Closed Thread
Old 07-31-2010, 09:40 PM   #576
americanmusc1e
americanmusc1e's Avatar
Re: What did you do to your truck today!
added a quart of engine oil and tranny fluid (it seems like as much money that I've spent on the engine and transmission that they wouldn't leak, but they still leak a little)
washed it, and looked at all the rust and bondo spots showing through and cried.
-- Josh
Instagram: @americanmusc1e
OLD SKOOL-- 1970 C10. 454/Th400/3.07 posi Build Thread
FARM TRUCK----1949 Chevrolet 3800 Power Wagon Hauler Build Thread
1999 4wd OBS Tahoe - daily.
DM me if you can't see photos i posted
americanmusc1e is offline
Old 07-31-2010, 09:46 PM   #577
rsavage
rsavage's Avatar
Came home from a motorcycle ride to a bike and rod show at Gowanda HD and put a new longer speedo cable on the Burb. Took her for a spin.
1961 C1 Corvette
1959 El Camino 350 TPI, 9" 4 w disc
69 Blazer K5 - sold July '20
2021 Durango RT 5.7
rsavage is offline
Old 07-31-2010, 10:09 PM   #578
s102000
Put a brake booster bracket on the 69 today, then watched Pinks All out that I had on DVR...
s102000 is offline
Old 07-31-2010, 10:28 PM   #579
Rob H.
Rob H.'s Avatar
Got the 72 hosed out from the flood, didn't have the seat or gas tank in it so was a pretty easy job. Pulled the original rubber mat out and found out how bad the floorboard was rusted, definately needs some work but not the worst I've seen! Picked up a new master cylinder and wheel cylinders for the back, still need to buy new lines and calipers, but I was really happy after using my Autozone points and getting 20 bucks off the price. After returning my core I'll only have $14.95 in the MC and both WC's! Yes I'm happy!
Rob
72 C/10 (under reconstruction)(destruction ? LOL)
48 Willys CJ2A
1952 Super "A" Farmall (Grandfather's)
Rob H. is offline
Old 08-01-2010, 02:00 AM   #580
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Bought a new air compressor for the shop today 80 gallon kellog american no more pos crafts man...
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline
Old 08-01-2010, 03:30 PM   #581
CSGAS
optomistic ah-so
CSGAS's Avatar
Loaded it 5 times and moved about 15 miles. Actually that took from Monday through Thursday dodging the weather we had.
Rubbing is Racin'
Ribbing is Bench Racin'
1970 C-10 lwb Fleetside. Originally 350 2-bbl 3-on-the-tree, m/b, m/w, m/s no a/c. Currently running on a '76 Camaro 305.
CSGAS is offline
Old 08-01-2010, 03:42 PM   #582
Newtz67
Newtz67's Avatar
Repainted my front emblem. Decided to do something different and paint the small stripe red also. Not perfect, but it's better haha.
Newtz67 is offline
Old 08-01-2010, 04:34 PM   #583
vectorit
What?
vectorit's Avatar
Drained oil in my Tcase.
R&R the output shaft sal on my T221.
Filled oil in the Tcase.
Chris
1968 K20 Suburban
1972 K10 LWB PU
vectorit is offline
Old 08-01-2010, 04:52 PM   #584
Jwill41
Jwill41's Avatar
installed the new door and glove box locks in the suburban so they now match the ignition. still need to have matching key made for the tailgate/hatch.
http://www.picturetrail.com/jwill41
67 1/2 ton GMC short step side
68 1/2 ton Chevy long fleet side
72 1/2 ton Chevy Suburban
99 1/2 ton Chevy Suburban
founder (and only member) of the primer/clearcoat club
Jwill41 is offline
Old 08-01-2010, 06:36 PM   #585
darush01
I just looked at it and put a battery on charge gonna fire it up for the first time this summer
darush01 is offline
Old 08-01-2010, 06:58 PM   #586
hayhauler71
hayhauler71's Avatar
Took my 10 year old daughter out for a ride it,s been 2 weeks since I had it out . I should be good for a few more days before I repeat .
Fuzzy
hayhauler71 is offline
Old 08-01-2010, 07:38 PM   #587
willys72fleetside
willys72fleetside's Avatar
Smile Re: What did you do to your truck today!
Finally finished doing the body work on the cab so that I can get it in primer!
A USED TRUCK IS A LOVED TRUCK!
willys72fleetside is offline
Old 08-01-2010, 08:16 PM   #588
ace of shades
NEWBIE!!
ace of shades's Avatar
Not really today, but a couple days in the planning. I went over a couple of towns, gave a guy $650 and drug home my old suburban, and a new parts truck
Water is for the weak
I don't like cocaine.. I just like the smell of it
"Well there might be a dime up a goats ass too, but I ain't looken" - Grandpa
VolksRods
ace of shades is offline
Old 08-01-2010, 08:21 PM   #589
willys72fleetside
ace of shades, nice find
Old 08-01-2010, 09:12 PM   #590
Newtz67
Newtz67's Avatar
Agreed, very nice!
Newtz67 is offline
Old 08-01-2010, 10:20 PM   #591
ace of shades
NEWBIE!!
Thank you. I regretted getting rid of the burb the moment the front wheels hit the trailer. It had changed hands but only moved down a house evidently. The truck was basically a freebe. The burb has the classic rust, pass front rocker, tail lights and behind the wheel wells. I had to sell (basically gave away) all my Volkswagen stuff and I'm sad about that, but its going to a good home, and parts for these are a little easier to find
VolksRods
Old 08-05-2010, 10:02 PM   #592
sjarrett71
sjarrett71's Avatar
Changed the drivers side low beam headlight. No that it's new and shiny the others need replaced too. And so it begins......
-Scott-
sjarrett71 is offline
Old 08-05-2010, 10:04 PM   #593
RemingtonSteel
RemingtonSteel's Avatar
pulled out sub and speaker box to get reupolstered with the seats!
1972 Stepside modified
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=418015
RemingtonSteel is offline
Old 08-05-2010, 10:40 PM   #594
07SSSC
07SSSC's Avatar
Spent all week trying to get my [super aggravating] belt setup to work, I would have never thought the [rediculously irritating] 5 rib alternator setup off an 86 burb would be so difficult to make work. I couldn't find an alternator that lined up right, so I had to switch back to a v belt on the alt. Now since I already put the larger pulley on the ps pump and now had to put a smaller crank pulley on I have hardly any assist at idle. Grrrrrrr.... I did however take it on it's first drive in over 3 weeks tonight, it was great fun.
Then.... Pulled back under the carport, got out all happy, went to lock the door and found the key cylinder was very loose. I attribute that to slamming the door thanks to the new weather stipping. So now that's gotta be fixed. If it ain't one thing it's another!
'69 Chevy C/10-under reconstruction -- '68 C20 Camper 50th Anniversary-runs, but sorely needs a resto --
'07 Cobalt SS/SC-very fun DD -- '93 Chevy K2500-LQ4/4L80E swap --
'84 Trans Am-awaiting (LS) drivetrain -- '00 Trans Am-road tripper -- '06 Z06-577 WHP beast
07SSSC is offline
Old 08-05-2010, 10:42 PM   #595
Hubscrub
Cruzin
Hubscrub's Avatar
sanded on the pass. side bedside
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8
Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U
Proverbs 3:5,6
"Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt
In memory of our first baby daughter, daddy and mommy love you.
Danica Grace 6/26/14
Hubscrub is offline
Old 08-05-2010, 10:52 PM   #596
project 67 sub
project 67 sub's Avatar
still nothing just been sitting, another week gone by now that makes 2 weeks total on this coming sunday. need to get back on it but trying to keep my daily beetle on the road and get it reliable so i can get on the burb like i want to try and do
project 67 sub is offline
Old 08-06-2010, 11:56 PM   #597
07SSSC
07SSSC's Avatar
Pulled the driver's door panel and reinstalled the lock cylinder retainer, no idea how it rattled loose. LMC part, awfully flimsy, gonna have to swap in an original I guess. Gonna take it to work tomorrow and wash it and adjust the doors.
07SSSC is offline
Old 08-07-2010, 12:09 AM   #598
Sonicman
Sonicman's Avatar
Bought new pistons for my 250 inline 6 after a week of searching. Putting them in tomorrow.
Sonicman is offline
Old 08-07-2010, 01:22 AM   #599
Rob H.
Rob H.'s Avatar
Yesterday I took off the old MC on the 72 and pulled the back wheels, discovered the right side had been stuck on and had worn a groove in the drum. Oh well, just more parts to buy. I did score a great deal on a 98 Tahoe today to replace the 96 burb the recent flood damaged.
Rob
48 Willys CJ2A
Rob H. is offline
Old 08-07-2010, 01:32 AM   #600
Ackattack
Ackattack's Avatar
Installed injectors into the LS6 intake manifold, removed the truck intake manifold, and started installing the LS6 intake. My aftermarket sending unit was hitting on the throttle body, so I removed that and put in a pipe plug. Now the intake fits like it should. Just got to bolt it down and get a 90 degree -6 AN fitting for the fuel line.
Ackattack is offline
Closed Thread
