, and 200 rr, ar too stiff, swapping to 400/150 right away. The power steering feels very heavy, a valve or a pulley will fix that. Then it's tune, tune, tune. O.K., no heat coming through the floor and tunnel . Brakes feel good. - frt/rr bias was the only thing I tuned all weekend. All the mechanicles are good. I dig the guages, the tach is easy to read, and the temp guages have built in warning lights. It's FAST, really fast. The motor pulls hard, and although it's not sorted out at all, I can tell by the feel of the platform that it will be a terror on the track and street. I'll try to get more picts and video up today, now I got to go and clean the shop.
GoodGuys 2012 Pro-Truck Champion 2012 Truckin' Throwdown Champion GoodGuys 2011 National Champion 2011 Truckin' Throwdown Champion GoodGuys 2010 National Champion Proud to put our products up against all others! |
04-02-2012, 05:55 PM | #554 |
2 words sum it up: BAD ASS! You guys did an amazing job in a short time and came out of the blocks hard! That truck is amazing and will go down in history as an ICON! Trend setting! Go kick the crap outta come camaros and vettes!
Frank (Hilo, Hawaii) Trucks, Tacos, and Beer go together like Peanut Butter and Ladies! 85 C/10 SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=760383 67 C/10 SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=489298 79 K5 Blazer SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=657461 |
04-02-2012, 08:16 PM | #555 |
x2
James 63 GMC V6 4speed carryall 65 chevy swb bbw V8 auto 68 K20 327/4 speed, buddy buckets 2002 GMC CC Dually Duramax 64 GMC lwb 3/4 V6 4speed SOLD 66 GMC swb bbw buddy buckets SOLD IG duallyjams The only thing that stays the same is constant change! |
04-02-2012, 09:03 PM | #556 | |
'69 Chevy SWB
I'd say hand built, just like the rest of the truck.
Matt '69 Chevy SWB Fleet, Primer Black; Project No Name '06 Chevy Trailblazer, Blueish Silver?; Wifes DD, Sold '08 Chevy Impala SS, Silver; the new DD, AND IT IS FUN!!! '99 Dodge Dakota R/T, Intense Blue; DD, Sold Quote:
04-02-2012, 09:25 PM | #557 |
Shots during the final push. 1. From the bottom you can see the floor layout, and exhaust path back and to the pass side. 2. from the bottom side, the rear end, fitted tank and air ducts for the radiator. 3. lots of insulation going in.
GoodGuys 2012 Pro-Truck Champion 2012 Truckin' Throwdown Champion GoodGuys 2011 National Champion 2011 Truckin' Throwdown Champion GoodGuys 2010 National Champion Proud to put our products up against all others! Last edited by robnolimit; 04-02-2012 at 09:32 PM. |
04-02-2012, 09:27 PM | #558 |
1. some foam going on the dash. Odd looking, but I can see the Tach and speedo at a glance, no blocking from the steering wheel. 2. No Limit fabbed alt. mount. Old school adjustment. 3. No water pump up front = lots of plumbing off the block.
GoodGuys 2012 Pro-Truck Champion 2012 Truckin' Throwdown Champion GoodGuys 2011 National Champion 2011 Truckin' Throwdown Champion GoodGuys 2010 National Champion Proud to put our products up against all others! Last edited by robnolimit; 04-03-2012 at 11:44 AM. |
04-02-2012, 09:28 PM | #559 |
1. On the pass side cyl head, I mounted the KRC power steering pump. 2. Drivers side header with the 'hot-dog' loop, needed to fit in for tube length and the plugs. The headers are try-Y design, mostly for packaging. 3. Pass. rear corner, with battery, fuel pump and wiring, Yes, we did clean this mess up, looks much more organized now.
GoodGuys 2012 Pro-Truck Champion 2012 Truckin' Throwdown Champion GoodGuys 2011 National Champion 2011 Truckin' Throwdown Champion GoodGuys 2010 National Champion Proud to put our products up against all others! Last edited by robnolimit; 04-03-2012 at 11:51 AM. |
04-02-2012, 09:30 PM | #560 |
1. shot of the rear just as we're wrapping things up. 2. the rear gate will have mesh grills soon, to help clean up the rear. 3. On the hard cover, we used 3m adhesive to hold the skins on, this stuff is way strong.
GoodGuys 2012 Pro-Truck Champion 2012 Truckin' Throwdown Champion GoodGuys 2011 National Champion 2011 Truckin' Throwdown Champion GoodGuys 2010 National Champion Proud to put our products up against all others! Last edited by robnolimit; 04-03-2012 at 11:59 AM. |
04-02-2012, 09:32 PM | #561 |
1. This is the hard cover frame with the skins next to it. The skins are 'Alumna-lite', a sign board material made of thin aluminum bonded to a layer of abs corrigated sheet. 2. the cover with the skins on. the white is a baked on finish, later we will wrap this to better match the truck. 3. the cover in place on the truck. The cover wieghs only 28 lbs total, not to bad.
GoodGuys 2012 Pro-Truck Champion 2012 Truckin' Throwdown Champion GoodGuys 2011 National Champion 2011 Truckin' Throwdown Champion GoodGuys 2010 National Champion Proud to put our products up against all others! Last edited by robnolimit; 04-03-2012 at 12:04 PM. |
04-02-2012, 09:33 PM | #562 |
OK, I usually don't like people to see our shop like this, but this is what happens late at night, with a few hours to go. pict 1 is at apx 11:00 pm on thursday night. From left to right, Mike (Sullivan) eating and checking the rear relay stack, Edwin color sanding with 1500, Carl, the super-tuner, working on the ECU, and wild Bill greasing up the IFS, getting ready to hang sheet metal. - notice that is really dark outside. 2. Monday morning, in the bomb testing area, time to clean up.
GoodGuys 2012 Pro-Truck Champion 2012 Truckin' Throwdown Champion GoodGuys 2011 National Champion 2011 Truckin' Throwdown Champion GoodGuys 2010 National Champion Proud to put our products up against all others! Last edited by robnolimit; 04-03-2012 at 12:15 PM. |
04-02-2012, 09:42 PM | #563 |
Everything about this truck is awesome...amazing fabrication and creativity.
Great job!
1967 Chevy c10 SWB Project "Daily Driver" Build Thread: http://67-72chevytrucks.com/vboard/s...ar#post4953311 |
04-02-2012, 10:14 PM | #564 |
PROJECT 7DEUCE
Do work driver....
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
04-02-2012, 10:52 PM | #565 |
Truck and auto performance nut
I'd say that's "all bizness"
Kurt - '68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy '72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close '06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD '18 Kia Sorento - wife's econo-driver '95 Chevy S10 - reg cab shortbed, LS, 4.3, auto... my '68's powertrain and chassis build -links broken A surprise phase - carb to efi -links broken |
04-03-2012, 10:27 AM | #566 |
67cheby
Everything is just awesome !
04-03-2012, 12:54 PM | #567 |
I love it!
04-03-2012, 02:53 PM | #568 |
Awesome job Rob can't wait to see the truck!
04-03-2012, 06:01 PM | #569 |
Since this is a really big learning experience for me with all the new stuff, I thought I'd pass on some of the info. This will be scattered in for the next few years. First off, How did the weekend go? - really? Pretty good. I was nervous about a lot of things, mostly gears, cooling and the suspension. And, did we tighten up all the bolts. So, nothing fell off, and it turns left and right. The cooling works very well, but, it makes me nervous knowing if its on or not. So, we'll be adding some indicator lights into the dash to tell me when the pump and fan are on. That brings up a question, why doesn't Autometer or VDO put turn sig and high beam indicators in the speedo? I used a 3/4" clutch master, as recomended, and the new McCloud hydrolic throwout bearing. It works good, but needs a lot of pedal travel, this may be fine in the average truck or car, but I'd like to have the pedal heads even for quick foot action. So, I'm going to try a 7/8" clutch master, and hope that it's not too hard to push, - it's really easy now so a little firmer would be good, but not too much. I will be finishing the interior and door panels soon, and decided to put a pocket into the door panel for a temp gun, a tire pressure guage and a log book. - never have a place for them. Anyway, the first time out was a big hit. We heard VERY encouraging comments, and thank you guys for them too. Next comes the Truckin' Throwdown, we'll be taking both trucks, the 'Bullit, and the new C-10, 'HellBoy'. We've got about 5 weeks to get ready, and lots to do. I'll keep ya posted.
04-03-2012, 07:09 PM | #570 |
Hey Rob instead of changing out the clutch master cylinder, you could just move the push rod away from the pivot on the foot pedal giving you the travel you will need on the 3/4" master. Just an idea.
The only part that sucks, is that I was on a food run on Saturday when you took the truck for a "loop", I heard that it was very exciting with the spins. I can see were your saying about the springs getting sorted out. How was Tina with the ride.....lol. Just make sure to get it worked out by next Sept, I want it to be perfect when I get to make a lap in it on the Labor Day Cruise.........hee hee hee Great job on the truck, I am still shaking my head at it's 2800 lbs curb weight.
Lifes journey is not to arrive at the gate well preserved, it is to slide in sideways all used up and wore out yelling.....God what'a ride! Where patience fails, force prevails Stapp's Ironical Paradox "The universal aptitude for ineptitude makes any human accomplishment an incredible miracle." |
04-03-2012, 07:19 PM | #571 |
6>8 Plugless........
Awesome work Rob and crew! That's awesome you guys got it together and were able to make shake down runs! It looks and sounds awesome!
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
04-03-2012, 09:28 PM | #572 |
You need to get the Bullit and Hellboy together for a new profile pic!
04-04-2012, 11:18 AM | #573 | |
04-04-2012, 03:12 PM | #574 |
Hey Rob was great talking with you in Del Mar. HellBoy is going to be a real fast truck no doubt. Truck did very well for the first trip out and looks great. A bit of tweaking and it's gonna be a bullet. Go and kick the crap out of those Camaros and Vettes! Very nice job to you and your boys,
04-04-2012, 03:16 PM | #575 |
What era Stang you working up for her Rob?
