Old 06-09-2016, 09:47 PM   #576
youngrodder
youngrodder's Avatar
Re: 53 Surburban "Family Truckster"
Originally Posted by Advanced Design View Post
Looks really good...and it is a good plan to fit everything now. Marc, if you have the part numbers I can just copy you...I think I am falling behind.
Doug-
I'm sure with your help you aren't too far behind. Yes, I can list the fittings. Someone else asked as well. I should see if I can screen shoot my Summit wish list...That would save some re-typing.
Marc
…………...........__________
.................. ((__|__||___\____
..;.;;.:;:;.,;..;((_(O))____ (_(O))
1948 Chevy Truck - Finished SOLD!!
1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021
http://67-72chevytrucks.com/vboard/s...d.php?t=605484
1994 4x4 Blazer - "Field Find"
https://67-72chevytrucks.com/vboard/...ferrerid=30857
youngrodder is offline   Reply With Quote
Old 06-09-2016, 11:06 PM   #577
youngrodder
Here is my fittings and hose part number list. Your quantity and type of fitting might be different based on how you are designing your system. Remember I will be going from rubber flex hose to metal tube back to rubber flex hose
Russell Performance 640863 - Russell Fuel Rail Fitting Adapters
RUS-640863
Fuel Rail Fitting, Aluminum, Black, Straight, 5/16 in., -6 AN, Each
(Mfr. #: 640863) 1
Russell Performance 660443 - Russell ProClassic AN to NPT Adapter Fittings RUS-660443
Fitting, Pro Classic, Adapter, Straight, -6 AN Male to 1/4 in. NPT Male, Aluminum, Black Anodized, Each
(Mfr. #: 660443) 2
Summit Racing SUM-240615BP - Summit Racing® Premium Braided Nylon Hose SUM-240615BP
Hose, Premium Braided Nylon, Black, -6 AN, 15 ft. Length, Each
(Mfr. #: SUM-240615BP) 1
Summit Racing SUM-221330B - Summit Racing® Fuel Rail Fittings
SUM-221330B
Fuel Rail Fitting, Aluminum, Black Anodized, 3/8 in. Male Spring Lock to -6 AN Male Threads, Each
(Mfr. #: SUM-221330B) 1
Russell Performance 640853 - Russell Fuel Rail Fitting Adapters
RUS-640853
Fuel Rail Fitting, Aluminum, Black, Straight, 3/8 in., -6 AN, Each
(Mfr. #: 640853) 2
Summit Racing SUM-220690B - Summit Racing® Hose Ends SUM-220690B
Fitting, Hose End, Straight, -6 AN Hose to Female -6 AN, Aluminum, Black Anodized, Each
(Mfr. #: SUM-220690B) 6
Earl's Performance AT165006ERL - Earl's Performance AN to Tube Adapter Fittings EAR-AT165006ERL
Fitting, Tube Adapter, Male -6 AN, to 3/8 in. Tube, Aluminum, Black, Each
(Mfr. #: AT165006ERL) 2
Old 06-10-2016, 06:06 PM   #578
Advanced Design
Advanced Design's Avatar
Marc, thanks for taking the time to share! I copied and saved for future reference.
Advanced Design is offline   Reply With Quote
Old 06-10-2016, 09:37 PM   #579
youngrodder
My pleasure Doug....anything I can do to help you lock down 2nd place.
Marc
Old 06-11-2016, 09:49 AM   #580
Advanced Design
Marc
I need all the help I can get! Oh, and my crew is already on it.
Turned so hot out still haven't made it to the shop so that doesn't help.
Old 07-05-2016, 09:34 PM   #581
youngrodder
Well I have been working on the Suburban. I decided as much of a pain as it is to put the body back on the frame that it would be best to continue the mock up process. I found myself staring at the frame wondering it this will fit here or if that will fit there. Putting the body back on did prop beneficial to figure out where stuff will fit.
I hade to clearance the flange of the rear wheel tubs to clear the frame notch. I was surprised that the notch didn't stick up any higher then it does. I was able to clearance the firewall to clear the brake pedal. I also confirmed that I don't need a tranny tunnel like I thought so that was a pleasant surprise.
Marc
Old 07-05-2016, 09:38 PM   #582
youngrodder
To clarify the hole for the brake pedal looks huge but the pedal has a larger mount for the pedal than shown in the pics. I plan to make a small plate that screws to the floor to cover the hole.
I'm heading to Columbus to the Goodguys show this weekend and I'm driving the 48. Looking forward to seeing some people from this site and grabbing some parts for the Suburban.
Marc
Old 07-05-2016, 09:57 PM   #583
mongocanfly
mongocanfly's Avatar
Looking good marc...that thing has a killer stance..I know you said those wheels wernt what your going to run but they look killer on the burb
Old 07-05-2016, 10:04 PM   #584
Coach529
Coach529's Avatar
Looks GREAT!!
1949 Chevy 3600
"Adventures of Henry"
http://smu.gs/QOlhWY
Coach529 is offline   Reply With Quote
Old 07-05-2016, 10:11 PM   #585
Advanced Design
Good work Marc, body is fitting really well. It sure helps to see it coming together.
Have fun at GG. I have to be in Columbus Friday and we discussed staying over. Decided to head for home after my meeting instead...too much to do.
Old 07-05-2016, 10:18 PM   #586
youngrodder
Thank you...I really wish I would have found 20" for rollers because I can't fit my 13" rotors with big calipers with these ****ty wheels. They look better in pics than in person.
Originally Posted by Coach529 View Post
Looks GREAT!!
Thanks Mike....
Marc
Old 07-05-2016, 10:22 PM   #587
youngrodder
Thanks Doug, it sure does. if you change your mind, check out the crown plaza hotel. It is the host hotel and is a party atmosphere with a lot of cool trucks/cars...
Marc
Old 07-05-2016, 10:33 PM   #588
99 to Life
99 to Life's Avatar
looking very cool, glad you are dodging some bullets!
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc
http://67-72chevytrucks.com/vboard/s...d.php?t=382481
49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold
http://67-72chevytrucks.com/vboard/s...d.php?t=594874
VIDEOS https://youtu.be/E8zHhjgS_lA
Geronimo 54' LS engine, static drop IFS, Client build, just about done
http://67-72chevytrucks.com/vboard/s...62#post7399162
52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame
Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next!
www.coffeeandcustoms.com
99 to Life is offline   Reply With Quote
Old 07-05-2016, 11:19 PM   #589
oldman3
oldman3's Avatar
Looking good Marc, I would rather have the body on two or three times, than get it painted, etc and then find the problem. Of course I don't have to lift it two or three times...Jim
oldman3 is offline   Reply With Quote
Old 07-06-2016, 01:02 AM   #590
CHIZZLER
SAVING ONE TRUCK AT A TIME
CHIZZLER's Avatar
Looking good marc.
53-suburban (99% done)
40-pick up (99.9% done)
12-cc lb dually D-max (dd)
61-crew cab D-max
"PAY LESS FOR WHAT YOU NEED PAY MORE FOR WHAT YOU WANT"
53 BURBAN BARN FIND:http://67-72chevytrucks.com/vboard/s...d.php?t=404091
1940 PROJECT MOON SHINE:http://67-72chevytrucks.com/vboard/s...d.php?t=551088
1961 CREW MAX: http://67-72chevytrucks.com/vboard/s....php?p=6957999
CHIZZLER is offline   Reply With Quote
Old 07-06-2016, 10:07 PM   #591
youngrodder
yes, its good to catch a break every now ands then
I agree but it is a heavy SOB.
Originally Posted by CHIZZLER View Post
Looking good marc.
Thanks man....
Old 07-07-2016, 08:34 AM   #592
lower50's
lower50's's Avatar
That looks amazing sits just right. Have fun at the Good guys show.
http://67-72chevytrucks.com/vboard/s...d.php?t=648459
https://67-72chevytrucks.com/vboard/...d.php?t=769441
1951 MG TD
1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers.
1952 GMC 9700 p/u 7.3L diesel on air, dually
lower50's is offline   Reply With Quote
Old 07-11-2016, 10:41 PM   #593
youngrodder
The GG show was a success for many reasons. I decided to drive my 48 this year instead of trailering. Driving is mush more fun. Over 600 miles round trip with no issues. I got to see Bob's (OldNSlow) truck. Man is it nice. The paint turned out great. He has decided to sell it. Oooops did I let that slip.
I did a fair amount of research on wheel and tire sizes for the Suburban.,
I picked up some Delmo LS1 valve cover adapters from Travis or Pro Performance. Travis is great to deal with and he delivered the parts to me at the show and provided a show discount (win/win/win/). I also found a nice set of script valve covers for CHEAP.....Score.
I got to check out and talk with the owner of Delmos latest truck build. It was a very cool truck.
I also picked up the trim piece I needed to fix the one inner trim from the Suburban..
All in all it was 4 days filled with cars and hanging out.
Marc
Old 07-11-2016, 10:42 PM   #594
98Murray
98Murray's Avatar
Very nice! Good stuff!
98Murray is offline   Reply With Quote
Old 07-11-2016, 10:43 PM   #595
youngrodder
Here are a few more pics..
Marc
Old 07-11-2016, 11:23 PM   #596
oldman3
oldman3's Avatar
Marc, great about the drive to the event, your truck looks great as always...Jim
Old 07-12-2016, 02:07 PM   #597
69CST-V
69CST-V's Avatar
Suburban is looking sick...... and the truck, well we all know its one of the nicest and most recognized AD's out there. Nice work as always.
Bryce
'69 SWB Fleet Still Under Construction
Company Trucks
69CST-V is offline   Reply With Quote
Old 07-12-2016, 04:07 PM   #598
rollenhard
rollenhard's Avatar
Thought you might like to see this marc is that your truck in the background pretty cool
https://www.good-guys.com/ggn-2016
Just Cruzin Through Life
rollenhard is offline   Reply With Quote
Old 07-12-2016, 10:06 PM   #599
youngrodder
Thanks Jim it was a lot of fun..
Thanks I appreciate it. I was excited to pick up a few parts for the Suburban and push this build forward. Of 6,000+ cars and trucks we only saw one suburban close to my vision.
Yes, I noticed that a few weeks back. The royalty checks are still coming in....Yea right. Thanks for sharing.
Marc
Old 07-13-2016, 07:39 PM   #600
Advanced Design
I like those adapters with the covers. And your truck! Thanks for sharing the pic's.
Wife and I were in Columbus that Friday for work. Marc was being a good guy, texting me to convince us to join in. Yeah, We should've...just too much to do at home. Thanks again Marc!
