04-05-2014, 05:13 PM | #576 |
Re: How about some pics of Static dropped 60-66
I love the stance of your truck. I just purchased a 66. It's my first project. I have a couple questions I was hoping you might answer for me. I want to drop the front 2 in the front. is yours a 3 or 4" drop in the back?
Thanks for the help! |
04-06-2014, 10:09 PM | #577 | |
Thanks,
Billy 65 C10 ............................... ____ ................ ________-|___\____ .;.;;.:;:;.,;.|__(O)___|____/_(O)| _______________________________ P.S. Send truck money ! |
04-06-2014, 10:19 PM | #578 |
My 60Five
ECE- 2.5 Spindles CPP- 2" springs CPP- 5" rear springs
04-07-2014, 11:09 PM | #579 |
4" CPP springs out back and for the life of me I can't remember what I went with up front. Thinking 2" but not sure. I wish I knew so I could order lowered shocks. Anyone happen to know the stock height of the front end on a 66? |
04-12-2014, 10:16 PM | #580 |
not sure what front springs were maybe 3 inch they are ground force,rear are belltech 5 inch drop, gonna need to trim bumpstops about 1/4 inch gap up front and none in rear pretty happy with results before and after pics
04-14-2014, 11:17 PM | #581 | |
Chris
1966 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=615165 1968 GTO http://67-72chevytrucks.com/vboard/s...=1#post7650182 |
04-15-2014, 07:50 AM | #582 |
Thanks, 255/70/15 on all 4.
04-15-2014, 11:00 AM | #583 |
It looks like you still have a good amount of tire gap between the front fender. I would say it's a 2" drop coil. With companies like CCP, they have a generic lowered shock for all their kits. A shock for a 2" drop coil and a 3" drop coil is going to be the same.
04-16-2014, 02:16 PM | #584 |
A little before and after-
04-16-2014, 05:03 PM | #585 |
04-17-2014, 02:09 AM | #586 |
Hey thanks! No idea what the total is. It sits on trimmed drop springs up front and cut stockers with 2" blocks out back. Removed the bump stops and mounts both front and rear. Relocated the shocks up front. Pie cut the control arms. Mild C notch in the rear.
Its pretty much maxed out. I think I am going hunt for a set of Jeep springs for the rear. The rear is very "buck board-ish" right now. Front is good. |
04-17-2014, 06:31 AM | #587 | |
04-17-2014, 10:38 AM | #588 | |
LIFE IS SHORT HAVE FUN |
04-18-2014, 12:12 PM | #589 |
Finally got the stance where I want it. Jeep springs and 2" blocks in rear ece 2.5 spindles and factory springs in front.
04-21-2014, 11:11 AM | #590 |
CPP 5 inch springs in the rear- 3 inch springs with 2.5 inch spindles in the front.
04-21-2014, 11:44 AM | #591 |
04-21-2014, 09:11 PM | #592 |
04-21-2014, 09:54 PM | #593 |
Rollin' Old Skool
x2, nice truck!...stance looks great as well.
_____________________________________________ Phillip My Build threads: 1966 Chevy C-10 "Black Betty" shortbed, fleetside, BBW, 327 V8/ Powerglide (under construction) http://67-72chevytrucks.com/vboard/s...ighlight=betty 1997 Chevy Tahoe, 2dr/2wd, mild custom (Daily driver) http://67-72chevytrucks.com/vboard/s...d.php?t=601142 Pics: '66 C-10 https://flic.kr/s/aHsjHWD4h9 '97 Tahoe https://flic.kr/s/aHsjGZ7wKP '93 C-1500 https://flic.kr/s/aHskxdpdnQ '88 S-10 Blazer https://flic.kr/s/aHsjYGx4Md Previous Rides: 1993 Chevy S-10 ext. cab, 4.3L, 4/5 drop (Sold) 1993 Chevy C-1500 short/step Retro-Rod (Sold) 1988 S-10 Blazer 2dr/2wd mild custom (Sold) |
04-23-2014, 09:14 AM | #594 |
Truck is PERFECT!!! Love it!! Exactly how I want mine to sit!
04-24-2014, 11:16 PM | #595 |
I need to lose that gap in the front. Will 3" springs do that? Thanx!
04-25-2014, 01:34 AM | #596 |
digging the stitching on your bench, looks clean and ties the truck together
04-29-2014, 07:22 AM | #597 |
Some great stance and lowering here.
I have a '66 Short Fleetside which has been lowered with heated cools etc a long time ago. THREAD HERE: http://67-72chevytrucks.com/vboard/s...d.php?t=585901 The truck behaves like a rubber duck on water when doing the bends. It is fitted with a 350/3 speed auto combo that obviously influences ride height a bit. I am looking at replacing the shocks and springs when I repaint and strip down the truck. Brothers currently has 50% off on the lot. My truck parked up in the garage shows these measurements to the underside of the fenders. Front 27 1/4 Rear 26 1/2 on passenger side 26 on driver side Does anyone have the stock standard measurements for these truck front and rear please??
MY BUILD LINK: http://67-72chevytrucks.com/vboard/s...585901]Redneck Express - 1966 C10 Short Fleetside MY USA ROADTRIPS http://forum.retro-rides.org/thread/...2018-humdinger IF YOU CAN'T FIX IT WITH A HAMMER, YOU'VE GOT AN ELECTRICAL PROBLEM MATE. |
04-29-2014, 04:10 PM | #598 |
The measurement from the fender lip to the center of the hub would be a better way to measure. Otherwise you have to take the tire size in to consideration. That being said I don't know the stock measurement.
Name: Rich Current Ride: 1964 C-10 Short Fleetside Daily Driver: 2005 GMC crew cab short fleetside /2001 Chevy Tahoe Past GM Trucks: 1959 GMC short stepside 1968 GMC short stepside-4x4 1973 Chevy short stepside 1989 Chevy short fleetside-reg cab 1993 Chevy short fleetside-Xcab 2002 Chevy short fleetside-Xcab Save the dinosaurs, use synthetic oil. |
05-03-2014, 08:42 AM | #599 |
Here is mine
64 with ECE 4.5/6 dropp kit 245/60x15 on front and 275/60x15 on rear Wheels are 15x8 Eagle Alloys
05-03-2014, 06:42 PM | #600 |
This is my '65.
4" LMC coils and lowering shocks on the rear. 2" drop spindles and lowering shocks on the front with cut coils. I would like to get a bit of a reversed steel rim going for the rear wheels. Any suggestion where to go to get the widest, deepest that will fit with a set up like this? Any help would be appreciated |
