#5951 |
![]() Join Date: Mar 2022
Re: What did you do today not on your truck...
Can only post 5 pics...
#5952 |
Last batch. Changed the last pic. This is how the Harley gets strapped in. After I had this worked out, I cut the excess off and melted the ends to prevent fraying.
#5953 |
laying low
![]() Join Date: Mar 2001
Real nice setup. The conduit is a great idea for all exposed wires. Mice love to chew the wires especially on something like a trailer that sits unused a lot.
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
#5954 |
![]() Join Date: Jul 2021
I went to the track to try out my new motor in the S10. Had a great time. Scary at first but finely got it to go straight.
Darrell ![]() 1972 Cheyenne Super C20 (My Fun Drive) 2000 S10 Xtreme (My Drag Truck) |
#5955 | |
20' Daredevil (Ret)
![]() Join Date: May 2003
![]() Quote:
#5956 |
Post Whore
![]() Join Date: Feb 2016
V8 S10's are great! Yours is looking good. Any more information on it?
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. ![]() RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
#5957 | |
![]() ![]() Join Date: Oct 2014
#5958 | |
#5959 |
It's a 2000 Xtreme. This is the third motor in it. Each one got a little nastier. First engine was a 383 with just over 500hp. The second motor was a built 374 with just over 600hp. Now this third motor is a built 430 with just over 700hp. I put this truck together to handle more than 1000hp just in case I decided to go bigger. So, all I really had to do was build the motors, the rest of the truck was fine, very little change.
#5960 |
Go fast and look good doing it
What a weapon you got there |
#5961 |
![]() Join Date: Nov 2018
If you have never changed a battery in a 2020 Tahoe (I'm sure a few other models too) your in for a real treat.
The wife's original factory battery finally gave up the ghost the other day so I found out the task of changing it is no longer a simple operation lol. You have to completely remove the air cleaner housing then loosen and slide the coolant overflow tank forward to have room to get it out. It has a positive and ground distribution block that straddles the top of the battery with 5 cables attached, all of that plus a brace over the battery. Nothing overly difficult it's just not a 15 minute job anymore. |
#5962 |
Did you have to do something to maintain power to the computers while you disconnected the battery? I think some vehicles require it.
#5963 | |
I did watch a youtube video (hoping for a shortcut) which showed turning the battery on its side for removal without taking everything else apart (coolant/air box) but it did not work for me as I was afraid of snapping the plastic mounting tabs on the coolant tank off, then we have another problem. On that distribution panel/busbar that sits on top of the battery it has a blue multi-wire connector it feeds that appears to power the computer, you can leave that connected as I did, and I suppose connect remote 12 volts to it but it would be right in the way of what your trying to do IMHO. |
#5964 |
Changed the engine oil on the Kubota . Not all that exciting
#5965 |
![]() Join Date: Jun 2019
#5966 | |
#5967 |
Who Changed This?
![]() Join Date: Jan 2013
There's a gizmo one can buy at the parts store that uses a 9 volt battery, and plugs into the electrical system. It has enough energy to keep the memory alive until the battery is switched out. I have my batteries tested when they've been in our vehicles for awhile, just to see where they are at. I'd rather replace a battery early than have my wife stranded someplace because I wanted to squeeze the last electron out of a battery. These days, batteries do not fail gracefully. Used to be you could tell, when the engine started cranking over a bit slower. Now, you drive someplace and come out to a failed battery. Come to think of it, it's time to go through the rotation with our vehicles having the batteries tested.
#5968 |
After many months of my bike sitting in pieces, I got it back together. I installed some silicon coolant lines to replace the 26 year old rubber ones. The body work needs to be installed still. Now I just wish I could ride it
#5969 |
laying low
It'll help you look forward to spring.
#5970 |
Exactly what happened! Once that computer drops below 10.5 volts or so it shuts it all down, couldn't start it even if cranked slowly.
#5971 | |
I call them organ donors |
#5972 |
#5973 |
Did some splitting today. This I did by hand with the Fiskers X27
#5974 |
Massive power outage?
![]() Who cares. ![]() Tested the ol' lawnmower generator and it's fine. ![]() I have a spare Chevy alternator charging two spare car batteries in here with a pure sine wave inverter to keep the ice cream frozen and the wifi on so I'm all set. ![]() |
#5975 | |
![]() Join Date: Dec 2009
________________________________________________________________________________________ ____________________________________________ The early bird gets the worm, But the second mouse gets the cheese 84 Chevy K-20 63 Impala (my high school car) http://67-72chevytrucks.com/vboard/s...Crew Cab Build |
