10-14-2019, 02:17 AM | #1 |
Re: Our "What are we going to do?" 66 Suburban Build
Yep, but it's all in there!
Thanks Capt., we appreciate that! We've had the reworked tranny back from BTE for a couple weeks now. BTE has impressed the s**t out of me with their support and willingness to help with some problems I had with a local builder. If you remember, I sourced a few parts from BTE in spring...aluminum drum, input shaft, intermediate shaft, torque converter, mechanical diode, and a few other little things. I had a local builder assemble the tranny. We cooked the tranny in the first 10 or so miles! I reached out to BTE for direction... I knew there weren't any problems with their parts, but I didn't trust my builder any more. BTE had me send the tranny to them in Mt. Pleasant, MS so they could inspect it. They quickly found a couple builder related problems. BTE completely rebuilt the tranny, tightened up the TC a bit, and had it back to me in less than a week! We reinstalled the tranny tonight...I don't expect any more problems with it.
1958 Chevy 1 ton dually 4X4 dump/flat bed My build thread 1966 "Not-So-Original" Chevy Custom Trim Suburban My Time-Killing Project Truck 1966 GMC Extended cab 1 1/4 ton 4X4 My Son's build thread |
10-14-2019, 02:33 PM | #2 |
Rollin' Old Skool
Sounds like some great customer service from fellow Mississippian's at BTE as well!
_____________________________________________ Phillip My Build threads: 1966 Chevy C-10 "Black Betty" shortbed, fleetside, BBW, 327 V8/ Powerglide (under construction) http://67-72chevytrucks.com/vboard/s...ighlight=betty 1997 Chevy Tahoe, 2dr/2wd, mild custom (Daily driver) http://67-72chevytrucks.com/vboard/s...d.php?t=601142 Pics: '66 C-10 https://flic.kr/s/aHsjHWD4h9 '97 Tahoe https://flic.kr/s/aHsjGZ7wKP '93 C-1500 https://flic.kr/s/aHskxdpdnQ '88 S-10 Blazer https://flic.kr/s/aHsjYGx4Md Previous Rides: 1993 Chevy S-10 ext. cab, 4.3L, 4/5 drop (Sold) 1993 Chevy C-1500 short/step Retro-Rod (Sold) 1988 S-10 Blazer 2dr/2wd mild custom (Sold) |
10-21-2019, 01:24 AM | #3 | |
My son didn't like the interior light housing and decided to do something about it. He ground the perimeter down until the center released and replaced it with a piece of light cover from the shop. He's replacing every bulb in the burb with LED's...should be a lot brighter!
1958 Chevy 1 ton dually 4X4 dump/flat bed My build thread 1966 "Not-So-Original" Chevy Custom Trim Suburban My Time-Killing Project Truck 1966 GMC Extended cab 1 1/4 ton 4X4 My Son's build thread Last edited by RockTonka; 10-24-2019 at 01:31 AM. |
10-21-2019, 01:31 AM | #4 |
We also disassembled the front end, painted everything, and reassembled...going back together for good...again!
10-22-2019, 09:45 AM | #5 |
Awesome..you going to test it on the dyno
My 63 GMC Panel Slow Build http://67-72chevytrucks.com/vboard/s...=1#post5457281 63 |
10-24-2019, 12:12 AM | #6 |
No, not on a chassis dyno. It's been tuned on the engine dyno...that was important to get it dialed in. I can't justify the $$ for time on a chassis dyno.
10-24-2019, 01:28 AM | #7 |
Continuing with the conversion to all LED...much brighter!
10-28-2019, 01:29 AM | #8 |
We finished up most of the wiring (lights, new fans, tranny temp sensor, etc), topped off all the fluids, and put a few miles on it this afternoon.
We kept it conservative...only about 20 miles, but we did hammer on it a few times. Everything kept cool...maybe too cool. The burb ran great though, gonna try to just kick back and enjoy it for a bit...although there are a few more things I want to do to it.
10-28-2019, 09:53 AM | #9 |
Dadgum, definitely my favorite suburban
Are y'all still running the Camaro rear sway bar?
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
10-28-2019, 11:03 PM | #10 | |
Thanks CW! We pulled the rear sway bar off...the mounts on top of the axle were hitting the frame as we played around with spring rates on the coil overs. We will run a bit with just the coil overs to see if they can compensate much for body roll...we have adjusted the rebound/compression a bit with positive results though.
10-29-2019, 12:46 AM | #11 | |
I just went back to where y'all installed it (page 12 for anyone else wondering) to see how y'all had mounted it. I want to add a bar to my truck as well, so I've been gathering up ideas. Still have stock stuff under mine, so no worries about hitting anything yet. Sounds like the coil overs are the way to go, but for now, stock is just fine
10-29-2019, 01:09 AM | #12 | |
If you were closer, I'd make you a deal on my old one...shipping probably isn't worth it.
10-29-2019, 01:13 AM | #13 |
That would be sweet, but I agree, shipping would be way too much. I'm sure I can find a bar somewhere around GA. There's a few places that I need to go to, just haven't had the time this semester to do so
10-29-2019, 01:01 PM | #14 |
Rollin' Old Skool
Glad to hear it's back together & running! Hopefully it all continues to work well from here on out. I know y'all are ready to just enjoy the fruits of your labor. Any thoughts yet on the headlights? I've noticed lots of folks switching to LED headlights these days, even on more modern (but not new) stuff.
10-30-2019, 08:28 PM | #15 | |
We'll see how long they last...
10-30-2019, 09:14 PM | #16 |
Sounds awesome glad you are out driving and enjoying it
10-30-2019, 10:00 PM | #17 |
Thanks PE!
11-02-2019, 08:21 PM | #18 |
11-02-2019, 08:27 PM | #19 |
All LED is fairly bright!
First pic is low beam, second is high...then back-ups and interior.
11-30-2019, 04:10 AM | #20 |
That is awesome
12-01-2019, 02:52 AM | #21 |
Thanks PE, this will improve the handling a bit and more importantly (for us), the arms will move the wheel centerline forward an inch. We need a smidge more clearance on the driver side header.
Everything came apart nicely...new upper shock mounts got welded on (couldn't get to the backside with boxed frame). We're going to order in some heavier front springs...the stockers, although relatively new, are a little overwhelmed with the added weight up front.
12-01-2019, 04:20 PM | #22 |
Rollin' Old Skool
Nice! Definitely need all the good handling you can get with a beast like that.
12-15-2019, 04:30 AM | #23 | |
We ended up working with Eaton Detroit Spring for different front springs, these guys know their sh!t...wealth of knowledge for sure. I measured my existing springs at 0.79" dia. and 13" long free length. This is a little heavier than stock C10. Eaton recommended a 0.815 dia. at 12 5/8" long...jumping me from a roughly 800lb/in to 1000lb/in spring rate and keeping my ride height exactly the same. They had these springs in stock and shipped out the same day I called. The new springs are the clean ones...can't tell much difference side by side, but I can tell a big difference installed. We also got the Porterbilt arms installed tonight (quick note about superior customer service...texted Nate with a question on the installation and he answered within a few minutes late on a Saturday afternoon). Moving the wheel centerline forward an inch is a subtle difference, but noticeable and provides us with needed clearance.
12-15-2019, 07:03 PM | #24 |
Buttoned back up...
12-16-2019, 12:02 AM | #25 |
Rollin' Old Skool
Looks good! Always a huge plus when you get good customer service. Some companies need a good lesson in that!
