#576 |
Just like to part out trucks!!
Re: Christmas BONANZA ALOT of 67-72 truck parts!!
Betty, I looked in one shop never found one, I'll look at my other storage today
Robert, I'll pm you total Thanks Randy
67 Chev swb stepside 4x4 283 4 speed SOLD 72 blazer 4x4 4 speed Cheyenne 72 GMC swb 4x4 fleet 4 speed, original paint 1958 Cameo (one of 1405 built, it was my dads) 2020 chevy Apex 4x4 crew cab 1969 Z28 with the 302 1980 chevy swb 4x4 1964 chevell Malibu SS 1976 K20, sold new originally out of my dads chevy dealership Members that I've met, over 200 probably closer to 300 in the 12 years I've been on this site, everyone I met "It was a pleasure" |
#577 |
OK, thanks for checking.
#578 |
The AC hoses arrived safely yesterday. Thanks
#579 |
Active Member
![]() Join Date: Mar 2012
ok sounds good...also I noticed the circle part in the pic the boot/gasket or whatever you call it is leaking oil/goo. Do you have one or know where I can get a replacement one?
thanks randy... betty |
#580 |
unclegrape, no problem, if I get one in I will PM you
Tony, glad they got there OK, Thanks Betty, I will know later tongiht on fan, I know I have a 5 blade fan with clutch on one truck. I have this steering section
#581 |
Active Member
ok, let me know about the fan...As for the steering piece...would/do I need to replace the whole thing? (like the pic you posted?) Or can I just replace the end pice? (like the pic. I posted?)
thaks, Betty |
#582 |
Active Member
ohh and forgot to ask if the shaft piece is the same for manual or power steering? cause there was a whole other steering box thing included when I got truck. Just never looked at it to see if it would work. This may answer why he included it...lol
thanks, Betty |
#583 |
Betty, I don't think you can repair the end piece on the one you have. This shaft was used on some 68 and all 69-72 trucks. The early columns were one piece and they went to this style.
On the fan the only 7 blade fanwith clutch I have is 19 1/2 wide, not original for our years Thanks Randy
#584 |
Active Member
Well as for the fan...I have a new fan clutch...so I really don't need one...would need bolts to mount it to the fan. How wide should the fan be for our trucks? And as for the steering piece I'll dig out the other steering box that I got with the truck and take pics tomorrow and post them and see what ya think...
thanks, Betty |
#585 |
Parts came today. Look great! Thanks for the quick shipping! Got any caliper to brake hose "banjo" type bolts? 1973?
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
#586 |
Active Member
ok nevermind the pics...When I pulled the other steering piece out of the small shed I noticed it the rubber boot thing is broken as well. So I will need the piece...afterall. So let me know how much and shipping costs...
Any luck with a fan? or size of the fan I need? thanks, Betty |
#587 |
![]() Join Date: Sep 2012
I am in need of some black 71 c10 belts. You have a y?
Posted via Mobile Device |
#588 |
FLchevygrl, Betty, stock fans are 18 inches if I remember right so this one is 1 1/2 inches wider. The steering piece is $25 shipped
jjzepplin, glad your happy with the parts, sorry no brake stuff right now 71swbtexas, sorry no black belts right now Thanks Randy
#589 |
Active Member
ok, done on steering shaft...I think you only accept money order right?
if so shoot me a PM and I'l mail it off tomorrow... As for fan does the size really matter? I'm not using a shroud now..or yet...lol thanks, Betty |
#590 |
Betty, the size of the fan won't matter if you don't use a shroud, another $15 for the fan without clutch. Thanks Randy
#591 |
Active Member
ok, sounds good...so 40 total with shipping...Send me a pm with where to send the money order. I'll get that out to you asap.
And if ya happen to run across a 7 blade that will work with a shroud save it for me... thanks, Betty |
#592 |
OK Betty, when I get a 7 blade stock fan in I will pm you. Thanks Randy
#593 |
Still have alot of parts for sale
#594 |
![]() Join Date: Dec 2012
Hi Randy-
Perhaps you can help me with a speedo issue?? The speedo on my '67 has never worked. Bought a new cable and installed it yesterday. Still nothing. Do I need to replace the entire mechanism or might it be something else? Having a speedometer/ odometer that works would be cool because I don't have a working gas gauge either!! Any advice?? Reed Martin |
#595 |
Reed, it cuold be your whole cluster or a wiring problem or your circuit board on cluster. You might post a thread on message board someone else might know for sure. Thanks Randy
#596 |
Do you happen to have a good set of lower control arms for a half ton?
Thanks, Derek |
#597 |
Derek, sorry I don't part out frontends. Thanks Randy
#598 |
![]() Join Date: Jul 2012
Randy, Im looking for a door jam switch wire harness for my 71. Would you happen to have one? If so, what would it be shipped to 76028?
Bryan |
#599 |
Bryan, sorry I don't ever save those setups, Thanks Randy
#600 |
Have any p/s gearboxes left? putting on a 68, with newer p/s pump serpentine setup from 90s tbi truck.
business address 40299 |
