#5826 |
Re: What did you do to your truck today!
I was finally able to get her out of the garage for the first real drive in almost two years. The last time I drove it was right before my son was born - 20 mo ago. Since then, too many things have conspired against me getting it out again.
I had to replace a headlight - the screws on the retaining ring felt like they were made out of peanut butter! Only one of them came out. The other two were starting to strip, so it was a whole lot of penetrating spray, but still no luck. Then I heated them up with a lighter, cooled, heated again, more penetrating spray, heated, etc. and they FINALLY came out. Got the new headlight in, and well, it was underwhelming. Next project will definitely be the headlight relay upgrade. Still, I managed to get a decent 30 miles or so on the clock today, and I even talked my wife into coming along. All in all, it was a great day. |
#5827 |
![]() Join Date: Dec 2006
Didn't work on my truck today but I did order a Porterbuilt Mild Rear Dropmember
![]() Posted via Mobile Device
Keith 66 Suburban Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361 IG: bennett68c10 |
#5828 |
![]() Join Date: Jul 2007
I put together a "nose hanger" for mine so I can work on it in a tent instead of out in the weather. Hopefully I just have a blown head gasket rather than a cracked head or something worse. I have the Cad 500 and Turbo 400 sitting there but I'm not ready to do the swap in 25 degree weather and need to get my other car running before I take the truck apart that far.
#5829 |
RAT1968 '68 Cab/'71 Parts
I'm done for the day. I worked a little on the stance.
I am running the 338's (20 x 10 in back and 20 x 8.5 in the front) ans was unhappy with the backspacing. In fact, the rears, with 275 45's touched the bed on the inside, so I was running a 1" spacer in the rear. No spacer in the front with 245 40's The wheels still didn't fill up the wheel wells as well as I'd like. So, I took the 1's off the back and replaced them with 1.5's (nice billet ones at 150# torque) and replaced them with what I ordered at 1.5", and were *marked* 1.5", but turned out to be only about 1 3/8"...No biggie. Then, I put the 1" on the front. No rubbing, no issues. With spacers, I stay on top of the torques, using 150# for the spacer, and 90# for the wheels. People love to moan about using spacers. But I don't see any difference in the geometry relating to stress.... And if you aren't lazy, you check your wheels and wheel torques from time-to-time, anyway. Cheap insurance, as they say. Anyway, as far as looks go, in my opinion, there was a little difference in the rear, and quite a bit in the front.
M17 Coarsegold, CA RAT's shiny now. But always a rat. |
#5830 |
Where'd ya get the vac guage ? I want one!
'67 K-20 longbed 4X4, 350, SM-420, Vortec heads, flat top 4-brow pistons, Eaton 4.55's, Qjet, MSD 8365, Comp XE250H, Dynomax duals |
#5831 |
I just looked back at my last post. Those other pics were crap. It's too late to edit in order to dump them. Here are a few that will show the differences in the stance a little better.
M17 Coarsegold, CA RAT's shiny now. But always a rat. Last edited by magwakeenercew2jh; 01-22-2013 at 09:28 PM. |
#5832 |
Beautiful truck! I sanded on mine for two days!
#5833 |
laying low
![]() Join Date: Mar 2001
That's a lot better Mag. The wheels are more centered in the fenders now.
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
#5834 |
Forgot the pics..
#5835 |
Bought it from classic parts. Works great
Jeff 1972 Cheyenne Super SWB 350, Auto, Bucket Seats w/Console, Tach, Factory A/C, P/S ,P/B, Tilt 1998 Chevy 1500 Ext Cab 5.7, Pewter w/blue interior |
#5836 |
I haven't had to do much to my '84 and '70 pickup, but I'm slowly making progress with the Suburban. I rebuilt the carburetor on it today, tried to get it tuned up and now the vacuum advance went out. I made a video of it running yesterday before the carb rebuild, it was running pretty good considering how dirty it was.
RJD 1984 Chevrolet C30 welding truck 454/SM465 1977 GMC C15 pickup 350/TH350 1970 Chevrolet C20 pickup 350/TH400 1970 Chevrolet K20 Suburban 454/TH350 1969 GMC 8500 478M V6/5 spd winch truck |
#5837 |
Rebuilt the carb, mounted the tach, a little more rewiring, busted it off and moved it on its own power.
72 Chevy LB, LS in the works, 4L80, Grandfather bought it brand new. 66 GMC Short Step, 84 Front Suspension, many more mods to come 67 Chevy 3/4 Ton, 327, Auto, Factory A/C Ya must have been movin cause I was haulin a*$ when I passed you |
#5838 |
![]() Join Date: Dec 2012
Ordered my 3/5 static drop kit from ECE. Plus a new set of beauty rings...
Posted via Mobile Device |
#5839 |
![]() Join Date: May 2012
ole dollor gets an auto trans....well almost, got the four speed out, put the 168 tooth flex plate in , trans in, cooler lines run and installed , tried the 1 piece drive and its to long, well that happens, tried to put the starter on and it won't go, fly wheel to big, went to Lubbock to dropped off two piece drive shaft at drive line shop, shop said over $300.00 to fix it, i said no, found another drive line shop for about $150.00 with new carrier brg and step down joint...came back to Anton and ordered a new 153 tooth flex plate from summit racing , still no lokar shifter in the mail...so trans out ,flex plate out , ole dollor setting on stands....hope everybody else is having a better day....
#5840 |
![]() Join Date: Dec 2008
Dropped engine and trans in the frame & started the pluming:
![]() ![]() ![]() ![]() _________ My build: 1970 C10, 550hp LSX, Ridetech suspsension http://67-72chevytrucks.com/vboard/s...d.php?t=556610 |
#5841 |
Put on 4 1" spacers, I did not like how far the wheels were under the truck.
#5842 |
Can you post some more pics when done? I added 1/4 spacers but want to move them out a little more.
1971 C/10 - Orange & White 2009 GMC 1500 - Lowered 3/4 22' KMC Slides |
#5843 | |
With the different angle of the shots, these pics are as close as I could get to "before" and after" moving the 1" spacers from the rear to the front, and installing new 1.5" spacers in the rear. Naturally, tire size and wheel size and backspacing are all-important to fit and stance, but this may give you *some* idea. It appears to be a bigger (I think *better*) change in the front than shows on the pics. And the 1/4' wider in the back is really minor. But I like it better than before.
#5844 | |
#5845 |
I think a WTB post will get you some good offers from Forum sellers.
I think I paid about $60 (for each end) for good billet spacers.
#5846 |
I have a set of 2- 5 lug spacers ( think 1.25") I dont need anymore. They are quality aluminum and will sell cheap. They are just taking up space right now.
#5847 | |
when I get it out of the my shop I will take some more pix of it, wanting to paint my front drums before I install the front and its real cold here.. |
#5848 |
![]() Join Date: Nov 2012
Well, I've finally found my inspiration and ordered about $7k in parts to get started on the resto mod version of my '69.
#5849 |
Wow $7k that should be one heck of a start.
#5850 |
7K is a very nice start isn't it.
