Old 08-10-2009, 05:57 PM   #576
ruffrida2005
Member of the longbed union.
ruffrida2005's Avatar
Re: Daverods project 66
You sure can do that kind of burn out, depending on what rear end gears your running. And screw in studs he's talking about what holds your rockers. I have a nasty little small block making about 400HP and can do that in every gear. Granted I'm running 4.10's and a T350
Paul
88 GMC Crew Cab dually, 454/T400
64 LWB 400 HP 350/350T Bagged, under construction! Sold most of it!
92 S10 Iron Duke 5 speed, 5/7 drop for now. soon to be bagged. Sold http://67-72chevytrucks.com/vboard/s...59#post4637759
ruffrida2005 is offline   Reply With Quote
Old 08-10-2009, 06:01 PM   #577
daverod
SSN 706
daverod's Avatar
That's what I want to hear . I guess I'm going to need a locker? I want to do burnouts like that but with the ass draggin throwin sparks everywhere.
daverod is offline   Reply With Quote
Old 08-10-2009, 08:18 PM   #578
daverod
SSN 706
daverod's Avatar
I need to order some push rods. I'm not sure what length? Why would you need longer than stock?
Old 08-10-2009, 08:52 PM   #579
Strodder
Daring to be Different
Strodder's Avatar
That guy looks like he needs a sway bar, and new tires
Dennis
Check out my 65/73 Cheap Build Thread.
http://www.67-72chevytrucks.com/vboa...d.php?t=327644
KUSTOM RIDES
FACE BOOK PAGE:
https://www.facebook.com/groups/291198124258863/
1965 C-10 Short Bed 350/700r4
2012 Silverado 1500 Crew Cab
2016 Honda Accord w/ 18" rims
2007 Honda Goldwing Trike w/ NAVI
2001 Yamaha Roadstar Indian look alike
"Life's journey is not to arrive at the grave safely
in a well preserved body, but rather to skid in sideways,
totally worn out, shouting "...WOW!...what an amazing ride!"
Live Life Passionately!!!
[/COLOR]
I AM WE TODD IT, I AM SOFA KING WE TODD IT
Strodder is offline   Reply With Quote
Old 08-10-2009, 08:54 PM   #580
Strodder
Strodder's Avatar
If anything you would think shorter push rods with a high lift cam.
Dennis
KUSTOM RIDES
FACE BOOK PAGE:
[/COLOR]
Old 08-10-2009, 08:56 PM   #581
daverod
SSN 706
daverod's Avatar
So just stock? I have the performer cam. I'll call the eldelbrock tech in the morning.
Old 08-10-2009, 09:11 PM   #582
daverod
SSN 706
daverod's Avatar
I love that video. I've watched it like ten times. His front fender almost drags on the pavement.
Old 08-11-2009, 01:16 AM   #583
Captainfab
60-66 Nut
To determine the correct length pushrods, you need to check the contact pattern of the rocker arm on the tip of the valve stem. You want the tip of the rocker to be in the center of the valve stem through out the cycle of the valve opening and closing. You also need some adjustable pushrods for checking the lengths. This is usually done on performance engines when doing what is known as "Blueprinting" an engine. With the Performer cam, there shouldn't be a reason to not just run stock length pushrods IMO.
Old 08-11-2009, 08:37 AM   #584
daverod
SSN 706
daverod's Avatar
Thanks Capt. Always wondered what blueprinting was.
Old 08-11-2009, 08:56 AM   #585
watahyahknow
watahyahknow's Avatar
theres a little tool for measuring the pushrodlength you slide it in the place of the rocker untill it rests on the valvestem then you measure with an adjustable rod and have the length the new rods need to be
i got a job again and having fun at it too
idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real
i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts
watahyahknow is offline   Reply With Quote
Old 08-11-2009, 09:42 AM   #586
jgh64pkup
Sunburst C10!!!
jgh64pkup's Avatar
Ok, How about $150 each. That's what I paid. I changed my mind I'm keeping them. . Screw in studs?
those are about 750 dollar heads
also on aftermarket heads you have to check them right? not sure just asking
Gage
1967 C10 Shortbed Stepside
jgh64pkup is offline   Reply With Quote
Old 08-11-2009, 01:45 PM   #587
daverod
SSN 706
daverod's Avatar
Did a little research. Said stock rods would work with those heads S/r means stock replacement. Edelbrock said use 7.8" rods I don't know if those were stock or not. Got them coming from summit. Parts fairy just brought me a big o step notch.
Old 08-11-2009, 06:43 PM   #588
Strodder
Strodder's Avatar
So hows that money tree coming. Got any leaves left on it.
Dennis
KUSTOM RIDES
FACE BOOK PAGE:
[/COLOR]
Old 08-11-2009, 06:45 PM   #589
daverod
SSN 706
daverod's Avatar
Just buds. Economy here sucks I was thinking about moving to Mendocino. This notch welds together to slip over the frame right?
Old 08-11-2009, 06:56 PM   #590
Strodder
Strodder's Avatar
Show me a picture of the notch you got. Some bolt in.
Dennis
KUSTOM RIDES
FACE BOOK PAGE:
[/COLOR]
Old 08-11-2009, 07:01 PM   #591
daverod
SSN 706
daverod's Avatar
Its just a bunch of pieces. I just got it.
Old 08-11-2009, 08:20 PM   #592
Strodder
Strodder's Avatar
Well, just weld them all together, and see if it fits..
Dennis
KUSTOM RIDES
FACE BOOK PAGE:
[/COLOR]
Old 08-11-2009, 09:12 PM   #593
daverod
SSN 706
daverod's Avatar
That's what I'm doing. I knew you'd help. I figured it out after I messed with it for a bit. I was pretty sure it slids over the frame. Kills me not even a picture. I'm good with pictures. Got bored took my bumper off beat the big dent out that I put in it towing it home. Freeway off ramp at 65, old lady pulling me, no brakes ,but that's another story. Z'ed my bumper mount lowered it 1 1/2" . Filled in the holes. Ya it's level. It's just the angle. Really, I cut it off once already.
Old 08-12-2009, 08:46 AM   #594
daverod
SSN 706
daverod's Avatar
Is it just me or does this look wrong. There's no reason to put one side on backwards is there?
Old 08-12-2009, 09:08 AM   #595
Strodder
Strodder's Avatar
That's called ART.
Like this one.
Dennis
KUSTOM RIDES
FACE BOOK PAGE:
[/COLOR]
Old 08-12-2009, 09:37 AM   #596
daverod
SSN 706
daverod's Avatar
I thought maybe there was a reason. Art hmm. Here I thought it was just stupidty. I'm glad I did'nt buy the bolt on kind that would have way to easy.
Old 08-12-2009, 01:58 PM   #597
ruffrida2005
You welded them in right. Are those the ones from SD? The frames from 63-72 are made the same way with the frame sucking after the axle. Some people make their own and make it straight.
Paul
Old 08-12-2009, 08:01 PM   #598
daverod
SSN 706
daverod's Avatar
ya there the weld in type from sd. I just thoght some kinda pics or instruction would be nice. I got it figured out though. Post some pics later.
Old 08-12-2009, 08:08 PM   #599
protrash64
Resistance is Futile
protrash64's Avatar
Old topic, but thanx for posting daverod....that video rules!!! I wish I lived somewhere where I could do that.....mine would end with me in handcuffs free riding with the po-po.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 08-12-2009, 08:42 PM   #600
daverod
SSN 706
daverod's Avatar
Are you talking about these guys.
