Old 09-17-2012, 09:12 AM   #1
67cheby
67cheby
67cheby's Avatar
Re: 67 cheby's Dropmember build thread (CLOUD 9)
Originally Posted by XxCHEVYMANxX View Post
Hey Mike, have you figured out your column issue? I have a 67, and 68 non tilt columns, and they both have the same wire cover and two small tabs that it slides under. I couldnt find slots like yours anywhere on either column. Hope you already have it sorted out.
nope not yet ?? i dont know , anyone else have any input ?
Originally Posted by Xeen View Post
A couple of questions that could clear up a few things for us.
Is it a 1967 GM Truck Column, 36"L X 3/4" OD shaft?
Is it a genuine GM column or a Reproduction?
Is it tilt or non-tilt?
A little more information would be helpfull.
Im sure there are tons of experts on here that could help you with this, now if we could only get them to chime in.
it is a genuine GM column and it is tilt
Originally Posted by watahyahknow View Post
could it be that the slots are for tabs that are on the original cover itself?
it might be that the cover sticks in on one end and get screwed tight on the other end or that the tabs are hooked and on both sides and you need to push it in untill the tabs fall in the holes and the setup click shut , it would make more sense in a factory setup than using 4 clips to hold it down
I dont know i will look ?
67cheby is offline   Reply With Quote
Old 09-17-2012, 09:19 AM   #2
67cheby
67cheby
67cheby's Avatar
Sorry i have been slacking on updates so here are a few, Interior lights working, wipers working, installed the PAINLESS courtesy lights, Spal fan contoller installed, front clip completely wired, DELTA Hid's done, Complete wiring harness 90 % done includes Painless 18 circuit wiring, Painless EFI wiring, Spal fan controllers, Delta HID harness, Accu-air, Vintage air, and the DAKOTA DIGITAL VHX dash setup ......i have been wiring and plumbing for 2 weeks now about 1 week and the truck should be ready to fire up !! here are a few pics !
Old 09-17-2012, 09:27 AM   #3
67cheby
67cheby
67cheby's Avatar
and a few more, all the wire on the whole truck will be wrapped with PAINLESS CLASSIC Braid loom...this stuff is so cool has that cloth factory look but it is split like the plastic loom and wraps around the wires...it is too cool, here is a quick run of it that will be tucked behind my fender, i didnt spend a ton of time on it here since it will all be hidden. I used 6 way wiring plugs to make the front wiring able to disconnect if the front clip needs to come off. Also working on ac lines, in the process of blacking out the aluminum lines to make them disappear and on my third set of AC to compressor lines trying to achieve the look i want (i am still not thrilled ) I just got in my new bed reinforcement strips last week i will be running them in place of the standard cross braces (because they are shorter to go with the bolt on body drop) i ordered the ones without holes so we could tighten up the factory gaps in the wood...a little to wide in my opinion !
Old 09-17-2012, 09:44 AM   #4
smartass12
smartass12's Avatar
Your truck is amazing as you've been told a thousand times, been following it since i joined. A couple questions if you had a minute...Your fuel cell is set up for fuel injection right? I really like the price point compared to others (these builds add up quick). Second, it seems you completely scraped the old wiring and your rewiring all new? Just wanted to know if i cant throw away all my old wiring.
My 67 stepside build
http://67-72chevytrucks.com/vboard/s...d.php?t=522760
smartass12 is offline   Reply With Quote
Old 09-17-2012, 09:50 AM   #5
67cheby
67cheby
67cheby's Avatar
The cell does have a return line and yes i am running an outside fuel pump...i hope it works well we will see ! And yes i went to it because of price also , i hope that doesnt bite me later..LOL ! As for the wiring, it just depends on what all you will be running on your truck i have so many different things to power up that i needed to go to the 18 circuit wiring harness ...and of course the fact that PAINLESS sponsored my truck sure helped ALOT !!! I would deffinately recommend their product, very straight forward install !....quite PAINLESS...LOL
Old 09-17-2012, 09:57 AM   #6
smartass12
smartass12's Avatar
When you say bite you (fuel cell) should i wait to order it? Now you have me worried...Im sure i will need a PAINLESS as well with air management and such...speaking of which i guess im going to have to bite the bullet and call Nate..time to order more stuffhttp://67-72chevytrucks.com/vboard/images/smilies/crazy.gif
Old 09-17-2012, 10:00 AM   #7
67cheby
67cheby
67cheby's Avatar
well if you are going fuel injection i would think the ideal thing would be a tank with the fuel pump in it , this keeps the pump cool ! Plenty of people have done it with an outside pump like i am doing so it will probably be fine i would just prefer to go the other way...but price wise this was far cheaper ! i hope it works i will know soon ! anyone else have any input on this ?
Old 09-17-2012, 10:14 AM   #8
oldman3
oldman3's Avatar
Mike, everything is looking super and moving right along, nice job...Jim
oldman3 is offline   Reply With Quote
Old 09-17-2012, 10:16 AM   #9
67c10rustbuket
67c10rustbuket's Avatar
Here is the right wire cover mikey I didn't know tilts were different either, learn something new every day! Truck is looking great btw!
http://www.brotherstrucks.com/prodin...number=WHC6772
Dan <---(my name)
67 SWB C10 project "GEORGIA"-59 Brookwood 2dr wag...Next project-03 Tahoe 4x4 5.3 family ride-07 Hondur Accord, commuter car
67c10rustbuket is offline   Reply With Quote
Old 09-17-2012, 11:37 AM   #10
screaminchevypickup
Laid Back
screaminchevypickup's Avatar
Are you going to be able to charge the a/c with the high and low side ports facing down?? It all looks great!!
72 chevy swb
Direct dealers for..
Vintage Air, Porterbuilt, Billet Specialties,Budnik wheels ,eddie motorsports, raceline wheels, intro wheels, Dakota Digital, precision, unisteer, Trimparts, and many many more... Laid Back Recreations.. Full restoration shop and full paint and body..
Kyle
http://67-72chevytrucks.com/vboard/s...d.php?t=574629
screaminchevypickup is offline   Reply With Quote
Old 09-17-2012, 11:44 AM   #11
67cheby
67cheby
67cheby's Avatar
They arent crimped on yet just mocked up , will this be a problem ? I just thought it looked better ?
Old 09-17-2012, 11:48 AM   #12
54Caddy
GM Addicted
54Caddy's Avatar
With a few years working at some shops I have never seen the charging ports facing down. dont know if it will cause an issue but I would face them up just in case.
..Mac’s Garage..
73 GMC, 54 Caddy, 2010 Silverado, 68 C10 RIP DAd
My 73 GMC Truck Build Pic
2010 Silverado 4/6 on 24s
IG:MacsGarage
54Caddy is offline   Reply With Quote
Old 09-17-2012, 11:49 AM   #13
big_al_71
big_al_71's Avatar
We had my a/c lines facing down but then decided to mount them up right as one my techs said not to chance it. I dont know why but I listened to him.
Get your facts first, and then you can distort them as much as you please!!!!!.
Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild
big_al_71 is offline   Reply With Quote
Old 09-17-2012, 11:51 AM   #14
67cheby
67cheby
67cheby's Avatar
do you have a picture of what you did Al ? I still dont like the look of what i have going on here !
Old 09-17-2012, 03:02 PM   #15
big_al_71
big_al_71's Avatar
Here is a picture of how the a/c lines look....
Old 09-17-2012, 12:07 PM   #16
superflysteiny
superflysteiny's Avatar
Its alive
superflysteiny is offline   Reply With Quote
Old 09-17-2012, 12:11 PM   #17
67cheby
67cheby
67cheby's Avatar
well...not totally alive but she does have a twinkle in her eye !!
Old 09-17-2012, 01:08 PM   #18
67cheby
67cheby
67cheby's Avatar
How about a little love from FLOWMASTER !!! Cloud 9 is fixing to be singing some mellow tones thanks to Flowmasters DBX stainless mufflers and universal pipe kit !!
Old 09-18-2012, 04:37 PM   #19
jlsanborn
jlsanborn's Avatar
I thought you had your exhaust done? Does this mean a re-do? Gotta get a tailpipe on that thing! Nice work!
'77 K30 3+3 - "The Crummy"
http://67-72chevytrucks.com/vboard/s...d.php?t=640134
'67 C10 L/SWB - Soon to be daily driver!
http://67-72chevytrucks.com/vboard/s...d.php?t=471776
jlsanborn is offline   Reply With Quote
Old 09-17-2012, 01:15 PM   #20
widewhite70
widewhite70's Avatar
Congrats on more Love! It's looking good Mike!
-Calvin
http://67-72chevytrucks.com/vboard/s...d.php?t=512270 my build, tube chassis and LS2
How I keep the truck shining, Detail thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=697902
widewhite70 is offline   Reply With Quote
Old 09-17-2012, 01:50 PM   #21
Lolyin58
Lolyin58's Avatar
Wow Mike she is coming together nicely. Great work!!
Lolyin58 is offline   Reply With Quote
Old 09-17-2012, 01:50 PM   #22
gringoloco
A guy with a truck
gringoloco's Avatar
You've got me looking all over for cool paint color inspiration. The Fiat 500s have some interesting options, too. You need a bigger surfboard...
Edit: could you turn the lines 45° straight down, then 90° forward to follow the framerail?
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 09-17-2012, 01:52 PM   #23
67cheby
67cheby
67cheby's Avatar
LOL....hopefully 2 before its over !!
Old 09-17-2012, 02:33 PM   #24
watahyahknow
watahyahknow's Avatar
from the looks of it there comming from all corners lately , there must be some internal memo roulating across the autopartsbusness to check out the ride and the tread on this forum .
i hope you chosen small lettering on that surfboard cause its going to take both sides when the sponsors are done before sema
i got a job again and having fun at it too
idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real
i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts
watahyahknow is offline   Reply With Quote
Old 09-17-2012, 02:56 PM   #25
67cheby
67cheby
67cheby's Avatar
LOL, thanks man !! How about a sneak peek...
fiberglass inner fenders, pb hood hinges ", w/pb 4 link
