Old 01-16-2017, 11:51 PM   #551
HUSSEY
HUSSEY's Avatar
Re: S10 Swap how to
Originally Posted by skymangs View Post
CoreyH; I would think twice about using that 700R4, in order to realize the benefits of that 5.3, you will need a 4L60E trans.
Personally, I don't think either transmission provides a benefit for the 5.3 unless you consider the ECM and it's ability to control the transmission.
If you're using the ECM from the 5.3 then yes I would agree that a 4L60E would be easier to get up and running, no need to hook up a T-V cable.
But, if you're going to a throttle body injection like the Holley Sniper or FI -Tech or with a carburetor then you could go with a 700R4, otherwise you will need a standalone transmission controller which run + $500. But, if you like the idea of being able to change shift points via your laptop then a 4L60E would be the way to go.
With the 700R4 you will need to hook up the T-V cable to the throttle body correctly and adjust it correctly, failing to do so will burn up your transmission.
So, in the end, I think it's really the builder that needs to weigh thier options to determine what best fits their needs, wants, and application.
My 49 AD Build / S10 Chassis -- Thread -- Pictures -- S10 Conversion Mounts
HUSSEY is offline   Reply With Quote
Old 01-17-2017, 10:23 AM   #552
CoreyH
Re: S10 Swap how to
I like the 4l60e transmissions, have one in my TB, but I didn't want to mess with all the wiring for that on a truck like this. Never used a 700r4 before but heard they were good transmissions for these builds with an LS motor. Running LS1 102mm intake manifold and fuel injection. I've already got a PCM and can get the TCM for it, just didn't want to mess with all the wiring. If that's the better transmission over the 700r4, then I'd rather have the 4l60e
CoreyH is offline   Reply With Quote
Old 01-17-2017, 10:48 AM   #553
reaper71
reaper71's Avatar
Re: S10 Swap how to
The 700R is a good trans. just be forwarned if you BEAT on one it will fail! So have it built to handle a beating if thats your plan.
The 4L60E is also a good trans just make sure you use DEXTRON 6 fluid! if you don't it will start to slip as it get's hot (do to foaming of dex 3-4) the dex 6 is a synthetic and will not foam (I found this out the hard way) That being said you can get the 4L60 (non electric version) and will be a great choice with the overdrive and the LS.
Mark...
reaper71 is offline   Reply With Quote
Old 01-17-2017, 11:05 AM   #554
CoreyH
Re: S10 Swap how to
Mark...
I don't plan on rodding it out, but if I want to get up and go I want the power to be there. Wiring don't scare me, I was just under the impression the 700 was the better choice. I can rebuild either one but since I'm going EFI, the 4l60e seems like a better choice.
Old 01-17-2017, 02:52 PM   #555
joedoh
joedoh's Avatar
Re: S10 Swap how to
are you guys maybe referrring to a 4l80e when you are talking the difference between a 700r4? because in my admittedly limited understanding, the 4l60e is an electronic 700r4, the 700 has a governor and a TV cable like Hussey is saying, but the internals are interchangable with the 4l60e which has an electronically controlled shift and kickdown
a 4l80e is a very stout trans that can come behind ls/lm/lq variants and doesnt share design with the 700/4l60
the mass of men live lives of quiet desperation
if there is a problem, I can have it.
new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393
joedoh is offline   Reply With Quote
Old 01-17-2017, 08:48 PM   #556
oldman3
oldman3's Avatar
Re: S10 Swap how to
Got this info off of google, and I already knew part of this.
700R4 from 1982 till 1990, then 700R4 was renamed by GM in 1991 as the 4L60 (non elec) numbers and letters stood from 4 speed, L longitudinally and 60 as 6000 GVW. In 1994 the 4L60E was introduced. Depending on brand etc, these dates will very on when they were installed in vehicle. We now have 4L80E, 4L85E, and so forth. Hope this helps...Jim
oldman3 is offline   Reply With Quote
Old 01-17-2017, 09:40 PM   #557
99 to Life
99 to Life's Avatar
Re: S10 Swap how to
keep in mind not all 4l60e will mate flawlessly to the gen3 block. Three modifications are needed if the trans didn't originate on the gen3 block. 1. Flywheel holes need elongated or get a new flywheel, 2. an adapter plate is needed since the cranks are different 3. which is least of any ones worry, one bolt hole won't be used on the trans to engine block. I'd ruffly say most trans that came from 98/99ish and older are more likely to be a gen2 trans. So just something to keep in mind if someone is searching for a 4l60e and isn't aware that not all of them are the same.
If using stock efi, I'd go with 4l60e, 65e or 80e. The 80e is a bigger and heavier trans, overkill for most mild LS stuff.
If going carb over efi on LS engine, (what I'm going through right now) it does get pricey with not only the stand alone controller, but you need a throttle position sensor which is about 130$. The TCI brand controller is nice bc it comes with a handheld cpu. Can't give much more on it as I don't have it yet.
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc
http://67-72chevytrucks.com/vboard/s...d.php?t=382481
49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold
http://67-72chevytrucks.com/vboard/s...d.php?t=594874
VIDEOS https://youtu.be/E8zHhjgS_lA
Geronimo 54' LS engine, static drop IFS, Client build, just about done
http://67-72chevytrucks.com/vboard/s...62#post7399162
52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame
Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next!
www.coffeeandcustoms.com
99 to Life is offline   Reply With Quote
Old 01-17-2017, 10:44 PM   #558
CoreyH
Re: S10 Swap how to
I did a little more research on it. My motor is a 2001 and I can get an 04 4l60e so I'll go that route. EFI cable throttlebody is how I'm going to go. I can use my PCM and just have it flashed with a 2001 silverado OS and I believe it controls transmission as well. Those trucks had the 4l60e in them already so should be just fine
Old 01-19-2017, 09:41 PM   #559
skymangs
skymangs's Avatar
Re: S10 Swap how to
Dear Sorry Hussey, I just assumed he would use EFI. What dummy would you use a 5.3 without going EFI? I woul them d use the 4L60E and the PCM (flashed as a stand alone PCM) to make that puppy go!
But if you do have the PCM flashed, use Brennen at lt1swap.com, he is the best in the business.
skymangs is offline   Reply With Quote
Old 01-20-2017, 10:19 AM   #560
reaper71
reaper71's Avatar
Re: S10 Swap how to
His name is Brendan and he lives 10 min. from me here, and yes he does a great job on all the flashing and harness work.
I have now used 4 harnesses from him and his quality is above and beyond.
Mark...
Old 01-20-2017, 12:53 PM   #561
skymangs
skymangs's Avatar
Re: S10 Swap how to
Sorry, stupid Dragon speak, I know his name is Brendan, I drove the 4 hours down there just to have him diagnose one of my projects. He is a great guy, and truly one of the best in his field.
Old 01-20-2017, 05:14 PM   #562
reaper71
reaper71's Avatar
Re: S10 Swap how to
Yes he is a really good Guy and a friend of mine!
If your ever headed this way again give us (ME and Dad) a shout and stop by the shop!
Mark...
Old 01-21-2017, 10:36 AM   #563
skymangs
skymangs's Avatar
Re: S10 Swap how to
Will do, always a pleasure to meet fellow enthusiasts.
Old 02-23-2017, 05:22 PM   #564
mxer666
Re: S10 Swap how to
Skymangs,
I just completed my first AD on an s10, and your info was invaluable.
I want to thank you, like so many before me.
Now, I have a question that I am sure has been asked many times.
With my first build, I shortened an extended cab frame 4" to work.
For this now next build, I have access to an already bagged truck at a great price. But, it's a single cab shortbed.
I'm sure people have extended frames, probably at the same factory joint.
Any problems w/ that?
thx
mxer666 is offline   Reply With Quote
Old 02-24-2017, 05:05 PM   #565
joedoh
joedoh's Avatar
Re: S10 Swap how to
dont cut the frame at the joint, cut off the last 11" of the frame and flip it over, then cut/drill out the rivets for the front leaf hangers and move them back 8". this moves the axle back 8" and makes the wheelbase perfect. it also moves the front perch up slightly along the frame which lowers the truck about an inch for free. make sure you move the front perch 8" straight back, not 8 inches diagonally up the frame, which would be slightly less than 8" straight back. but its super easy, should only take an hour or so to do.
I learned this from 62chevy on here, he has the pictures of how to do it on his build. it works PERFECTLY, there are no downsides, I did it on my shortbed s10 chassis under my 65 swap before the back half.
Old 02-24-2017, 05:43 PM   #566
Clay54
Re: S10 Swap how to
Here is the link to 62chevyll's build which outlines what joedoh mentioned. Clay
http://www.killbillet.com/showthread...-(step-by-step)
Clay54 is offline   Reply With Quote
Old 02-24-2017, 09:45 PM   #567
joedoh
joedoh's Avatar
Re: S10 Swap how to
thanks clay! I use his bed floor trick too!
62chevy also lives in wichita, and is also named russ. the co-inky-dinks abound
Old 03-03-2017, 11:59 PM   #568
ClevsChev
Re: S10 Swap how to
Sorry, I didnt read through all these pages to find the answer but.. If i made my rear mount higher on a 53 cab could I just bolt straight through instead of using the shackle mount the 53 came with?
The previous owner cut them off taking the cab off and the cheapest replacement i have found was 219$ for new rear mounts.
ClevsChev is offline   Reply With Quote
Old 03-04-2017, 12:32 AM   #569
joedoh
joedoh's Avatar
Re: S10 Swap how to
its literally the third post in this thread, there is a pdf of mount dimensions and what to do about completely replacing the shackle mounts on the 51-54 cabs. I am not sure this thread even talks about keeping the shackle mounts, so you should be good!
Old 03-04-2017, 12:39 AM   #570
sscjwl
Re: S10 Swap how to
[QUOTE=skymangs;6723893]I've been asked lots of questions about how I get these S10 swaps done so quickly, and how to do "x" or "y"... I want to start this thread detailing as much as I can on the nuts and bolts of S10 frame swaps, parts lists, pics, and any other frequently asked questions out there. To start this off, there are basically three options I see as easily attainable for an S10 frame swap. Keep the stock 4.3L, go small block, or go LS1. I will start off with small block parts, as these are by far the most popular conversion.
What you'll need:
-47-54 Chevy pickup with bed, fenders, hood, core support
-S10 chassis (117" w.b. long bed short cab) If you can, score the brake pedal, master/booster assembly and power steering box.
-Engine/trans combo of choice
I am starting to part out my 2003 s10, but I was wonderful my if there is anything else I should hang onto for my 50 Chevy swap. A/c components? Power brake stuff? 4l60e tranny? Wiring harnesses? Any comments would be appreciated. Thanks,
Jon
sscjwl is offline   Reply With Quote
Old 03-04-2017, 09:57 AM   #571
skymangs
skymangs's Avatar
Re: S10 Swap how to
[quote=sscjwl;7875871]
What you'll need:
Jon
is it a 4.3, if so save all the brake stuff and the trans
Old 03-04-2017, 10:04 AM   #572
sscjwl
[QUOTE=skymangs;7876005]
Only a 2.2. Wont the tranny work for a 350 though?
Old 03-04-2017, 11:09 AM   #573
skymangs
skymangs's Avatar
Re: S10 Swap how to
nope bellhousng's to small
Old 03-08-2017, 10:29 PM   #574
ClevsChev
Re: S10 Swap how to
I might have missed it, but what did you use for bushings on your motor mounts?
Old 03-08-2017, 10:46 PM   #575
skymangs
skymangs's Avatar
Re: S10 Swap how to
you did, i use 85 camaro mounts
