Closed Thread
Old 08-13-2012, 09:18 PM   #5926
dantimdad
dantimdad's Avatar
Re: What did you do to your truck today?
Gas tank and rear glass out. Remaining weather stripping removed. Only thing left before removing the cab is the gauge panel and undoing the bolts.
Then, on to the rest of the frame cleanup and then tearing it down for painting and suspension rebuild.
Steven
“Life is and will ever remain an equation incapable of solution, but it contains certain known factors.” - Nikola Tesla
Matt. 6:27 "Who of you by worrying can add a single hour to his life?”
http://www.67-72chevytrucks.com/vboa...=507266&page=2
dantimdad is offline
Old 08-13-2012, 11:11 PM   #5927
LT1 Burb
LT1 Burb's Avatar
Originally Posted by padresag View Post
some more pics and put away for the night
ron
That looks like that took some time getting that body off, I did a body on and it wasn't easy either.
LT1 Burb is offline
Old 08-14-2012, 11:56 AM   #5928
padresag
It didn't take that long to do what you see in the pic.started after lunch on sunday. 8 hrs. that body I took off an 84 frame so most of the body mount bolts were not that bad. there was some welding that I had to undo but that was done previous.
I was just thinking, who ever put that body on that 84 frame ( mounting was crude), but they lifted the complete body in one piece and installed it. the doors had never been off before. the hood had been removed at one time in it's life as the bolts were not orig. the fenders, inner fenders nor grille or rad support had ever been taken off. one always wonders if it was a mechanical wonder or just a fluke happening through ignorance.
ron
padresag is offline
Old 08-14-2012, 06:23 PM   #5929
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
ron
I am super nervous about taking the body off my 64, with all the floor rust I hope it dosent bend in half
was that an engine hoist that you used to lift the body?
jonzcustomshop is offline
Old 08-14-2012, 06:48 PM   #5930
Chevy Fleetside
Chevy Fleetside's Avatar
I found a lower radiator hose for the truck. Had to cut to fit but it worked great. Now I just have to find a top one.
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline
Old 08-14-2012, 07:41 PM   #5931
rendus
rendus's Avatar
I adjusted my column shifter so I don't get stuck in first gear anymore.
'66 C10 250 3-on-the-tree
'68 Galaxie 460/C6
'74 914 2.0
rendus is offline
Old 08-14-2012, 07:53 PM   #5932
padresag
most have rust issues
yes that is an engine hoist that I used
I used a double 2 x 8 tied to the roof thru the frt door opening and a 2 x 12 (stuff that was laying around), put over the top of the 2 x 8's at the front and secured with plumbers hanging strap at the rear( quite a few screw at the back top). I needed almost 36" to clear and you will more than likely run out of lift capacity with that lift. you will see in the picture where I inserted a piece of 6 x 6 for a little more lift( nothing like living dangerously). for that last height adjustments on the corners , I just used a jack-all.. I did do the lift in stages between frt and rear. all in all it was a piece of cake and you can do it all by yourself
ron
padresag is offline
Old 08-14-2012, 08:03 PM   #5933
dantimdad
dantimdad's Avatar
You can also put eye bolts in the cab mount holes and run chain or rope to the hoist and lift it. Just use really big washers so the weight is distributed.
Steven
Old 08-14-2012, 09:11 PM   #5934
padresag
Steven
little trickier if you have rust in the floor though. there is considerable more weight to a suburban than there is to a p/u. if you have a good floor I don't see why you couldn't. you have to lift the body off the frame to nut it on the bottom side though and the same for installing it. my way gives you a clear shot at it.
ron
padresag is offline
Old 08-14-2012, 09:16 PM   #5935
ol school
Thumbs up Re: What did you do to your truck today?
drove my 64 stepside about 50 miles then started sanding it and doing some body work
ol school is offline
Old 08-14-2012, 10:12 PM   #5936
CRGRS 66
CRGRS 66's Avatar
Gave the old girl a nice pat on the dash for getting us there and back. Little 4 day camping trip with my wife. Put on close to 500 miles, she ran like a charm
Oh yeah, rained just about the whole time, man that trailer is small!
Craigerrr
My build thread, CRGRS 66 Winter Build: http://67-72chevytrucks.com/vboard/s...09#post5638709
CRGRS 66 is offline
Old 08-14-2012, 10:33 PM   #5937
MikeS.
MikeS.'s Avatar
Had a new radiator top pipe built to replace the original. I got that installed and started the truck back up today. After filling the new radiator with water and anti freeze. Looks like I have some carburetor issues going to have to dig into that further. Also having problems with the steering column shaft. I'm going to have tear into that and figure out what's wrong. It's part of the power steering that I put in. The splines didn't match up properly or something I don't know really yet what. I could turn the steering about a quarter of the way than it just stopped.
Past Master
Triluminar Lodge #117 GL of WVa
My 1963 4x4 Suburban build;
http://67-72chevytrucks.com/vboard/s...d.php?t=531274
My Gallery, now with pics of my 1966 C30 motorhome.
http://67-72chevytrucks.com/gallery/...&ppuser=103447
MikeS. is offline
Old 08-15-2012, 02:50 AM   #5938
fryer1979
Redneck Hillbilly
fryer1979's Avatar
Still working on a carb rebuild and exhaust redo....tried to fire her back up today, but the starter took a crap and I ran out of time to keep working on her before work. Hopefully tomorrow I can get her fired up and driving again.
fryer1979 is offline
Old 08-15-2012, 06:03 PM   #5939
ljackson
ljackson's Avatar
We put tires on the repainted wheels, put on the front bumper and grill guard and rear bumper
Father and son built. Driven daily since 2012. 283, 3 speed. Mostly original. '81 PS and disk front. Fuel tank relocate.
Maintenance, repairs and upgrades on his dime now.
http://zacks64longfleet.shutterfly.com/
Higher res. photos in my gallery.
ljackson is offline
Old 08-15-2012, 09:36 PM   #5940
markeb01
Senior Enthusiast
markeb01's Avatar
That is a great camping photo!
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
markeb01 is offline
Old 08-15-2012, 10:00 PM   #5941
LDO
LDO's Avatar
Sorry, no pictures but I did install new wipers after a 0500 rainstorm incident on the way to work. Luckily, my cool under pressure and superior driving skills saved me from certain doom.....ok, I really just pulled over until the rain shower ended but hey, it sounded good right?
LDO is offline
Old 08-16-2012, 01:19 AM   #5942
64thunder
sanded some more primer off so i can do it right found out mine was a aqua torquoise type color originally and got rid of a wasp nest behind the gas tank
put a fogger in shut the windows sat on the tailgate and enjoyed a beer and a smoke listening to their screams inside the cab
64thunder is offline
Old 08-16-2012, 02:00 AM   #5943
fryer1979
Redneck Hillbilly
fryer1979's Avatar
Got her all running and almost tuned in, then with only an hour and a half to go before I had to come to work, my buddy and I decided to go ahead with a swap out to my new HEI distributor. Unfortunately, the battery died and the power went out while we were trying to get her dialed in. So for now she sits, hopefully the power is back on in the morning so I can stop by the shop and plug in the charger on my way home to bed. Should be driving tomorrow night!
Teaser pic....and yes, once I am all done I am going to clean up the engine bay.
Old 08-16-2012, 10:18 AM   #5944
Blue Heeler
Blue Heeler's Avatar
bumper was not straight had to adjust that, put my hybrid tag on back so the stupid tree huggers don't look at me like they are smarter than me, and had my grand-kid helping me with drinks.
Blue Heeler is offline
Old 08-16-2012, 11:14 AM   #5945
jbgroby
jbgroby's Avatar
Thats too funny, I might do that as well. I figure ALL our trucks are Hybrids, hell I got all sorts of different parts from different models!
jbgroby is offline
Old 08-16-2012, 12:20 PM   #5946
66clow
66clow's Avatar
What is the story on the grille guard? Where is that from. Just curious.
66clow is offline
Old 08-16-2012, 12:33 PM   #5947
markeb01
Senior Enthusiast
markeb01's Avatar
Went to the quarter car wash today and hosed the winter crud off the firewall, then came home and gave the truck a bath getting ready for the Goodguys show tomorrow and Saturday. Normal temps for the show are mid-80’s to low 90’s. Saturday is suppose to be 100. I’m not a hot weather person, but at least we’ll have a shade canopy and some chairs with us.
markeb01 is offline
Old 08-16-2012, 12:59 PM   #5948
G-Money
G-Money's Avatar
Spent yesterday digging thru trucks in an unmarked graveyard. Scored a tach dash from a 1964 ( trying to figure out a way to get it in my 63), posi rear end out of a 72, factory power brake booster, tilt column from a 74 van ( less the shifter lever )and a much needed p/s hood hinge. I found a pair of bucket seats in a carry all that I left, I'm thinking I might go back for those. I also grabbed this tachograph do hicky ... not sure what it is but it looked cool, it has a tach and a clock in it.
G-Money is offline
Old 08-16-2012, 01:24 PM   #5949
ljackson
ljackson's Avatar
I bought a great 66 custom parts truck earlier this year. The truck has lots of rust though. The floors are gone. The bumper and grill guard were the main reasons for the purchase. Take a look. I have seen a few like this. I believe it was something that could be purchased from the dealer back in the day.
http://67-72chevytrucks.com/vboard/s...d.php?t=509664
ljackson is offline
Old 08-16-2012, 01:25 PM   #5950
markeb01
Senior Enthusiast
markeb01's Avatar
Tachographs and speedographs were common devices installed in fleet vehicles back when I worked at Peterbilt in the 1970's. They basically were a "Big Brother" system to see when the truck was moving or sitting, and how fast the truck and the engine were running. It allowed the fleet operator to determine if the driver was doing what he said, driving 55 mph all day, or taking a break at his girlfriends house and then driving 90 miles an hour to make up for the lost time.
markeb01 is offline
Closed Thread
