05-10-2013, 03:20 PM | #576 |
6>8 Plugless........
Re: 72 k20 project
Nice work! I need a fancy machine toy too.
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
05-10-2013, 03:30 PM | #577 | |
Re: 72 k20 project
05-12-2013, 09:04 PM | #578 |
Re: 72 k20 project
Very true
05-12-2013, 09:11 PM | #579 |
Re: 72 k20 project
i planned to get a little more done this weekend, but i ended up doing a bunch of other stuff, including cleaning my messy garage.
but i did get the frame notched and plated back in for the compressor housing. i may need to buy another pro-werks donut for the turbo to turbo boost tube. the hot pipe donut is supposed to ship this week, so i can do that. i also need to make a plate for the charge pipe on the intake so i can look at that. i know this is a bit of a repeat, but i really like looking at twins |
05-13-2013, 03:30 PM | #580 |
Re: 72 k20 project
Very nice! Enjoy iy because I can only see one turbo on mine still.
05-13-2013, 11:59 PM | #581 |
Chevy Enthusiast
Re: 72 k20 project
Man that looks so awesome, I love that plate you made!
Tony 1985 GMC K2500 restoration Project: Rust, White & Blue 1989 Chevy R3500 CC Cummins & 4X4 swap some day... 1989 Burb (D60, 14BFF, 12V, NV4500, NP205, 37" tires in progress) |
05-21-2013, 08:20 PM | #582 |
Re: 72 k20 project
Thanks!
i had a long weekend out of town, but i did manage to piddle a little before i left on friday and again a little this afternoon. i need to pick up a short length of 3" strait tube. the leg on the other half of this u isn't long enough. then i can run it down to the I/C and then ill need to order das boot. ill take this stuff in to work to Tig weld it this week sometime. hopefully my a/c bracket will come from my Iowa friends this week or next, and i can start on the other piping. |
05-21-2013, 09:32 PM | #583 |
Carpe manana
Re: 72 k20 project
Lookin' good....don't forget to add oil to the motor before firing it up for the first time
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 Members met: ORANGBLAZ, 2003 silverado, MikeCofield, BB72CHEVKT, Duncan&Son, Sameyrasmea72, THENEWMEXICAN, HotRod C/10, brianthelion02, Sport/Truck, ryanroo, michael bustamante, Dirt's72, Already Gone, WestButteTruck, 57taskforce, Moreyel, painterljp, AASmedic, SoCoC10, Lumaestas, carbuff382, Chevyland |
05-21-2013, 10:50 PM | #584 |
Re: 72 k20 project
Nice work Ryan! You have a lot more room than I do so far.
05-21-2013, 11:57 PM | #585 |
Re: 72 k20 project
Nice work Ryan! That's going to be sweet!
1980 K10 - 6.2L Diesel/SM465/NP205 Build Thread 1984 K30 CC Dually - "The Tank" 12V Cummins/Nv4500/Np205/D60/D70HD 4" lift & 37's Build Thread 1960 C-60 Dump Truck Make it road worthy! Thread |
05-22-2013, 12:01 AM | #586 |
Chevy Enthusiast
Re: 72 k20 project
Awesome! It looks like you have room for one more... lol
05-22-2013, 10:17 PM | #587 |
Re: 72 k20 project
Thanks guys!
so i received a part today the C stands for cash, as in all of it the water neck will be tight, but i can make it happen here it is with the incredibly nasty dodge compressor. it looks like the inlet for the primary will have to be a little on the stupid side, but i guess i can work with it. for any swap where the compounds or the oem single are in the oem position and you have oil filter relocate kit, this water inlet bracket would be fantastic for frame clearance. since my turbos are forward, i get stuck with annoying. also got the hotpipe welded |
05-22-2013, 10:27 PM | #588 |
Junk Yartist
Re: 72 k20 project
Still studying your fabrication and engineering! Lovin it!
-Jeremy YOU ONLY FAIL IF YOU STOP TRYING 70 Crew Cab Build Link 70 GMC Suburban 4X4 build thread 95 Yukon Daily Driver Rebuilding an NP205 |
05-22-2013, 10:56 PM | #589 |
Re: 72 k20 project
Nice welding! Dang, I wonder what those oil filter relcating things look like. I'm surprised the Dodge sanden compressor fit on that inlet too. Very nice though.
05-22-2013, 11:17 PM | #590 |
Re: 72 k20 project
i have read that they wont, but i saw mosesburbs and it had the stocker on it... so i ordered it and figured i would see. this compressor is cooked, so i may look into the F-800 one that has the more compact outlets.
relocation kits... yeah.... |
05-23-2013, 12:54 AM | #591 |
I had a V-8
Re: 72 k20 project
If you are referring to the a/c compressor, mine is not a Dodge unit. It is a Freightliner application. The exact application escapes me right now, but I can check the file of doom for the invoice if you need the number on it.
1972 K20 Suburban, 5.9L Cummins, Banks Power Pack, NV4500HD, NP205, H.A.D., D60/14FF ARB Link To Build: HERE. |
05-23-2013, 07:51 AM | #592 |
Re: 72 k20 project
possibly, i think i have the number for either an FLsomething or F-800 saved on the computer right now. for some reason i thought the mounting base dimensions where different on the MD compressors. im glad i have options though!
05-23-2013, 03:06 PM | #593 |
Re: 72 k20 project
Ryan, I may have an inlet that bends around and points down from a 4BT that may fit your situation. I will see if I can locate it.
05-23-2013, 11:27 PM | #594 |
Re: 72 k20 project
Thanks man!
05-24-2013, 09:05 PM | #595 |
Re: 72 k20 project
Poly will last longer and more "High Tech and pricey", however rubber will help more with any vibration and ride.
05-26-2013, 01:57 PM | #596 |
Re: 72 k20 project
Dude this fab work and engineering is impressive. Way beyond me! I'm lucky to be able to just put it back together the way it was!! Can't wait to see this finished..
Shawn 68 chevy K/20 05 chevy 3/4 4x4 71 short step-sold 71 chevy Beauville van My build. http://67-72chevytrucks.com/vboard/s...d.php?t=633039 |
05-28-2013, 11:29 PM | #597 |
Re: 72 k20 project
05-28-2013, 11:33 PM | #598 |
Re: 72 k20 project
That bumper looks sweet! That's close to what I want to do on mine.
05-28-2013, 11:48 PM | #599 |
Re: 72 k20 project
Very nice work on the bumper Ryan!
