Old 02-26-2016, 02:21 PM   #551
Mrturner1
Re: Starting my engine build
This is the trans mount recommended for my application but my truck doesn't have original tranny
Mrturner1 is offline   Reply With Quote
Old 02-26-2016, 02:23 PM   #552
Grumpy old man
Grumpy old man's Avatar
You may want to do some research on body and suspension mounts before you spring for urethane squealers that can creak and moan and will drive you nuts everytime you turn a corner .a lot of guys bought them and then took them back out and used rubber .
1967 Factory short bed - Old school
'71 - 350 / 4bolt / 487 heads / Edelbrock C3BX
Muncie M-22 4 speed / Hurst Comp plus
Factory 12 bolt posi 3.73 / 255-70-15
Smoothed firewall / Factory cowl induction
Power disc brakes / power steering / 3.5-5" drop
Grumpy old man is offline   Reply With Quote
Old 02-26-2016, 02:25 PM   #553
Grumpy old man
What trans is in it ?
Old 02-26-2016, 02:26 PM   #554
Mrturner1
This is interesting, I'll start researching now and read up. Any suggestions on crossmember for my truck and correct trans mount? I don't mind forkin out some dough if need be, I just want to make sure it's right
I'm so excited to drive it with new mounts, it's gonna feel a lot faster and smooth
Old 02-26-2016, 02:27 PM   #555
Mrturner1
Originally Posted by grumpy old man View Post
what trans is in it ?
th400, thanks for the quick reply grumpy
Old 02-26-2016, 05:39 PM   #556
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Stick with stock rubber mounts. Unless you like excessive squeaks and vibrations.
Leave the urethane mounts for the drag strip on a drag only rig.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 02-26-2016, 07:19 PM   #557
Mrturner1
I'm glad I asked because having done all that work to get squeaks and vibration would be a bummer
Old 02-26-2016, 09:01 PM   #558
Mrturner1
Just a small update, did a lot of running around today and put together some parts to finish up the engine/transmission build. It's getting close and that makes me nervous but also very excited.
I took the chrome water pump off and got a nice plain one to paint orange. I decided 215.00 bucks is too much for a water pump when I need transmission parts and mounts and fluids so I'm prepping and painting the water pump, and also doing some prep in the motor well. Little bit of masking and that should be ready for the first coat of black.
Old 02-26-2016, 09:03 PM   #559
Mrturner1
Got all my transmission parts rounded up. Picking up the rubber mount tomarrow, decided against Prothane
Old 02-26-2016, 09:05 PM   #560
Mrturner1
parts
Old 02-27-2016, 02:52 AM   #561
swamp rat
swamp rat's Avatar
Nether the chrome water pump or this pan are necessary..
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 02-27-2016, 03:59 AM   #562
Mrturner1
The water pump was too expensive, but I like the pan a lot. It holds 3 extra quarts of fluid and is already drilled and tapped for the temp gauge. Anything to keep that transmission cool!
Old 02-29-2016, 01:13 PM   #563
Mrturner1
Alright!! I got the engine lift ready, the motor well all painted up in semi gloss black, and I cleaned up and painted the perches that bolt to the motor mounts. There's nothing left to do but drop it in and bolt everything up, and then the break-in! I'm pretty nervous about the startup, but I've gone over everything I did and I read ALOT, so it should go good.
I'll have some pictures up of the motor well all painted and the progress of the engine going in soon. Anything you guys want to add or some things I might've forgot would be greatly appreciated
Matt
Old 02-29-2016, 02:01 PM   #564
Mrturner1
Do you guys use break in oil during initial startup and breakin? I have assembly lube and break in moly on all the parts, so I'm wondering if 6 quarts of actual break in oil are needed?
Also, do you guys bolt on the motor mounts AND the perches to the engine and drop it in, or do you bolt the perches to the frame?
Old 02-29-2016, 02:02 PM   #565
Mrturner1
Fresh paint
Old 02-29-2016, 02:03 PM   #566
Mrturner1
Old 02-29-2016, 02:36 PM   #567
Mrturner1
In she goes
Old 02-29-2016, 03:25 PM   #568
Average Joe
Average Joe's Avatar
Looks great!
I bolt the motor mounts to the motor and bolt the towers to the frame.
I have had to loosen bolts on one or the other if the main bolt was being stubborn.
Use break in oil as well as a good zddp additive if you want your cam to live.
Make sure motor fires off quickly and keep your rpm above 2k for first 20-30 minutes. Valvoline Vr1 should be sufficient. I heard it was on sale at Autozone this month. Fyi.
Be careful with dist. on install. I usually install after motor is already in.
Good luck, have fun, and have a beverage or two😎
Also make damn sure you get the torque converter fully seated in the trans before you bolt up the flexplate.
1967 C10 Suburban 454/TH400/3.07's
An Average Joe and His 'Burb:
http://67-72chevytrucks.com/vboard/s...d.php?t=775843
Average Joe is offline   Reply With Quote
Old 02-29-2016, 03:36 PM   #569
Mrturner1
Originally Posted by Average Joe View Post
Looks great!
Thanks man! I'm sweatin bullets lol
Old 02-29-2016, 03:37 PM   #570
Mrturner1
Pic
Old 02-29-2016, 03:38 PM   #571
Mrturner1
Pushed on the torque converter and it went one click and it wouldn't go a second so I backed it off and turn it a little and it slid way on. There's at least an inch between the converter and the outside of the bell housing
Old 02-29-2016, 04:04 PM   #572
GASoline71
GASoline71's Avatar
Looks good!
When seating a converter you should feel 2 distinct "thunks" One when it engages the input shaft splines and the second when it engages the oil pump. If you don't get that second "thunk" you will destroy your tranny oil pump.
When you bolt the bellhousing up to the engine you should have to pull the TC forward towards the engine a bit to get it to touch the flexplate. Just make sure you have your flexplate on the correct way.
That deep transmission pan might not clear the crossmember, but you won't know until you go to install it.
Gary
Old 02-29-2016, 05:44 PM   #573
Mrturner1
Originally Posted by GASoline71 View Post
Looks good!
Gary
I was just getting ready to ask if the converter should have to slide a bit towards the flexplate when bolting it on. Thanks for the reply!
Old 02-29-2016, 05:45 PM   #574
Mrturner1
Pic
Old 02-29-2016, 05:48 PM   #575
Mrturner1
