Old 04-16-2025, 10:09 AM   #551
wpsharpshooter
wpsharpshooter's Avatar
Re: Previous owner '68
Looking good, I was hoping to eventually being able to take a drive up the road and lay eyes on this rig one of these days.. But things have taken a very positive turn for me and I am moving to Nashville.... Progress is looking nice though.
wpsharpshooter is offline   Reply With Quote
Old 04-16-2025, 01:42 PM   #552
raggedjim
raggedjim's Avatar
Nice, good luck in Nashville. Life has a way of working out if you just keep trying!
raggedjim is offline   Reply With Quote
Old 04-21-2025, 10:10 AM   #553
68Gold/white
LOL, Hackery IS the word!!!
68Gold/white is offline   Reply With Quote
Old 04-21-2025, 11:19 AM   #554
raggedjim
raggedjim's Avatar
When I was a kid there was an old guy who owned a service station in town and his last name was Hackery, it's always stuck with me!
Old 04-23-2025, 07:08 AM   #555
hewittca
hewittca's Avatar
Keep hacking away! What brand replacement panels are you using? Most of them need a fair amount of massaging anyway to fit right. I've been using Key Parts on mine and so far they have required minimum hacking. :-)
Builds: Green Gus the 68 C10 | Bluey the 72 1500 | Lowly the 70 C10 | Oscar the 70 C10
C10 Concept/Development Photos: Master Thread
hewittca is offline   Reply With Quote
Old 04-23-2025, 09:17 AM   #556
raggedjim
raggedjim's Avatar
Key Parts for most, I think the a and b pillars may be some other brand.
Old 05-06-2025, 08:25 PM   #557
raggedjim
raggedjim's Avatar
Been working on the inner windshield area. Not fun, a lot of overhead welding and grinding. Hopefully near the end of the over head work.
Some duraglass and filler and she'll look fine.
Old 05-06-2025, 09:41 PM   #558
72 tigger
72 tigger's Avatar
You’re doing a great job!
71 C10
72 K20
72 K10 Super
Kirk
72 tigger is offline   Reply With Quote
Old 05-07-2025, 09:28 AM   #559
loudchevy
loudchevy's Avatar
That is a long joint to work on, overhead to boot. Nice job!
Scott
1970 C10 Restomod|454/700R4|LWB-->SWB Build Thread
2014 2500HD DirtyMax|Daily Driver|Stock
2003 Tahoe Stock
1985 K5 5.3LS/4L60E|8Lug 4:56|3/4 Ton Front|14BFF Rear|Roll Cage|Dove-tailed & Bobbed
loudchevy is offline   Reply With Quote
Old 05-07-2025, 09:56 AM   #560
raggedjim
raggedjim's Avatar
Thanks guys. It is a long seam, I probably spent 8 hours total spot welding, letting it cool, then grinding. The good thing is it has a curve in it so it resists warping, but I still took my time.
The only thing I worry about is pinholes. I spent quite a bit of time trying to make sure it is solid and I'm going to spread some duraglass on it so hopefully I won't have any problems.
I'm trying to think of a way to get through the visor hole and spray the back of the weld to help prevent rust.
Old 05-08-2025, 08:16 AM   #561
jaros44sr
jaros44sr's Avatar
Eastwood sells a long flexible nozzle for spray cans, made in Italy. It’s about 2 feet long
image by [url=https://www.flickr.com/photos/97391199@N06
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 05-08-2025, 08:47 AM   #562
raggedjim
raggedjim's Avatar
That would definitely do it, Thanks!
Old 05-22-2025, 10:22 AM   #563
raggedjim
raggedjim's Avatar
Started in on the door channels. Not too bad of an area to work on.
Old 05-22-2025, 10:25 AM   #564
raggedjim
raggedjim's Avatar
I also worked on the inner cab in the same areas. Hopefully this will get the worst of the rust repairs done and I can focus on welding up unwanted features.
Old 05-22-2025, 10:29 AM   #565
raggedjim
raggedjim's Avatar
Pretty sure this antennae hole started most of the rust problems with the cab. It sat in the weather for who knows how long with the hole in the roof. No hole anymore!
Old 06-19-2025, 07:10 PM   #566
raggedjim
raggedjim's Avatar
Finally got back from vacation and stated in on the firewall. Still have a long way to go as far as the cab is concerned. I hadn't really planned on spending so much time on the cab but sometimes the truck determines the timeline instead of me!
Old 06-19-2025, 07:12 PM   #567
raggedjim
raggedjim's Avatar
Also spent a few days building a pre-filter for my MrCool unit. Hopefully it will help it last longer, I generate a lot of dust!
Old 06-19-2025, 07:18 PM   #568
raggedjim
raggedjim's Avatar
My 94 work truck started leaking trans fluid pretty bad so I decided to take a look at it. It had a bad pan leak and it turned out the transmission mount had collapsed and the trans pan was sitting on the cross-member! While working on it I found that the carrier bearing, 2 u-joints, and the rear seal were also bad. Finally got it all together and it is running as good as it always has.
Only took one pic, pretty boring stuff.
Old 06-21-2025, 07:39 PM   #569
68Gold/white
I have a 25X25 steel building garage, It is insulated. Was thinking about one of those mini split units for it...
How big of an area is yours cooling/heating?
Old 06-22-2025, 10:31 AM   #570
raggedjim
raggedjim's Avatar
The area I'm using it in is 24x30 with a 10 foot ceiling. I've been impressed by it, today it's 98 outside and 71 inside. When it got below zero for a week this winter it kept it at 68. It's a 24k unit, you need around 35 btu's per square foot so you would need a 21k-23k unit, might as well get the 24k.
I installed it 3 years ago and finally got around to building a pre-filter for it. If you are doing the kinda stuff I am it needs one.
Old 06-22-2025, 05:21 PM   #571
sfont66
sfont66's Avatar
Awesome job getting after the rust repairs on the cab!
You Sir have skills, and a lot of ambition.
I was trying to catch up on some other portions of your thread, but when I try it tells me “ the server is too busy”
I’ll have to try again later
72 C10, Was a 350,M20, Brodix heads,Comp cam, Edelbrock intake&carb, Hedman hedders LWB.
Project is now a 5.3(L33) w/PRC stage 2.5 CNC ported 243heads, FAST 102/102, FIC injectors,BTR RedHot cam,Holley Terminator X, T56 magnum. SWB, Boyd tank. 4.5/4 Drop http://67-72chevytrucks.com/vboard/s...My72c10project
sfont66 is offline   Reply With Quote
Old 06-22-2025, 06:06 PM   #572
raggedjim
raggedjim's Avatar
I'd have been better starting with a better cab but they are hard to find. I like the idea of repairing something most people would have scrapped but the truth is it is wearing me out!
Old 06-25-2025, 12:38 AM   #573
wpsharpshooter
Looks like its coming together.. Nice.. hopefully will have mine back soon.. I ended up throwing my wallet at a vintage air unit for it..
Old 06-25-2025, 09:39 AM   #574
raggedjim
raggedjim's Avatar
That'll be nice, I probably will one day.
Did you move to Nashville?
Old 06-25-2025, 10:48 AM   #575
wpsharpshooter
Yes sir. Been here almost a month now.. And With the addition of the ac unit. I'm hoping the truck will be back in action in the next few weeks
