#5901 |
![]() Join Date: May 2012
Re: What did you do to your truck today!
ole dollor now has a auto trans , instead of granny 4 speed, had to get a 153 tooth flex plate instead of the 168 tooth i had, starter is said to be a big block starter, put in a lokar auto floor shift its a 16" shifter. sure glad i did not get the 23" one...got all the odds and ends finished and took it out for a drive, when i stop trying to stomp a hole in the floor board trying to find the clutch it will be better, i drove about 45 miles and no leaks or noises. i think i am going to love it better than i did...and a few pic's.
#5902 | |
![]() Join Date: Mar 2012
Sold the 63 and have a 68 now. 63 ![]() LT1/4L60E, PS, PB, Disk Brakes, CPP 4" drop coil rear, 2.5" drop spindle w/ 1" drop coil. slotted rotors, front and rear sway bars. 18"x8" Cragar SS w/ 245/45R18 http://67-72chevytrucks.com/vboard/s...d.php?t=544174 |
#5903 |
Who Changed This?
![]() Join Date: Jan 2013
Drove it for the first time in a few weeks. Hope to do more than keeping it sorta lubed by running it once every few weeks, maybe a camping trip is in my future; my wife is asking about our 32nd anniversary plans...
#5904 |
Did a little wiring on the '67 and put a new posi rear end in my S10....
but my buddy spotted this truck not to far from where he lives in WI...
Adam My 1967 C10 - Turbo 250 Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=485843 (608) 214-8706 |
#5905 |
those side steps kind of hinder ground clearance...
#5906 |
C/10 junkie
^^Now thats cool!!
Shawn 70 LWB C10 current driver/project http://67-72chevytrucks.com/vboard/s...d.php?t=663051 68 SWB C10 Work in progress.....SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=559520 72 LWB C10 Sold 71 LWB C10 Sold 68 LWB C10 CST Sold http://youtu.be/kbB0QrBIs9k My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!" ![]() |
#5907 |
RAT1968 '68 Cab/'71 Parts
No, Silly!
Once you climb in, you pull them into the cab and put 'em in your pocket.
M17 Coarsegold, CA RAT's shiny now. But always a rat. |
#5908 |
![]() Join Date: Jan 2012
Finished up the drum to disk conversion on my 71s 12bolt used captainfabs impala ss brackets everything went together flawlessly. Now just gotta put it back under the truck. ![]() Posted via Mobile Device Posted via Mobile Device |
#5909 |
I finally got the pesky compression fitting off the back of my oil gauge!
71 K20 64 GMC mud truck |
#5910 |
Ooops, double post
#5911 | |
68 ![]() My other ride ,,, 07 Streetglide.. |
#5912 |
Removed dome light, and all caulking from drip rail. Not much but still progress.
#5913 |
Nasty drip rail is gone
1970 Chevy swb, project UGHH! ![]() 1987 Grand National http://s168.photobucket.com/albums/u.../1970%20Chevy/ |
#5914 |
Unplug the front driver side brake hose to order a custom made due to my C10 69 I swaped 80 C10 disc brakes.
#5915 |
By the way:
71/72 calipers will fit in the 73/87 spindles? |
#5916 |
did not take any pic's of the install, just the th 350 painted , and the pic. of the 168 tooth flexplate that i put in and was to big. it started life as a granny four speed and i changed it over to a auto, it still has the 292 six cyl. its hard to get parts for the 292 and a lot of trial and error. but its back on the road after about 3 weeks of ordering parts and waiting on them to come in, the only pic i took of the install was after it was in and through the floor, need to take some sense i got the floor shift in and the a/c moved back to the middle of the dash.and all back together, also put in a new am fm radio. the old one was no good from the day i put it in. i do like the auto better that the old four speed, old knees need an auto....
#5917 |
![]() Popped out the back window today and enjoyed the ride home.. Also today was double time pay for me, so today was a win/win for me Posted via Mobile Device |
#5918 |
Started a build thread. Check my signature.
Got the pilot bearing for the flywheel mounted, and finished re mounting the tank, compressors and lines closer to the cab. Posted via Mobile Device
Best Regards, Leon M. Instagram: @TheDirtyDianah
Bagged | 6.0L LS | T-56 (6-Speed Manual) | Turbo Burnout/Rolling Video: Chevy C10 Stepside 6.0L LSx & 6-Speed Manual |
#5919 | |
#5920 |
Got the 72 custom deluxe back on the road today after sitting under a shelter for 8 years. Got a video of first drive by from a friend..lol
https://vimeo.com/58841496
1972 Custom Deluxe LT1 Gen V Swap "Green Lantern" 1984 Silverado Red Baron-72 c10 Project |
#5921 | |
i will take a pic Monday and post it of the floor and the pedal . Last edited by ole dollor; 02-03-2013 at 10:27 PM. |
#5922 |
Installed my new correct color brake booster and ac delco master cylinder with new brake lines
Jeff 1972 Cheyenne Super SWB 350, Auto, Bucket Seats w/Console, Tach, Factory A/C, P/S ,P/B, Tilt 1998 Chevy 1500 Ext Cab 5.7, Pewter w/blue interior |
#5923 | |
C/10 junkie
#5924 |
Made a bracket for my fuel pump and filter, and got it installed. Installed my fuel tank as well.
#5925 |
Order up a copy of the "1969 Chevrolet GMC Truck Shop Service Repair Manual Book Engine Drivetrain OEM" today. Very excited as I love to tinker but I am no mechanic. This should help a lot in my journey I think. Ebay for $23.58
Jeff
St. Louis, Mo 1969 C10 2011 Dodge Charger R/T (custom) |
