Old 07-14-2014, 12:04 AM   #576
lenguini
lenguini's Avatar
Re: Project truck dream 65"
After several hours of prep, and repositioning the receiver mount as it was to high.....,I sent the trailer hitch out to the powder coaters.I just got it back and did a final bolt in.It looks great and was worth all the work !
I was going to go with a later Chevy power steering pump with the reservoir directly attached but I thought there would be clearance issues with filling it.
I ended up going with the remote setup that I'm mounting on the battery side of the shroud. The res was custom made for me by J.A.C. Specialties. All stainless construction. It has an internal baffle ,screw in cap at a custom height I wanted at 6 1/2 "total height.
So in the last few days I made a mounting bracket for the res.:ito
Always a place in my heart for old Chevy trucks:
My build thread-project truck dream 65"
http://67-72chevytrucks.com/vboard/s...d.php?t=510863
lenguini is offline   Reply With Quote
Old 07-23-2014, 01:42 AM   #577
lenguini
lenguini's Avatar
I managed to finish one vent window rebuild, the repo chrome junk went back to the supplier, and happy for it. Nothing like the originals.
Powder coted and cleared with the new tinted glass installed. I had a few problems with the window regulator as this door was caved in on the outside and obviously bent some of the internals etc.
After a few hours, I have it rolling up and down well, glad I did this now before paint !
Old 07-25-2014, 01:10 AM   #578
lenguini
lenguini's Avatar
Just got my inners back from the shop today. Start to now,there are 30 plus hours into them,but well worth it in the end.
Duraguard on the underneath,with base,three coats of clear...wet sanded and polished.
Tonight I installed the weatherstrip with hopes of getting them on this weekend so the fan shroud can be centered and cut.
Old 07-28-2014, 02:16 AM   #579
lenguini
lenguini's Avatar
Was a busy boy over the last few days. Got the inner fenders bolted in place ....no stress there with the new paint and started putting the front end back together.The grill is temp mounted ,drilled and mounted the rear cab trim.
Old 07-28-2014, 09:33 AM   #580
rustbucket66
Very nice. Your attention to detail really shows. I hope we can hook up one day with our trucks and compare notes. I continue to follow your build, I like the fabricating and unique ideas you have. Keep on it.
rustbucket66 is offline   Reply With Quote
Old 07-28-2014, 06:49 PM   #581
NONHOG
NONHOG's Avatar
Wow! Very cool. Nice going!
"I feel the need for speed!"... as soon as I am done with my nap.
NONHOG is offline   Reply With Quote
Old 07-28-2014, 10:13 PM   #582
Bomp
Bomp's Avatar
Very Clean. Very Sharp.
Bomp is offline   Reply With Quote
Old 07-28-2014, 10:33 PM   #583
Bigru
Bigru's Avatar
Nice!!
1965 Short Fleet
http://67-72chevytrucks.com/vboard/s...d.php?t=637478
1983 Short Fleet (Under construction for my 13 year old son)
2008 GMC Denali
2012 Harley Roadglide
Follow me on Instagram: Ru_django
Bigru is offline   Reply With Quote
Old 07-28-2014, 10:47 PM   #584
pdxhall
pdxhall's Avatar
Lookin' purdy with all that shiny stuff.
Sanity'66
http://67-72chevytrucks.com/vboard/s...d.php?t=515110
Long bed, Fleetside, Small back window
I've Done So Much, With So Little, For So Long, That Now I Can Do Anything With Nothing.
pdxhall is offline   Reply With Quote
Old 08-09-2014, 06:24 PM   #585
lenguini
lenguini's Avatar
Thank you all for the complements, they keep me inspired. I'm really aiming for this project to be in paint by the year's end......?
Old 08-10-2014, 10:10 PM   #586
lenguini
lenguini's Avatar
Polishing,measuring,tackwelding,measuring,cutting ,drilling,clamping.....................fan shroud now finally off for final welds.
I designed a system that will allow the bottom portion of the shroud ring to unbolt allowing the remainder of the shroud to easily be removed for any future servicing.
In the second pic you can see some reference points marked in black, they are for mounting tabs that will hold panels I'm making to cover the tanks on either side of the rad.
Old 08-11-2014, 07:45 AM   #587
Dubnova
This is one nice ride! You are knocking this thing out of the park and the White don't look bad either.
Dubnova is offline   Reply With Quote
Old 08-16-2014, 08:19 PM   #588
SSpeed66
SSpeed66's Avatar
Hey Ed, who did your chroming, and are you satisfied with their work ??
Al in Winfield
Living The Canadian Dream in British Columbia
SSpeed66 is offline   Reply With Quote
Old 08-16-2014, 10:50 PM   #589
Modges'66
Modges'66's Avatar
Location: Grand Rapids, Michigan, otherwise known as Beer City U.S.A.
Awesome work as usual!
I'm always watchin your thread!
Modges'66 is offline   Reply With Quote
Old 08-30-2014, 09:48 PM   #590
lenguini
lenguini's Avatar
Al in Winfield
Victoria Plating and yes,the best in B.C..
Old 08-30-2014, 09:49 PM   #591
lenguini
lenguini's Avatar
Thanks,getting closer !
Old 08-30-2014, 09:50 PM   #592
lenguini
lenguini's Avatar
Thanks,I appreciate the complement !
Old 08-30-2014, 10:00 PM   #593
lenguini
lenguini's Avatar
Finally finished up with the fab work on the shroud.I wanted a 2 piece for water pump change ,etc. later on.This was some figuring....,but worked out great.
I also had the power steering res bracket welded into place.
I build a temp press for an angle profile on the rad tank covers,worked out not bad !:
Old 08-30-2014, 10:10 PM   #594
Modges'66
Modges'66's Avatar
Lookin super clean!
No fingerprints allowed!!!
Clean that up! LOL!
Old 08-30-2014, 10:11 PM   #595
lenguini
lenguini's Avatar
So after a lot of sanding and polishing, I mounted the tank covers in place.Here are some pics of the almost finished product.
Also got my hinges back from the powder coaters, They turned out pretty good.Tricky job as you have to spay them fully open and then again in closed position. I was going to get them plated, but chose this instead
Old 08-30-2014, 10:14 PM   #596
lenguini
lenguini's Avatar
Lookin super clean!
Clean that up! LOL!
I was trying so hard not to leave any...and of course the dam camera flash showed them all !
Old 08-30-2014, 10:33 PM   #597
Modges'66
Modges'66's Avatar
Dude!
I know how hard it is!
Every time that you turn around, to gotta get out the Mothers and clean everything up!
I feel like I am doin it all of the time!!!
Old 08-30-2014, 10:44 PM   #598
lenguini
lenguini's Avatar
Dude!
Tomorrow, Im heading to the beach to find a gal who likes to clean....., and will wear a bikini year round. Problem solved
Old 08-30-2014, 11:55 PM   #599
Modges'66
Modges'66's Avatar
You know what?
If she will wear a bikini all year round, she doesn't really need to clean, does she?
I am willing to bet that if she is always wearing a bikini, that you will soon forget about polishing aluminum...
Old 09-08-2014, 11:55 PM   #600
lenguini
lenguini's Avatar
You know what?
Found one.....what were we talking about ?
