#576 |
Re: The '67 Burb Build Thread
cant wait to see the bumper in primer! that way we can see how smooth it is!
#577 |
its gonna need a little bit of filler work before its completely smooth
#578 |
no, the wheels will not go on ,like the axle is too big for them to go on .thanks again ron
#579 |
so the axle is to wide, or the center bore is bigger on the axle than the rims??? sorry im trying to understand what you are saying. are the wheels stock escalade wheels, or aftermarket wheels that were on an escalade??
#580 |
#581 |
The center bore on axle is bigger then the wheel. They are factory optional wheels ,6 spoke like TT2s. Sorry I can't explain better thanks. Ron
Posted via Mobile Device |
#582 |
ahh ok i got it
![]() in that case you have a few options.... you can either have the center bore on the wheel opened up to fit, or if you have the room you can run the spacer/adapter i was talking about a few posts up. you could also have the axle machined. or if its got long enough studs on the back, you could run just a small spacer to push them out just enough to clear the problem area. well mine is converted to 5 lug but..... the wheels on the front of mine i had to do something similar.... the center bore on the wheels on the front were to small, so i used an angle grinder to open the center bore a little hoping it would help, but it wasn't quite enough, so then i added a small spacer and presto.... perfect fit ![]() as for the back they fit no problem, they just sat in to far because of the offset of the wheels, so to fix that i used one of the same pattern to same patter wheel adapter spacers |
#583 |
ok i will see if i can find some spacers thanks ron
#584 |
oh no problem bro... glad i could be of some help
#585 |
sprayed some rust convertor on the back and front side and brought it out in the sunlight for some better pics..
#586 |
primered and guide coated..... needs some filler and block sanding now
#587 |
yes it does but other than that your doing fine!
#588 |
#589 |
finally got it home and out of my buddy budnikguy's storage yesterday. thanks for letting me leave it their as long as i did
![]() and now today its in my garage where it will sit until i get a storage unit and then they both go into hibernation for a while...... |
#590 |
low n' slo
![]() Join Date: Mar 2009
hey, whats the roof for again?
67 1/2 ton Suburban - Project DRGNWGN. Build thread ![]() -_--_--_ _________ _--_-_ -/____|__|__\__ ,.,,,.,.,,.,|_O _______ O_] |
#591 |
well...... i have a few different ideas floating around in my head for it
1. roof skin swap ![]() 2. 3" chopped top ![]() 3. 3" chopped top with a big a$$ full length sliding rag top ![]() |
#592 |
updates???
![]() keep going ![]() almost their ![]() pretty self explanatory ![]() finally doing it right ![]() tacked in... key hole patch tacked in some grindage... ![]() Last edited by project 67 sub; 10-02-2011 at 01:12 AM. |
#593 |
good enough for now...
working on the 3rd door area patch piece welded in gas filler area cut out patch panel made and fitted Last edited by project 67 sub; 10-02-2011 at 01:01 AM. |
#594 |
welding it in
and some paint to keep it from rusting here to ![]() ![]() Last edited by project 67 sub; 10-02-2011 at 01:15 AM. |
#595 |
low n' slo
nice work man...good welds. do you have a popper system setup already?
#596 |
thanks, i made my buddy do it because i let him borrow my wheels to put on his bagged 70 caddy for a show a while back, and a photo shoot for his car clubs calendar last weekend or was it the weekend before last. anyways lol. and also because i don't have a mig welder
#597 |
these sub's are starting to grow on me , maybe next project
check out my build thread 71 c/10 step side 5.3 twin turbo http://67-72chevytrucks.com/vboard/s...d.php?t=485320 raul |
#598 |
#599 |
put some green paint on it because i was tired of seeing the white squares every time i walked into the garage
#600 |
Very nice! Nice use of labor
![]() I think I'm gonna tackle the popper on my suicide 3rd door, on monday.
Eric '68 C20 Suburban, Bagged with Suicide 3rd Door, and Loaded with a 396 - Under Construction http://67-72chevytrucks.com/vboard/s...d.php?t=403690 |
