07-26-2020, 10:15 PM | #551 |
60-66 Nut
Re: Johns 66
To bolt up the front suspension and related components, I would just go to either Fastenal or a local hardware store and get some grade 8, 7/16 -14 bolts, SAE flat washers and top lock nuts. If you need to know the lengths, let me know and I'll see what I can do.
07-27-2020, 07:29 AM | #552 | |
Re: Johns 66
Former Decorated Combat Marine...Semper Fi!! Instagram jorourke322 Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=734699 2019 GMC AT4 |
07-27-2020, 11:29 AM | #553 | |
Re: Johns 66
There's also another option.... I've ground the shaft flat in that area so a standard flat spacer can be used. This was during a disc swap & various years of parts were utilized. I don't know exactly what you have but I know there's more than one way to solve the dilemma.
07-27-2020, 11:57 AM | #554 |
Re: Johns 66
John not sure what all bolts you're needing but a local place here has full front end bolt kits for a littel cheaper then going to the hardware store and they are correct length and tapered.
http://sokyclassics.com/product.php?skcid=1003942 They also have a stainless option and they are really quick at shipping. Best of luck! |
07-27-2020, 04:07 PM | #555 | |
Re: Johns 66
07-28-2020, 11:15 AM | #556 | |
I'm just glad to be here!
Re: Johns 66
Are you looking for item #9 in the attached diagram or the round washer that is flat on one side and concave on the other side that goes against the frame between the frame and the shims (item #8)?
Karl 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square |
07-28-2020, 04:02 PM | #557 | |
Moderator
Re: Johns 66
the concave washers - POL has new ones. Or contact Aspen Truck Parts in Arizona for used. Hinges to doors etc. - I used LMC Truck Parts.
07-28-2020, 05:58 PM | #558 | |
Re: Johns 66
The ones I took off were round, if I remember correctly one set had a concave face and one set had a convex set. Based on the drawing you posted they definitely go ion Bolt #7
07-28-2020, 06:12 PM | #559 |
Re: Johns 66
Thanks for the info...I looked on the POL website but couldn't seem to find the concave washers....do you happen to have a link
07-28-2020, 06:20 PM | #560 |
Re: Johns 66
I found this pic of what I am needing....maybe this helps
07-29-2020, 08:43 AM | #561 | |
Moderator
Re: Johns 66
07-30-2020, 01:09 PM | #562 | |
Re: Johns 66
07-30-2020, 01:12 PM | #563 |
Re: Johns 66
Well I may not have any bolts to put things back together....but Babe got a new set of shoes today with a lil bling to go with it
07-30-2020, 01:50 PM | #564 |
Re: Johns 66
Looking good.
07-30-2020, 02:41 PM | #565 |
Re: Johns 66
That is the one I was trying to describe. I have seen them available from somewhere but can't remember where.
I see that Rocknrod found a link to a similar part at POL, looks like those should work.
07-30-2020, 04:57 PM | #566 |
Re: Johns 66
07-30-2020, 06:51 PM | #567 | |
Re: Johns 66
Big Moe..... The rear is 5.5" backspacing, and the fronts are 4.5" front tires are 245/50/20 and the rears are 275/45/20
07-30-2020, 07:23 PM | #568 |
Re: Johns 66
The more stuff I do and buy for my truck the more I am amazed at things and how businesses are run...Some you can tell are small businesses and try their best to take care of the customers, some seem like bigger businesses and don't have a clue.
For example....I bought my wheels and tires from a guy in Atlanta, Russ.....I told him what I had as far as vehicle, told him what I wanted and poof....he has them on the way. I paid 1750.00 for Ridler 5 spoke wheels...there were mounted and balanced with a set of lugnuts and were delivered to my door, when they said there were gonna be here...in perfect condition. Second example is I got my rear axle conversion kits yesterday from CPP....They sent me 4 boxes...and boxes weren't damaged...So I waited until today when I got my wheels to make sure they mated up. Come to find out they sent me an extra kit of axles, drums etc....Of course trying to do the right thing I called them....and after waiting 20 minutes on hold they had no clue that 1. that they sent 2 sets, or 2. how to get them back. I checked my account and I was only charged for 1 set. I asked the guy to send me a call tag and have the extra set picked up....it was like a foreign concept. Anyways they were the right ones and mate up to the wheels perfectly.....One last thing is that I paid 344.00 with taxes and of course they are made in china.....Im amazed that they can make these, send them on a boat and be cheaper than if it was made here.
07-30-2020, 10:38 PM | #569 |
Re: Johns 66
Dadgum, those are some fancy wheels! That is pretty weird that they didn't even realize they sent 2 sets for the axles
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
07-30-2020, 10:43 PM | #570 | |
Re: Johns 66
They eventually did sent me some return labels and Ill get them sent back tomorrow....as they say....Never wrong to do the right thing.
07-30-2020, 10:51 PM | #571 | |
Re: Johns 66
08-01-2020, 02:18 PM | #572 |
Re: Johns 66
Welp I have ordered some grade 8 bolts from Wholesalebolts.com...so we will see how that goes.
So I went over to my brother in laws, Randy's shop to check on ole girl.....and didn't like what I saw.....There were about 3 places that the primer had cracked and flaked off...not really sure why... Im gonna go to a local body shop and see what they say it could be...Im afraid I will have to take it all back down to metal...but would rather do that that have the paint flake off. They sprayed my buddies truck a few years back and did a great job...may see what it cost for them to spray the color, especially after the cracked primer revelation. Also found a shop to rebuild my rear end and do the axle swap for me.....gonna run me 150.00 but think its worth it...don't want no issues with the rear end......so Ill get it pulled out this week and get that taken care of...And when the bolts arrive the chassis is going back together!!!!!!!
08-01-2020, 06:31 PM | #573 |
Moderator
Re: Johns 66
I was looking at those wheel. Good job. I recognized the first pic.
08-03-2020, 10:14 AM | #574 |
Re: Johns 66
I found a set, but they are slightly thicker than the one in the picture. $10 to cover shipping and they are yours if you want them.
Karl
08-03-2020, 11:04 AM | #575 | |
Re: Johns 66
Do you happen to have the big washer bolts that go on the inside at the bottom of the front fender?
