#551 |
Re: 1972 Chevy p/u NewType Build
might we be talking a blower assembly to enhance it!?!?
Adam My 1967 C10 - Turbo 250 Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=485843 (608) 214-8706 |
#552 |
![]() ![]() Posted via Mobile Device
![]() Project Great Grandpa's Legacy 1973 Chevy C/10 Cheyenne ( Current daily driver collecting big time parts ) http://67-72chevytrucks.com/vboard/s...89#post7084289 - Dylan (209)-985-7721 |
#553 | |
Proprietor of Dale's Corner
![]() Join Date: Nov 2012
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
#554 |
Haha I know I'm staying as close to daily as I can with a little fun
#555 |
Well was a very nice weekend I ran a few errands around Saturday and even got some dinner taking the truck up to Modesto and then Sunday had a bigger run down to chowchilla for my brother in laws bday had a blast driving the truck down there in the fast lane with everybody else in their prius's laughing as they would scoff at my pollution
![]() ![]() Here's a picture of the beautiful sunset we had for a few minutes on our way back ![]() Posted via Mobile Device
#556 | |
#557 |
C/10 junkie
I'm down when you guys are
Shawn 70 LWB C10 current driver/project http://67-72chevytrucks.com/vboard/s...d.php?t=663051 68 SWB C10 Work in progress.....SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=559520 72 LWB C10 Sold 71 LWB C10 Sold 68 LWB C10 CST Sold http://youtu.be/kbB0QrBIs9k My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!" ![]() |
#558 | |
![]() ![]() And I'm down whenever we can all work out a weekend day Posted via Mobile Device
#559 |
Well I'm roundin up ideas for the truck since its current setup is decent I want it to have a little more power and durability all around so here's what I have
Current setup: 350 sbc less than 200 HP Th350 trans Very solid rebuilt three years ago 12 bolt 3:73 gearing dog legger rear end very solid Disc brakes up front with mcgaughys 2.5" drop spindles and stock worn springs Drum brakes out back solid but wanting disc E-brake cable broke midway never been fixed since I got it Dream setup: 350 sbc 300 HP on carb style motor 700r4 overdrive tranny 12 bolt 3:73 Richmond gears with eaton posi Front suspension stays with the spindles Rear brakes upgraded to wildwood calipers and rotors (what do I need for swap or can I just buy the kit?) Bag the truck manually Posted via Mobile Device
#560 |
I'll have to check with my friends and see when they'll let me relax a day
![]() and we'll do it
#561 | |
#562 |
I plan to swap everything out in the next two months in one swoop so the truck isn't down long and I can work out any kinks before I do the brothers show this summer so I'm trying to figure out all that ill need for when I do this the motor won't be much change other than more power, new headers and what not. The trans will be longer an has the overdrive so new crossmember? And the linkages for the column to act correctly? And then I'm not sure if I can just do the kit for disc brakes in the rear end and what not. Should I put the question elsewhere in the forum for more depth in what I should prepare for?
#563 |
Well I'm hearing multiple opinions so far as far as rebuild an older motor save a few bucks if it's solid, buy a long block from gm and have that new motor smell, run 3:73's youll be fine, 3:08's work better with the 700r4's...
lotta stuff to process may be nixing the posi at this point so I can afford the more major stuff
#564 |
I like your truck! What do you do down in turlock? Im always working in that area.
Rob 1971 c10 - ground up in progress Tripp's Speed Shop Build - http://67-72chevytrucks.com/vboard/s...d.php?t=589750 |
#565 |
Thank you I work for Sinister Wheel in downtown Turlock I do their motorcycle Billet machining for them and I'm usually up and down from Salida to Madera but been living in Turlock since 2002 or so
#566 |
Oh nice. I work for R&s. I'm sure we've done work on your doors at your shop!
#567 |
Possibly so then right on
#568 |
C/10 junkie
Hey Hardesty you should come to the Stockton swap meet BBQ with us and join the fun,
http://67-72chevytrucks.com/vboard/s...d.php?t=563077
#569 | |
1968 LWB C20 / AC / Wood Bed |
#570 | |
#571 | |
C/10 junkie
1658 S Airport Way Stockton, CA 95206 (209) 466-5041
#572 | |
#573 |
Becoming harder to decide if I should rebuild this motor I have or just buy a crate motor and be done with it. Obviously a little more expensive but if I plan on putting a lot of miles on this thing where's the negative after that?
#574 |
C/10 junkie
Crate and done. Check out Westcoastengines.com
#575 |
X2, less down time. Pull old out, clean up the engine bay, install and done
Tags |
1972 chevy c10, cheyenne super, rebuild, restoration, showtruck |
