05-22-2009, 02:47 AM | #576 |
Restoring a 68 SWB
Re: LFD's 4dr Tahoe Build
Good luck with the computer switch. Already tried that and took the Mac back. Old and set in my ways I guess. Camaro looks good. Gotta do the lower quarter panels on a 72 firebird soon as well.
My Build Thread: Lucy - My 1968 SWB - Shop Truck Style North Nashville Concrete Contractor |
05-22-2009, 04:56 PM | #577 |
How much do ya charge to do a 1/4?? PM me if the quote should be kept quiet. You are a ways away, but your work speaks for itself, if nothing else it gives me an idea of what it will cost me here local?? Looking sweet can't wait to see the Tahoe/burb get some altitude adjustments!
05-22-2009, 05:11 PM | #578 | |
Speaking of Napa parts I just broke down and bought a good floor jack. I have always had $100 jacks that last for a few years but I needed something a bit better and lower than my last few. This one is 2 3/4" down and 19 3/4" up. It has a double pump for fast raising and is very smooth and controllable on the release. Also the reach is good so it will get to the front main cross-member and still have room to jack up. Kevin LFD Inc. [IMG][/IMG] [IMG][/IMG] [IMG][/IMG] |
05-22-2009, 05:23 PM | #579 |
DropMember C-4 install Well parts started showing up about 1:30 pm but I had started a few hours before that getting things ready. First I pulled the front sheet metal then I set the Tahoe up on jacks front and rear. I made sure they were level side to side then I started removing everything that was not going to stay. After that I cleaned the out side frame rails to get them ready for the new parts. The inside rails were nice and clean and since I will be boxing this frame front to back I did not want to remove the paint from inside the rails. Then time for lunch. Kevin LFD Inc. [IMG][/IMG] [IMG][/IMG] [IMG][/IMG] [IMG][/IMG] [IMG][/IMG] [IMG][/IMG] [IMG][/IMG] |
05-22-2009, 05:27 PM | #580 |
PITbut
I just shot slurpee out of my nose from this picture. I have no idea but i just LOL'd out loud here at work.... You need to call that jack the donkey....
New project. 1971 Twin Turbo blazer http://67-72chevytrucks.com/vboard/s...d.php?t=676047 My new YOUTUBE channel.. Videos of my truck and a current walk around. Lyrikz74 Youtube channel DONE! SOLD! My 1971 stepside build thread My Build Thread UPDATED 6/11. DONE and sold. |
05-22-2009, 05:39 PM | #581 |
Seņor Member
Oops... sorry about that
05-22-2009, 08:34 PM | #582 |
05-22-2009, 10:42 PM | #583 |
I don't know about anyone else and maybe I need a new job but checking this sites updates is the best part of my day recently.
Hey I made it to Northern California so if you need any help I'm bored stiff in a hotel room because my house isn't ready yet. |
05-23-2009, 01:39 AM | #584 |
Here are a few more pics. I was a bit side tracked today so I did not take as many pics as normal but the end results will make up for it Saturday afternoon. So I spent some time grinding and smoothing all the welds and edges of all the DM parts so I won't have to do it later when I have the chassis on the table doing the frame boxing. It is not needed with the way Nate welds but I think it gave it a smoother look and Nate welds so well all the outside corners were welded to a perfect radius so clean up was quick. Then a friend of mine showed up who owns the 68 Camaro and replaced the upper and lower ball joints while I was working on other things. I think I will be doing a slight clearance of the fire wall so I can turn when laid out. I just can't believe that is a 29.6" tire and it clears the fire wall like it does. I can't wait to get it on the ground in the morning then start shaving sheet metal so the front end can go back on.
Kevin LFD Inc. [IMG][/IMG] [IMG][/IMG] [IMG][/IMG] [IMG][/IMG] [IMG][/IMG] [IMG][/IMG] |
05-23-2009, 09:01 AM | #585 |
GEARHEAD
Unreal!
If no one knows what you're doing, they can't tell you you're doing it wrong HG's Dream Car Build - Shelby Cobra Kit Build your own adjustable track bar 71 Long Fleet C/10 72 Jimmy 4x4 (Junkyard Jimmy) HG's Plow Truck '78 K35 Dually Bigass Farm Truck HG's thread of miscellaneous stuff |
05-23-2009, 04:42 PM | #586 |
Rollin Low!
Well it is 1" to the frame when dumped and still rolls just fine. I had to cut off the part of the frame were it bends down for the trans cross member to slide in because it was resting on the ground. So here are a few pics to look at and to compare with low buck. Kevin LFD Inc. [IMG][/IMG] [IMG][/IMG] [IMG][/IMG] [IMG][/IMG] [IMG][/IMG] [IMG][/IMG] [IMG][/IMG] [IMG][/IMG] [IMG][/IMG] |
05-23-2009, 04:50 PM | #587 |
wow, no inner fenders for you!
looks sharp
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
05-23-2009, 05:02 PM | #588 |
That is PURDY Kevin! Wheel and tire combo look perfect on there. I'll have to see that in person!
Tony from Norcal |
05-23-2009, 05:19 PM | #589 |
05-23-2009, 05:30 PM | #590 |
are you gonna moddify the stock ones, or make new ones??
05-23-2009, 06:13 PM | #591 |
05-23-2009, 08:08 PM | #592 |
Very Nice Kevin!
05-23-2009, 10:39 PM | #593 |
Formerly- 1972SuperCheyenne
Some of the nicest work I have ever seen. Absolutely unreal the amount of talent coming out of that shop. You probably have more skill in your left boot than most people will ever have. Keep up the killer work.
--Josh My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218 A good crossthread is better than Loctite any day. Life is not about what you have, but who you have to share it with. |
05-24-2009, 02:05 AM | #594 |
Looks fantastic Kevin! How about a straight-on side shot so we can see how perfectly the wheels are centered in the fender openings. Great choice on the wheels too, I can't wait to get mine!
Steven "If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers R.I.P. Oscar R.I.P. Ratchet 1967 Pontiac GTO - Dad was the Original Owner 1970 Chevy 2wd SWB "Oscar's Truck" 1970 Chevy 2wd Blazer "Ratchet's Blazer" 2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar" 2017 Chevy Suburban "BDB" 2020 Chevy Blazer Premier "Foxy" Member of Louisiana Classic Truck Club (LCTC) Shop Build |
05-24-2009, 06:25 AM | #595 |
i like it low
05-24-2009, 09:43 AM | #596 | ||
Kevin LD Inc. |
05-24-2009, 01:41 PM | #597 |
Seņor Member
Maybe tomorrow we can get a couple of pics like these with the Wallet Eater in the lineup.
05-24-2009, 02:03 PM | #598 |
So what time are you showing up? I should have the engine in tonight and be ready to go.
Kevin LFD Inc. |
05-24-2009, 11:58 PM | #599 |
Here are a few side shots from today. I still need to adjust the rear tires forward about 5/8" and it should all be good. The first 3 are about ride height and the rest are dumped.
05-25-2009, 12:22 AM | #600 |
WOW!
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride American Born, Country by the Grace of God 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! Last edited by 67ChevyRedneck; 05-25-2009 at 12:22 AM. |
