Old 05-30-2021, 10:53 AM   #551
SkinnyG
SkinnyG's Avatar
Re: SkinnyG's '61 Apache
I should meet this guy....
Ok, ok....
On one hand I'm a little lazy and I want the easy option.
On the other hand, I don't want to ruin the originality of the truck.
On both hands, I don't even know what that last sentence means.
I'm formulating a plan.
In other fitment ideas, I originally intended to fit air tanks inside the backs of the stepside fenders, figured I could mount two three-gallon tanks in there.
Road grime concerns me with the longevity of the tanks there, but as it turns out, the five-gallon tank that came with my kit should fit just fine against the driver's rear X-brace leg, beside the driveshaft.
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, turbo, LS
1977 Silverado: Shortboxed & dropped, potato-potato
V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag
Lotus Super 7 Replica: Scratch-built street-legal rollerskate
SkinnyG is offline   Reply With Quote
Old 05-30-2021, 09:06 PM   #552
caseyjones
Originally Posted by SkinnyG View Post
Which kit is this?
caseyjones is offline   Reply With Quote
Old 05-30-2021, 11:05 PM   #553
SkinnyG
SkinnyG's Avatar
It's the Revell '65 C10 stepside truck, with the AMT '60 Apache fleetside bed.
I bought both kits to build a '60 step side into what my '61 will be. My kid is building with the cast-offs.
Helped a buddy repair his tire machine, then tried pounding the bed sides straighter, then decided to blast.
Half hour of blasting:
Old 06-01-2021, 10:38 AM   #554
SkinnyG
SkinnyG's Avatar
As an in-between, I drew up a brake caliper adapter for the back axle. This is v2, because apparently I can't measure.
Old 06-02-2021, 10:33 PM   #555
SkinnyG
SkinnyG's Avatar
Did not do any blasting yesterday, as it was stricken with "too dang hot outside." Last week it was two jackets to drive the 7 to work, yesterday was "I wish I had shorts."
I -did-, however, get 45 minutes of blasting done today, but I think I was heading to heatstroke. My heart was absolutely pounding while I blasted (could hear it with my ear plugs in), and was absolutely wiped. Came in for a shower and tried not to just curl up on the floor and sleep.
Maybe I'll do a bit less of it tomorrow.
About 15 minutes of blasting on the outside of one bed side.
Old 06-04-2021, 02:14 AM   #556
SkinnyG
SkinnyG's Avatar
Met with the window folks to get a quote for replacing windows in our house. Wow. THAT is pricey.
Welded brackets onto a buddy's bumper bar to mount a splitter.
Trial fitted V.4 of the disc brake adapter. Fits REALLY well, and now just needs final welding (no, the vice grips are not staying):
Old 06-04-2021, 09:43 AM   #557
SCOTI
SCOTI's Avatar
LS1 style disc set-up w/the shoe in hat e-brake?
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 06-04-2021, 09:46 AM   #558
SkinnyG
SkinnyG's Avatar
Z/28 calipers which operate the e-brake with the caliper.
Old 06-04-2021, 09:48 AM   #559
SkinnyG
SkinnyG's Avatar
Old 06-04-2021, 10:33 AM   #560
SCOTI
SCOTI's Avatar
Looking @ the caliper made me think 'caliper actuated e-brake' but I knew it didn't look like the traditional/common aftermarket street-rod Cadillac variety.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 06-05-2021, 12:26 AM   #561
SkinnyG
SkinnyG's Avatar
More blasting today. At least I did this in the evening - it was much more comfortable. The other side left to do. And the tailgate. And the braces. And the fenders. And the steps. Oh my.
Old 06-05-2021, 08:59 PM   #562
pdxhall
pdxhall's Avatar
That's a ton of work. I know, huh? But it sure is nice to work with a clean slate as you continue. You're doing some great work and I'm enjoying following your build.
Sanity'66
http://67-72chevytrucks.com/vboard/s...d.php?t=515110
Long bed, Fleetside, Small back window
I've Done So Much, With So Little, For So Long, That Now I Can Do Anything With Nothing.
pdxhall is offline   Reply With Quote
Old 06-06-2021, 02:44 AM   #563
SkinnyG
SkinnyG's Avatar
Lots of hammering and shrinking to get these bed sides flat again. Wow.
Old 06-07-2021, 10:58 PM   #564
SkinnyG
SkinnyG's Avatar
Ok, FIFTH try, and I'm confident enough to weld it all together. We now have 9"-Ford/Z-28/Caprice brakes.
Old 06-08-2021, 10:40 AM   #565
88Stanger
88Stanger's Avatar
Nice!!
John 3:16 - Saved me... God Bless
88Stanger is offline   Reply With Quote
Old 06-12-2021, 09:58 PM   #566
SkinnyG
SkinnyG's Avatar
Finish blasting the bed. Eight hours, ran the abrasive through about six times, then added a new bag which I ran though probably three times. Went through two plastic screens for the hood.
Overheated the compressor motor twice despite its own fan blowing on it and an extra fan blowing on it and another fan circulating air and the compressor shed door open to the outside. It's an IR 5hp 2-stage rated for 100% duty cycle. Odd.
Each time I waited for the motor to cool down, I worked on fixing the front fenders. Got this far, close-to-zero-filler TIG:
Old 06-13-2021, 06:33 AM   #567
The Rocknrod
Moderator
The Rocknrod's Avatar
Nice rear end set up, I sure like 9" rear ends.
Old 06-13-2021, 07:33 PM   #568
SkinnyG
SkinnyG's Avatar
Old 06-13-2021, 09:48 PM   #569
cwcarpenter98
cwcarpenter98's Avatar
That looks good on the fender repair. Did you have to fab a patch towards the top?
Christian Carpenter
Overdrive wiring here
1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed
1995 Dodge Dakota Sport
Old 06-13-2021, 09:50 PM   #570
SkinnyG
SkinnyG's Avatar
I did. The fender bottom patch is cheap, the back -half- fender patch is not. I happen to have some fabrication tools....
Old 06-13-2021, 09:59 PM   #571
cwcarpenter98
Just a few
It looks almost like a new, GM fender now
Christian Carpenter
Old 06-14-2021, 01:22 AM   #572
caseyjones
I can very much appreciate how much work went into that...excellent.
Old 06-16-2021, 10:52 PM   #573
Low Elco
Great stuff!
Low Elco is offline   Reply With Quote
Old 06-19-2021, 11:27 PM   #574
SkinnyG
SkinnyG's Avatar
Did some blasting of the left fender in prep for epoxy. Might get to epoxy tomorrow; I'd like to do both front fenders at the same time.
Worked on the air compressor pressure ON and OFF settings to try and reduce how much it the motor cycles. IR figures the motor goes into thermal protection because of the stops and starts, not the constant running. Motor is rated for 100% duty cycle.
Also tried the smallest blasting tip that would still pass sand in hopes of cutting down the CFM required. I did set the line pressure at 60psi and it seemed to last reasonably well.
Welded in the patch on the passenger side. Needs a bit of planishing, but should be ready for epoxy tomorrow.
Old 06-20-2021, 12:10 PM   #575
88Stanger
88Stanger's Avatar
Awesome work there sir!!!!
