Closed Thread
Old 07-14-2012, 06:35 AM   #5751
C-10cutty
C-10cutty's Avatar
Re: What did you do to your truck today?
Originally Posted by doobiebro View Post
sweet truck...did you shave the front tire?
Yes, did one. Wanting to find the extent of the white rubber on the sidewall of a skinny WW.
C-10cutty is offline
Old 07-14-2012, 08:45 AM   #5752
jbgroby
jbgroby's Avatar
Originally Posted by MARTYZ View Post
No i don't mind at all , thats why we look at this forum to share and get ideas , need to come up with latch for the lid. 70 mph it stands straight up! you getting this hot weather in cambridge too!!
Since it has the "really Old School Look" why may an antique style lock for show and use a modern lock when out and about.
Such as this?
http://www.ebay.com/itm/1850s-Origin...item2c66c7a4d1
Jake
jbgroby is offline
Old 07-14-2012, 09:07 AM   #5753
CRGRS 66
CRGRS 66's Avatar
Such as this?
Jake
Cool, Marty there is an antique shop on 8, on the way to sauble on the right hand side, a little more than half way to sauble from hepworth... maybe they have something cool there
Craigerrr
My build thread, CRGRS 66 Winter Build: http://67-72chevytrucks.com/vboard/s...09#post5638709
CRGRS 66 is offline
Old 07-14-2012, 11:44 AM   #5754
goirish78
I swapped out my old cracked valve cover for a nice new dress up chrome one!! Looks pretty. Question for u guys tho: I have 3 holes in the new valve cover. My new breather cap is in the front one just like it was. The hose is going in the back one just like it was. Below the front hole tho, on the driver side of the valve cover is another same size hole. I have nothing to put in it. Is it a oil filler hole maybe? If so what do I put in it while it's running? I'm assuming it has to be plugged. HELP??!!!!!
It's a 230 Chevy L6. 63 Chevy c10 short/step. Thanx men
VIC OUT
goirish78 is offline
Old 07-14-2012, 02:01 PM   #5755
Cody63
Lowered my '63 with a 5/4 drop.
Ended up having to cut the front spring by one full coil to get it to level out.
Looks sick now. So excited.
Hopefully this weekend I'll get my front sway bar on.
Cody63 is offline
Old 07-14-2012, 03:01 PM   #5756
chevy_man5
GMC's n H.D.'s too!
chevy_man5's Avatar
We adjusted the brakes out, then took her for a drive around the neighborhood, and she stops now!!
Then we pulled off both diff covers to verify if when a P.O. swapped out the rear axle, they matched the front. From what I can tell they are the same, but I have to find some info to make sure.
Jason
1960 GMC 4x4 Babe (the Blue Ox) - Build Thread
chevy_man5 is offline
Old 07-14-2012, 05:05 PM   #5757
MARTYZ
MARTYZ's Avatar
Yes I know the place , only 10 minutes from home I will check it out, going to go rumagew through the barn again may find something there. If your ever up thos way send me a pm and we can meet up. They have a real good cruise night at thd beach on Tuesday nights, 100 plus cars in July and Aug. Sandfest show in August is a good one too over 400 last year. I'll do the same if I get down Cambridge way
MARTYZ is offline
Old 07-14-2012, 05:52 PM   #5758
cb1965
cb1965's Avatar
Originally Posted by MikeS. View Post
What? It hit 85?
Well, maybe not too hot but hot enough to be working under the direct sun doing somewhat heavy work.
'66 chevy lwb c10
'65 chevy lwb c20
cb1965 is offline
Old 07-14-2012, 06:06 PM   #5759
tincan1966
tincan1966's Avatar
Just made the credit card scream and ordered 16 pieces of sheet metal for the body repairs. So....if anybody needs me over the next two weeks- look for the welding glow.....
tincan1966 is offline
Old 07-14-2012, 06:10 PM   #5760
gimmy 64
VIC OUT
thats for smog pump hook up just buy a breather with rubber gromet and plug it in
gimmy 64 is offline
Old 07-14-2012, 10:35 PM   #5761
ABX131
ABX131's Avatar
Got the old tranny out, now I need to get the replacement unit in......
ABX131 is offline
Old 07-15-2012, 12:46 AM   #5762
goirish78
Thanx man!! Preciate it
Vic
Old 07-15-2012, 12:59 AM   #5763
Woogeroo
I worked on lining the door back up to the door latch after replacing the door pins and bushings last weekend.
I think it is close, it may need a little more tweaking.
-W
Woogeroo is offline
Old 07-15-2012, 10:09 AM   #5764
Cody63
Got my front sway bar on. Wow, what a difference.
Great add on.
Cody63 is offline
Old 07-15-2012, 11:23 AM   #5765
E911manager
Flipped a coin to see which one I would work on today. It landed on tails so it was the barn find project. Started by cleaning up the engine and start working on a breaking the engine loose.. I found an old points and rotor still in the package while I was going through this thing.
One question is the rubber floor mats appear to be original and in great shape. But there is a thin foam sheet under it. It is formed to the floor pan and it appears to be factory. It has holes in the right places. So is that factory?
My Build CAPRICKUP 1964 Chevy SWB on a 94 Caprice
http://67-72chevytrucks.com/vboard/s...d.php?t=492640
E911manager is offline
Old 07-15-2012, 11:41 AM   #5766
LT1 Burb
LT1 Burb's Avatar
Yes the foam sheets are factory.
LT1 Burb is offline
Old 07-15-2012, 07:00 PM   #5767
jbgroby
jbgroby's Avatar
Put her eyes in.
jbgroby is offline
Old 07-15-2012, 07:51 PM   #5768
chevy_mike
Never Ending Projects
chevy_mike's Avatar
Troubleshooting a bad miss since my drive back from the Brothers Truck show last weekend. Ran a compression test and all the cylinders were within 10 psi (155-165). Since I had no idea how old the cap, rotor and plug wires were, I replaced them and the spark plugs as well. From what I can tell, seems to have solved the problem. Running like it was before the miss started. Yea!!!
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline
Old 07-15-2012, 08:16 PM   #5769
markeb01
Senior Enthusiast
markeb01's Avatar
VIC OUT
Depending on the size of the hole, there are also generic valve cover grommets that are plugged:
http://www.jegs.com/i/JEGS-Performan...rentProductId=
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
markeb01 is offline
Old 07-15-2012, 09:48 PM   #5770
wrecked36
wrecked36's Avatar
Re: BEST ANSWER EVER!!!!!!
I drove it. I drove the spit out of it!
Big Jim
1966 C10 Short/Fleet canary yellow-I call her "Big Bird"
1979 K10 Short/Fleet blue-I call her "Cold Blue Steel"
2008 K2500 Duramax Crew Cab black paint I call him "Sir"
2006 H-D Street Glide black cherry paint I call her "Expensive"
wrecked36 is offline
Old 07-15-2012, 09:57 PM   #5771
Sneaux
Sneaux's Avatar
Started the new motor for the first time. Got some timing and overheating issues to workout.
Sneaux is offline
Old 07-15-2012, 11:03 PM   #5772
towersddg9
towersddg9's Avatar
Got one inner fender in
towersddg9 is offline
Old 07-15-2012, 11:18 PM   #5773
1enick72
1enick72's Avatar
Upgraded some upper engine parts, new distributor, 58mm BBK throttle body and SLP TPI runners. Can't wait to go for a spin
65 short step
edited by staff
1enick72 is offline
Old 07-16-2012, 09:25 PM   #5774
198plus
198plus's Avatar
Put one wheel on today........
198plus is offline
Old 07-16-2012, 10:11 PM   #5775
E911manager
More body work!!!!!
Closed Thread
