Old 03-29-2019, 12:44 AM   #5926
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
I recommend you set aside 60 hours for this project... 59.5 to get the stupid lock mechanism out, and 1/2 hour for everything else, ha ha
Top Tip - don't go pockin' anything like a paper clip into that hole in the twisty knob thingie, it's there just to show you that GM engineers have a sense of humor
Top Tip 2 - use a super skinny flat screw driver to push in that little pin thingie in the hole in the picture, that will allow the lock to slide out about 1/4 inch, then do it again to the second pin in the same hole and then it will come all the way out
Fun Level = 2
Gregski is offline   Reply With Quote
Old 03-29-2019, 12:47 AM   #5927
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
58 1/2 hours later...
anatomy of a C10 glove box lock latch
Old 03-29-2019, 12:50 AM   #5928
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
and here's the real reason we are doing this, apparently in 1973 GM thought fatiguing plastic will out last a metal piano hinge and decided to fix what wasn't broken, I swear the only things that have broken on my truck have been plastic bits! surprise?
Note there is a metal bar that runs across underneath the plastic piece that attaches to the bottom of the dash board
Old 03-29-2019, 12:51 AM   #5929
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
mandatory stare and compare, old vs new
Old 03-29-2019, 12:54 AM   #5930
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
This is not a bad camera angle! This is not an optical illusion either!
this is jus how the brand new box comes it is off by 1/2 an inch from the left side to the right by design, if you put your head under the dash and look up you will see that that part of the dash metal piece actually goes from skinny to fat as it goes across
Old 04-24-2019, 08:46 AM   #5931
GRAY GOOSE
Re: Restoring Rusty
How is the LS swap going?
GRAY GOOSE is offline   Reply With Quote
Old 04-27-2019, 10:57 AM   #5932
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
Ha, thanks for following up, well April taxes ripped me a new one so I hope to drop off the 1999 Suburban roller cam short block at the engine builder next month in May, and go that route first, if they tell me this block is junk, than we do the LS thang, stay tunned.
Old 05-01-2019, 02:52 PM   #5933
82Diesel
Re: Restoring Rusty
Crazy thread man... haha.
1979 Pontiac LeMans 231/Th350
1982 Chevrolet Silverado K10 6.2 Diesel/700r4
1984 Buick Regal Limited Sedan 4.3 V6 Diesel/200r4 (Hens teeth rare)
1991 Chevrolet Silverado K2500 5.7/700r4
1999 Chevrolet Base LS K2500 6.5TD/4L80e
82Diesel is offline   Reply With Quote
Old 05-03-2019, 01:14 AM   #5934
fordguy40
Thumbs down Re: Restoring Rusty
Originally Posted by Gregski View Post
WTH?
this brand new after market garbage is seriously off by 1/2 an inch from the left side to the right!!!
Wow.....
Mind sharing where you got this? I'm looking to pick one up soon and am really hoping they're not all made by the same company!
A few Fords and a couple of Chevys
fordguy40 is offline   Reply With Quote
Old 05-03-2019, 10:36 AM   #5935
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
thanks I guess, I hope you mean "Crazy" in a good way, ha ha
Old 05-03-2019, 10:42 AM   #5936
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
Originally Posted by fordguy40 View Post
Wow.....
you bet, this is why I share, just looking out for one another, so I get my parts from Classic Parts out of Riverside, Missouri
They have been great up to this point and I prefer them over LMC Truck since LMC is just a call center and has not Tech Support, but I called them on this part and they said it should work and that's just how they come
Old 05-19-2019, 05:15 PM   #5937
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
so yeah a quick update since I haven't been posting, well I suck I will be turning 47 in a few days here, and for my birthday I decided to get a hernia, yup, got scheduled for surgery in a few months (they are super booked out, I guess it's the operation to get if you are thinking of going under the knife, ha ha), so what would have been a lovely time to rebuild that '99 Suburban roller cam engine and swap it in has me grounded and going stir crazy - - - watching LS swap videos ???
Old 05-20-2019, 02:17 PM   #5938
Pontiac1976
Pontiac1976's Avatar
Re: Restoring Rusty
http://bowtieguy.proboards.com/threa...box-lock-truck
I wish I had read this sooner, or know you needed this link.
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed
Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change.
Pontiac1976 is offline   Reply With Quote
Old 05-24-2019, 02:05 PM   #5939
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
this just happened...
5.3 L LM7 truck engine from a _________ Chevrolet Silverado
4L60E automatic RWD transmission
all there but the starter
Old 05-24-2019, 02:09 PM   #5940
Rich84
Rich84's Avatar
Re: Restoring Rusty
The plot thickens....
Rich84 is offline   Reply With Quote
Old 05-24-2019, 02:48 PM   #5941
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
yes sir, game on, the wiring harness is in that white garbage bag, and the computer aka the PCM in a grocery bag in the cab, ha ha, so it's all pretty much there, Top Tip: buy as much as you can in one shot! so you don't get nickle and dimes to death
Old 05-24-2019, 02:51 PM   #5942
Re: Restoring Rusty
Nice!!
Old 05-24-2019, 06:30 PM   #5943
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
Nice!!
oh yeah, and only $1K for both the engine, transmission, wiring harness, and computer, HUGE THANK YOU TO THE SELLER, such a cool guy
12200411 = 2001-02 PCM
red/blue connectors = 1999-02 drive by cable
Old 05-24-2019, 10:23 PM   #5944
Wgesnerjr
Wgesnerjr's Avatar
Re: Restoring Rusty
spoiler alert:
You will LOVE the LS motor! Mine was worth all the work, X2!
Jay Gesner
Atlanta, GA
1985 C10 Long Bed 4X2
LS 5.3, 4L60E
Father/Daughter Project
Wgesnerjr is offline   Reply With Quote
Old 05-24-2019, 11:31 PM   #5945
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
Originally Posted by Wgesnerjr View Post
spoiler alert:
Bro, other than having to dust off my metric socket set, ha ha, so true, ten minutes with her and I am already like wow I love the valve cover design, it will not leak oil with the high cylinder walls, every bolt I go to remove comes out cause to me a 20 year old engine is BRAND NEW ha ha having worked on a 45 year old one
no broken off exhaust manifold bolts, that's a surprise
anybody know if the exhaust manifold flange will fit the downpipes from a 5.7 Vortec like off of a 1999 Tahoe/Suburban?
Old 05-24-2019, 11:33 PM   #5946
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
my truck did not have AC from the factory so I decided to delete the AC on the LM7 5.3 L engine, so easy, the AC compressor uses it's own belt and belt tensioner so it all comes off super easy and there is no need for an idler pulley to replace the compressor one, nice
Old 05-25-2019, 09:59 PM   #5947
kipps
Re: Restoring Rusty
If I remember correctly, you went to a bit of trouble to put a manual in your truck. Correct or no?
If so, are you intending to stay with a good stick-shift, or install that slushbox? You can probably guess which way I vote.
1987 C6P V20 truck, 2010 LMG 5.3, AFM delete, 2010 Camaro exhaust manifolds, 1997 nv4500, 1991 np241c, hydroboost, 2005 14bff axle & driveshaft, drop-n-lock gooseneck, 4.10 gears, stock suspension, rims, and tires. Still a work in progress. Any questions or suggestions are welcome!
kipps is offline   Reply With Quote
Old 05-25-2019, 11:25 PM   #5948
Jake Wade
Jake Wade's Avatar
Re: Restoring Rusty
I am in for this swap!
Jake Wade is offline   Reply With Quote
Old 05-26-2019, 09:22 AM   #5949
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
what you did not read this thread in it's entirety? LOL
my truck originally was a 4 speed manual (SM465 iron granny gear box), and the reason I bought it, regardless of what people say manual trucks are very hard to find be it 45 year old or modern, trust me I know I have been looking for them for years
I swapped the SM 465 for an A833 like GM 4 speed (from GM mid 80s trucks, direct bolt on no trouble at all) with overdrive, so one GM trans for another GM manual factory trans
I luv stick shifts - after all I am European (shh don't tell anybody)
I really wanted to go 6.0L with the NV4500 5 speed manual but those are Unicorns and immpossible to find, the only two trucks I have seen with those in the entire United States were 4x4s and I want a RWD
The 5.3L LM7 engines only came with Automatic transmissions
since this is my first swap I am keeping it simple and installing the 5.3 with the 4L60E automatic
and YES, the day after I install it a 6.0L manual donor truck will pop up on Craigslist, ha ha ha
good questions bro,
G
Old 05-26-2019, 09:32 AM   #5950
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
Me Too!
so one of the reasons I got such a great deal on this combo is because the owner did not know the VIN and could not tell me that information (knowing the VIN was important to me because I did not see all these parts come out of the same vehicle so I wanted to run a VIN checker to find out what year this was off of and confirm it was a RWD originally, etc.)
so off to Pick N Pull I went and bought just the blue connector for the computer and a Obi-Wan Kenobi port so that we could make ourselves a bench harness, which for us Carburetor Generation is just a cable that will connect the car computer aka the PCM (while out of the car) to our laptop so that we can get some information off of it. I also bought a generic universal 12 volt 1.5 Amp AC adapter to power up the PCM off the car.
while we wait on our $300 dollar HP MPVI2 Tuner to arrive we are going to try to get the VIN at least off of this PCM using an ELM 327 Interface (serial dongle that plugs into a cars OBD2 on one end and the USB port on your laptop on the other end)
NOTE: you can pull some information off of the PCM this way and clear the error codes, but you CAN NOT program it with this hack.
