Old 04-04-2012, 03:16 PM   #576
fencepost
fencepost's Avatar
Re: No Limit's "K-10"
I see very little sleep in your future Daniel-son.
fencepost is offline   Reply With Quote
Old 04-04-2012, 08:44 PM   #577
Nsanehotrodz
Nsanehotrodz's Avatar
The truck looks great Rob! What size master cylinders are you running for the brakes?
www.nsanehotrodz.com
customerservice@nsanehotrodz.com
865-761-0460
Tennessee's #1 HotRod Shop!
Nsanehotrodz is offline   Reply With Quote
Old 04-04-2012, 10:24 PM   #578
robnolimit
robnolimit's Avatar
It's a Wilwood tandem pedal set with a balance bar. 3/4" front, 7/8" rear. It feals good, takes a bit of adjustment to get it right.
GoodGuys 2012 Pro-Truck Champion
2012 Truckin' Throwdown Champion
GoodGuys 2011 National Champion
2011 Truckin' Throwdown Champion
GoodGuys 2010 National Champion
Proud to put our products up against all others!
robnolimit is offline   Reply With Quote
Old 04-05-2012, 05:15 AM   #579
mcmlxix
Collector of Projects
mcmlxix's Avatar
I found that Harley (and the after market) make indicator lights... Not overly expensive and seem to be readily available. Just thought I would share ...
Turn Indicator.............. Factory P/N: 68021-92A ...... Biker's Choice P/N: 48-2649
Hi Beam Indicator......... Factory P/N: 68023-92A ...... Biker's Choice P/N: 48-2648
Oil light Indicator.......... Factory P/N: 68020-92A ...... Biker's Choice P/N: 48-2650
Neutral Indicator ......... Factory P/N: 68024-92A ...... Biker's Choice P/N: 48-2646
Rich
1972 K5 Blazer CST Click HERE
Old 04-05-2012, 11:27 AM   #580
robnolimit
robnolimit's Avatar
Thanks, those are pretty cool, I think I'll get some of those. I looked at some other 'aftermarket' indicators, - not so cool lookin. lol
Old 04-05-2012, 03:27 PM   #581
Rstone1
Hey Rob
Wondering were the final wieght ended up and what the weight balance is front to rear?
Rstone1 is offline   Reply With Quote
Old 04-05-2012, 04:59 PM   #582
67chevemall
67chevemall's Avatar
AWESOME MAN ! WOW ! AWESOME! WOW
what did you cut the front window with??
1968 Chevy C10 307 3ott fleetside
1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold
1967 Chev C/10 step, 383, M21. SOLD
67chevemall is offline   Reply With Quote
Old 04-06-2012, 02:25 AM   #583
68 TT
Still plays with trucks
68 TT's Avatar
Great to see you guys got the truck done and to the event on time. Sounds evil and gets along pretty darn well. Great work. Definitely a new standard by which all other performance trucks will be judged.
On my drag cars with electric water pump drive & electric fans I usually set them up with a Hypertech low temp fan switch to turn them on in addition to a manual control switch. The one I like is designed for third gen TPI Camaro's and comes on at 176 degrees & off at 166.
The fans & water pump drive come on & go off when they should without having to remember them and the manual switch allows me to turn them on in the pits and cool things down when needed.
Depending upon how you wire the thermostatic switch it can continue to function after key off or stop working when the key is off and the fans & pump will only function when the manual override switch is flipped. I like the last option as you can cool the thing down even further than the low cut off point of the thermostatic switch while in between passes.
A dash mounted indicator light is a good idea so you can tell when they are on and if they are coming on when they should to trouble shoot the system when things break.
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been https://67-72chevytrucks.com/vboard/...d.php?t=484426
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
68 TT is offline   Reply With Quote
Old 04-06-2012, 11:17 PM   #584
widewhite70
widewhite70's Avatar
Awesome! Wish I would've saw this sooner.
-Calvin
http://67-72chevytrucks.com/vboard/s...d.php?t=512270 my build, tube chassis and LS2
How I keep the truck shining, Detail thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=697902
widewhite70 is offline   Reply With Quote
Old 04-07-2012, 03:26 PM   #585
robnolimit
robnolimit's Avatar
Yes, we are stressed about cooling. We have the ECU set to turn the pump on at 160, and the fan at 190. Also we have a temp switch back at the radiator for the fan, on at 210, off at 185 (batt power, key off, to cool down between rounds), also two override swithes for the driver. We missed the indicator lights, but after the first time out, they would be welcomed, so we will know when the pump & fan are on. - can't hear 'em in the cab
Old 04-07-2012, 03:38 PM   #586
robnolimit
robnolimit's Avatar
So, today I started tinkering. I built the truck with 500lb springs in the front, and 200 lb in the rear. Probably seamed like a good call one night. After scaling the truck, 2930lbs now, 1550 up front, 52.9%, I checked RideTechs spring rate calculator. It says 350, and 175. Hmm, not so close up front. So I thought I'd change the fronts to 400 lbs (don't have any 350's around, besides, I'm concerned that may be too soft) As I was working on changing the springs, I spotted something else that we missed. When you assemble a set of Ridetech coil-overs for the first time, you have to screw the rebound adjuster knob all the way in to get the spring collar past it and onto the shock. Then you need to unscrew it back to 'zero', and adjust it in from there. If you forget to do this, at any hour of the night or day, with the adjuster all the way in, the shock is set with the rebound at 'max tight'. I have to say, I couldn't pull these apart for my life! 28 clicks back to 'zero' and 6 clicks in for now. Guess what, now, if i push down on the front end, it actually moves, and comes back up nice and smooth. Yep, it's a novice mistake, I'm almost afraid to go work on the back. later.
Old 04-07-2012, 04:11 PM   #587
smbrouss70
smbrouss70's Avatar
In the short amount of time that you fabricated , painted, and assembled this truck, I think ANYBODY would have missed way more than that!
Steven
"If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers
R.I.P. Oscar
R.I.P. Ratchet
1967 Pontiac GTO - Dad was the Original Owner
1970 Chevy 2wd SWB "Oscar's Truck"
1970 Chevy 2wd Blazer "Ratchet's Blazer"
2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar"
2017 Chevy Suburban "BDB"
2020 Chevy Blazer Premier "Foxy"
Shop Build
smbrouss70 is offline   Reply With Quote
Old 04-08-2012, 08:24 AM   #588
Mike Bradbury
Mike Bradbury's Avatar
Rob it was fun to see the truck at Del Mar and to talk to you about it. It had been a while since I checked on the progress of this project and I was stunned to see it all together and painted. It is cool to read about your progress and see you pictures but it is an entirely different experience to see it in person. You have really put together an awesome truck I can't wait to see the numbers you put up once it gets all dialed in.
I'd rather attempt something great and fail.. than try something ordinary and succeed. Norman Vincent Peale
Project: Barn Raising http://67-72chevytrucks.com/vboard/s...d.php?t=414961
Project: 30 Be Low https://67-72chevytrucks.com/vboard/...d.php?t=830583
Mike Bradbury is offline   Reply With Quote
Old 04-08-2012, 07:52 PM   #589
406 Q-ship
406 Q-ship's Avatar
Here are some indicator lamps I have come across in my travels.
http://www.newvintageusa.com/panels.html
Lifes journey is not to arrive at the gate well preserved, it is to slide in sideways all used up and wore out yelling.....God what'a ride!
Where patience fails, force prevails
Stapp's Ironical Paradox "The universal aptitude for ineptitude makes any human accomplishment an incredible miracle."
406 Q-ship is offline   Reply With Quote
Old 04-09-2012, 04:34 PM   #590
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Rob, if that was the worst thing that got put together wrong in a hurry, you have little to worry about! I know how those all night multy day thrashes go. It takes a toll on ya!
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 04-16-2012, 11:58 AM   #591
ohsolowtrent
Hey longhair heard through the grapevine your comin East with the resale red wonder wagon? Did you get the cup holders worked out for the interior?
ohsolowtrent is offline   Reply With Quote
Old 04-16-2012, 02:57 PM   #592
robnolimit
robnolimit's Avatar
Cup holders are not the problem, it's in flight fueling! If we can work out the transfers, we be back on your side of the big hill. Going to the dyno tuesday at Westech. Plowed any corn with 'ol blue yet?
Old 04-16-2012, 03:04 PM   #593
CHRIS67GMC
CHRIS67GMC's Avatar
Im thinking the Mother Trucker Twety Twelve Tour has a nice ring to it. I have alot of work to do to get ready for this. Rob is my care package on its way?
CHRIS67GMC is offline   Reply With Quote
Old 04-16-2012, 03:06 PM   #594
robnolimit
robnolimit's Avatar
Yep, it left friday, three boxes of speed.
Old 04-17-2012, 10:28 AM   #595
ohsolowtrent
Well I didn't know you hood rats new what a dyno was let alone use one, poured some whiskey in that ole tractor Sat. and she lives! primered the **** box last night paint today shame, you can't make it for the 5th of May send that s-10 on steroids of yours back home with a black eye! What are you and Smitty up to? Watch that boy he's from northern Ohio you get him going to fast and he might get sick. Mother Trucker 2012 tour? That is funny, there will be t-shirts right?
Old 04-18-2012, 01:54 AM   #596
robnolimit
robnolimit's Avatar
It would Almost be worth it to transport a FAST truck back to ? where? to kick you off the Banks and back to the barn. But then your mom would call and complain, and people would call me a bully, bla-bla-bla. Smitty is Ok as long as you don't let him run an auto trans, then he gets into this whole sun-god thing. Mother Trucker 2012, I like it.
Old 04-18-2012, 11:52 AM   #597
ohsolowtrent
Load ur up and hook er up to that mobile home and head this way big boy ,you can park at the shop and I'll give you a ride to airport after Nashville, then you'll only be 7 hours from Des Moines. I told Smitty I'd come up there and help him cut up that c-10 he's building but he wants a pretty boy truck you better have a word with him. How long did it take you to steal the dyno yesterday? Well I'll let you chew on my offer I know it's a long way for 2nd place but just think of the fun well have beatin up all those Camaro's!!!!
Old 04-18-2012, 11:54 AM   #598
robnolimit
robnolimit's Avatar
Highlight Real: OK, so yesterday we put it on a dyno at Westec Performance. These guys really know there stuff. Right from the start, the first pull was 328hp, 352tq at the tire. Thats about what the 'Bullit puts down. Not to bad, but a bit on the low side for an LS. First thing - the ECU was locked, previous tuning took it's toll. Off the the bone yard for a new-used ECU, $100 bucks. Quick flash and a pull, 366/371. - Has a definate miss. Broken rocker arm? no, pulled all the plugs, went to a colder NGK, then found the dead coil. Had some used spares. BTW, the #8 plug is a bit*h to change. Runs clean now. They took the time to scale in the MAF, and then another full pull. 394/392. Now it was real tuning time. Part throttle, midrange, fuel consumption...... I was happy that it never got over 220 degess with all of the running under load, it was 92* here. The final numbers were 418 hp @ 6450, and 408 Tq @ 4900. The torque is above 400 at 3450, and stays up above 375 'till 5800. All this on 91 octane pump gas.
Then it was road test time. We drove it from Westec to Adams Motorsports Park, about 15 miles, 10 on the fwy. No trouble, rides great, new gears in the quickchange are much quieter. At AMP we ran about 20 laps on and off to feel it out. All was going great then as I was getting a little more comfortable, SNAP, I busted a sway bar link! I guess economy rod ends aren't up to it. So that was it, then a 22 mile drive home, no trouble. All in all a good day/night.
Old 04-18-2012, 01:09 PM   #599
Low Elco
Great progress! Amazing what you can find out on those dynos. Gonna be unstoppable once you're REALLY dialed in! Whens the next time on the main stage?
Low Elco is offline   Reply With Quote
Old 04-18-2012, 02:38 PM   #600
robnolimit
robnolimit's Avatar
May 11th, is the Truckin' Throwdown. check out our facebook page, we'll be posting live. Then Pleasanton Goodguys in june.
