Closed Thread
Old 04-21-2014, 07:50 AM   #551
mcm1209
mcm1209's Avatar
Re: What did you do to your truck today? Chapter II
Hauled her home from PO!!
Good day yesterday!!!!!!!!!!!!!!!!!!
mcm1209 is offline
Old 04-21-2014, 03:56 PM   #552
Willys47
Willys47's Avatar
Originally Posted by zellway View Post
Started to work on my fan setup and pulled all the parts for the front runner kit but with family in town that was about it.
I like the fan Idea is ther any info on the fan can u share?
I was hooked on these trucks since 1982 when I drove my budys fathers 1968 Custum GMC 396 automatic dana 60 rear with a power lock diff what a ride more fun then we will we can ever tell!!
Willys47 is offline
Old 04-21-2014, 03:57 PM   #553
BugzC10
BugzC10's Avatar
Finshed up installing new master cylinder, proportioning valve and new stainless steel soft brake lines. Had to do a little grinding on the caliper to change the banjo clocking. Man the pedal is so much better. Still have to test drive. Also installed new alternator bracket.
OLD:
NEW:
1970 C10 Short Stepper with 71/72 front clip.
BugzC10 is offline
Old 04-21-2014, 07:04 PM   #554
vidman
vidman's Avatar
More work on my fuel system and exhaust...
62 Willys 4wd Pickup : 72 C-10 swb 504 stroker 09 Taco 3" lift 33" tires: 90 K-5 blazer (plow truck): RIP Ross Little brother
vidman is offline
Old 04-21-2014, 09:19 PM   #555
In The Ten Ring
Whoa! I really like the simple but very solid mounting bracket system you have.
Also....are you going for a side marker or tail light filler setup on your tank?
In The Ten Ring is offline
Old 04-21-2014, 09:23 PM   #556
In The Ten Ring
I actually got something done on my truck today! I ground out the broken off extractor from a broken bolt. I had tried to break the extractor out with a chisel but no luck. My dremel tool seems to have done the job and as soon as my left handed drill bits get here, I hope to remove it utterly.
I also used my dremel and cutting wheels to cut out the tac welds on the passenger side (front) cab to frame mounting bolt. I took it really easy and took my time: the sparks flew! All it took was a very light tap with a ball peen hammer and BOOM, she was free.
I hope to have the cab to frame bushings replaced this week!
Old 04-22-2014, 07:34 PM   #557
vidman
vidman's Avatar
I did a inside the bed filler..I will take pics later in the week..
vidman is offline
Old 04-22-2014, 07:37 PM   #558
vidman
vidman's Avatar
worked on my power steering and alternator set-up..
vidman is offline
Old 04-23-2014, 06:56 PM   #559
vidman
vidman's Avatar
Some pics of my fuel filler
vidman is offline
Old 04-23-2014, 07:36 PM   #560
BugzC10
BugzC10's Avatar
Who's power steering pump braket are you using?
BugzC10 is offline
Old 04-23-2014, 08:01 PM   #561
big_rig
Today I installed my alternator and power steering brackets on the 292. Went with a nice two groove billet pulley on the p/s pump to run a seperate belt for the alternator.
big_rig is offline
Old 04-23-2014, 08:03 PM   #562
vidman
vidman's Avatar
Modified Alan Grove..the stock Grove bracket was about 1/8 off for belt alignment. I messed around with tig welding some washers on the block side to correct. also made some 7/16 flat head bolts and counter sunk the front bracket for more clearance on my alternator belt.. Right now my all my belts are perfect
vidman is offline
Old 04-23-2014, 09:00 PM   #563
In The Ten Ring
I ground down the old tac weld.....I am rather concerned my new bolts won't allow proper cab to frame alignment due to the old tac welds. If anyone has any advice....PM me!
Old 04-23-2014, 09:45 PM   #564
colgad
colgad's Avatar
Aligned the hood and installed the bumper.
Hood coming off tomorrow to paint
One year three months after my frame off start, getting close now!
1967 Red, C10 Short Bed 6.0L T5 5 speed
1967 Orange and Black C50 6.2 Detroit Diesel NV4500, 2 Ton Pickup
1972 White, Chevy Blazer 2WD 67 Dog house 5.3 4L65 2016 Power Tour LH
1955 Red-Cream, Chevrolet Nomad, restoration on hold
2004 Black, Corvette Z06 LS6 convertible (Rock solid Fun) 2011/2018 Power Tour
colgad is offline
Old 04-23-2014, 09:55 PM   #565
Mr Handy
Mr Handy's Avatar
I got a few parts in the mail for my Jegs Long Block... more stuff coming tomorrow, and Friday, and Monday
Mr Handy is offline
Old 04-24-2014, 01:59 AM   #566
Motoxrrar
Didn't exactly do much, rebuilt my steering shaft. Powder coated it and then put it all back together. Needed to use a small file... But couldn't find the handle... Then I found an old headlight switch that was broken, waaa laaaa handle..... Redneck improv = good times !! Headlight file !!
Motoxrrar is offline
Old 04-24-2014, 07:12 PM   #567
vidman
vidman's Avatar
Sweet looking ride...
vidman is offline
Old 04-24-2014, 07:21 PM   #568
vidman
vidman's Avatar
Trying to finish my exhaust system. Just don,t know where to go from here..
vidman is offline
Old 04-25-2014, 07:47 AM   #569
KyleSeal
KyleSeal's Avatar
Originally Posted by 88fordf150 View Post
Made a custom SPI tag on the computer.
That's sweet. What software did you use?
"Sometimes I do serve as a good bad example. Glad to be of service."
My Build Thread (1967 C10, lowered, EFI, daily truck): http://67-72chevytrucks.com/vboard/s...d.php?t=830809
KyleSeal is offline
Old 04-25-2014, 07:50 AM   #570
KyleSeal
KyleSeal's Avatar
Originally Posted by OregonNed View Post
I test fitted my new seat and figured our how far up I needed to mount my floor shift:
Then removed it and began the fat mat installation:
Then laid the new carpet in to test fit:
Where'd you get the carpet from?
KyleSeal is offline
Old 04-25-2014, 08:23 AM   #571
Towstrap
Towstrap's Avatar
got my tailgate back from paint after 9 months
Towstrap is offline
Old 04-25-2014, 08:55 AM   #572
texasld
texasld's Avatar
I like this idea! Is that magnets that hold the top to the bed side?
Nice looking truck. I hope mine will be half that nice by the same time frame.
Love it!
1969 C10 SWB 5.3L LS, 4l60e, 2/4 drop (In Progress)
2015 GMC 2500 Duramax (Daily Driver)
1999 Jeep TJ
2010 Harley Street Glide
Check Out My Build!: http://67-72chevytrucks.com/vboard/s...d.php?t=617981
texasld is offline
Old 04-25-2014, 11:56 AM   #573
zellway
zellway's Avatar
Fan is from a jeep with a v8. link that gave me the ides. http://67-72chevytrucks.com/vboard/s...d.php?t=378483
Erik
My 69 suburban http://67-72chevytrucks.com/vboard/s...d.php?t=530626
1970 C10 step Project Jiminy http://67-72chevytrucks.com/vboard/s...d.php?t=682647
RUST!? Thats just mother natures way of telling all of us.....MINE!!!!
zellway is offline
Old 04-25-2014, 02:52 PM   #574
vidman
vidman's Avatar
That they are. I used 3 super-duty magnets to hold the cover in place and 2 stainless pins on the bottom. you need quite a bit of force to pull the cover off, so might end up putting on a billet handle. have to see how it goes
vidman is offline
Old 04-25-2014, 05:40 PM   #575
Motoxrrar
Somewhat finished my gauge cluster thanks to 70shortfleet. Thanks for tach tin ! Really need to find a decal for my lens for vaccum.
Closed Thread
