Closed Thread
Old 09-02-2012, 12:31 AM   #6026
mud.man.rj
mud.man.rj's Avatar
Re: What did you do to your truck today?
What did you paint it with, some kind of primer or epoxy sealer. Looks better without the big front bumper too.
mud.man.rj is offline
Old 09-02-2012, 12:50 AM   #6027
ABX131
ABX131's Avatar
Painted with Rustoleum Colonial Satin Red and Semi Gloss White..nothing fancy and it will fade out to look old in a very short time in the sun.
ABX131 is offline
Old 09-02-2012, 01:09 AM   #6028
dantimdad
dantimdad's Avatar
pulled the rearend, track bar and trailing arms. Tomorrow, I start wire wheeling everything and painting the frame. Hopefully, Monday, I start reassembly.
Steven
“Life is and will ever remain an equation incapable of solution, but it contains certain known factors.” - Nikola Tesla
Matt. 6:27 "Who of you by worrying can add a single hour to his life?”
http://www.67-72chevytrucks.com/vboa...=507266&page=2
dantimdad is offline
Old 09-02-2012, 06:51 PM   #6029
Ta2Don
Ta2Don's Avatar
Nothing to the 65 but had to replace wheel seals and pinion seal on my 90 model DD...
DON
Proverbs 27:17
US Air Force Retarded errr Retired
My '65 Stepper Build:http://67-72chevytrucks.com/vboard/s...d.php?t=533920
My '60 Rusty Patina Build:http://67-72chevytrucks.com/vboard/s...66#post7402266
My '72 http://67-72chevytrucks.com/vboard/s...59#post7204359 SOLD
Ta2Don is offline
Old 09-02-2012, 07:02 PM   #6030
dantimdad
dantimdad's Avatar
Cleaned up a bunch of the rear suspension parts, engine mounts and track arm and got them ready to paint.
The trailing arms, coils and a couple other parts are going to the blaster. I just can't get them clean enough. Besides, my bushings didn't come in so I can't reassemble until next weekend anyway.
Steven
Old 09-02-2012, 07:43 PM   #6031
vin63
It's Better With Nitro
vin63's Avatar
...mounted the evaporator unit under the dash...getting closer handing it off to the body guy for prep and paint.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline
Old 09-02-2012, 08:26 PM   #6032
62 Barnfind
62 Barnfind's Avatar
Painted the front end and welded in the angle strips.
John Z
1962 Chevy C10 Stepside
62 Barnfind
My build tread: http://67-72chevytrucks.com/vboard/s...d.php?t=507513
62 Barnfind is offline
Old 09-02-2012, 09:13 PM   #6033
Chevy Fleetside
Chevy Fleetside's Avatar
I was doing some of the wiring again today. I was all ready to cut the Ign switch plug from the new harness so I could slice and solder an original plug on when I notice I could just switch plugs by removing the clips and slip them on to the original plug. Then I hooked up the battery and blasted the stero. It was nice to have it going under it's own power. I tried to put it full blast but the fuse blew right before I got to full blast. I guess the two 250 watt amps were too much for the 10 amp fuse. Then I hit the key and the started engaged and turn the engine for a minut sec. I had a smile on my face. I hope to get everything done tomorrow and maybe see if it fires with starting fluid.
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline
Old 09-02-2012, 11:06 PM   #6034
Volvo_Matt
Volvo_Matt's Avatar
I looked at it and wished I had some extra $$ and time to spend on it.
1963 LWB 350 M-21 4spd comp/edelbrock/holly/LT1 1.94/1.60
Volvo_Matt is offline
Old 09-02-2012, 11:14 PM   #6035
vintagetin
vintagetin's Avatar
Originally Posted by oem4me View Post
Well, I altered both my all-original truck and suburban from stock. I can no longer say either is 100% factory correct. I added a middle set of seat belts for the little fella. He can now ride with us legally, as opposed to how we all used to ride with our folks. I still think his generation is missing out big-time by not getting to stretch out across mom and dads lap while driving home late after a visit with the grandparents.
But he's not missing out too much because he's getting to ride in Daddy's old truck. How many kids get to that? None. When I was a little kid in the early 90's My dad had a beat up early 70's Dodge Dart. I remember wearing the lap belt in the passenger side of the bench seat while listening to boston on the AM/FM cassette deck. Dad would always stretch out his arm and hold me back when he had to brake hard.
vintagetin is offline
Old 09-03-2012, 02:20 AM   #6036
doobiebro
doobiebro's Avatar
Finally bought my steering wheel to match up with the hotrod steering column I installed a while back....
CURRENT & PAST CHEVY TRUCKS
60 C-10 Apache short step side
62 C-10 short step side
66 GMC Long bed fleet side 305 V-6
77 C-20 Custom Deluxe (Blue Goose)
doobiebro is offline
Old 09-03-2012, 02:27 AM   #6037
mud.man.rj
mud.man.rj's Avatar
Interesting steering wheel, kind of a takeoff of the old original style...but way nicer.
Old 09-03-2012, 10:29 AM   #6038
LT1 Burb
LT1 Burb's Avatar
I tried to break one of my rear ends down and was curious as why it was so black when I took the cover off. I removed the bolt and spent an hour trying to drive the pin out, it was destroyed where it had wallowed out, the gears were junk and there was metal everywhere. I wonder if previous owner had any ideal. I ended up giving up and throwing it into the back of the longbed with the rest of the scrap. Broke my other one down and ready for power washing and paint, ordered a rebuild kit and hope to have it under the frame in a week or two.
LT1 Burb is offline
Old 09-03-2012, 01:51 PM   #6039
Chvyman1975
Chvyman1975's Avatar
Im sitting here looking at it for a while because I need to put the windshield in it but too scared that its gonna break...
Chvyman1975 is offline
Old 09-03-2012, 05:32 PM   #6040
dantimdad
dantimdad's Avatar
Rear bumper brackets off, exhaust hangers cut off finally got the top bolts to the coils off (broke both of them). Now, the rear frame is bare except for the cross member the PO added for the hitch.
Took the t5 to the car wash and got it 75% clean. BTW, the crossmember wasn't even attached to the frame. It literally fell to the floor when I pulled the transmission!
All-in-all, a good day with my son working on the truck.
Steven
Old 09-03-2012, 06:10 PM   #6041
CRGRS 66
CRGRS 66's Avatar
Cleaned it inside and out, took it for a drive (the best part). Chopped a cord of wood in 95F heat (good to have a helper even though all she does is listen to me cuss)... had a shower... went for another drive, little slice of heaven, nice hot afternoon, tunes cranked, ahhhhhhh oh, and look at that! it is time for an Ale, perfect
Craigerrr
My build thread, CRGRS 66 Winter Build: http://67-72chevytrucks.com/vboard/s...09#post5638709
CRGRS 66 is offline
Old 09-03-2012, 06:57 PM   #6042
LT1 Burb
LT1 Burb's Avatar
Added to my scrap load and pressure washed and started to paint my rear end.
LT1 Burb is offline
Old 09-03-2012, 08:19 PM   #6043
fink64
some things are better left to the professionals I learned the hard way with my windshield. not lol
fink64 is offline
Old 09-03-2012, 08:25 PM   #6044
Chevy Fleetside
I hooked up more acc but couldn't figure out where the oil pressure switch went. I put oil in the engine and tried to fire it for a sec but not spark. I did figure out where the oil pressure switch goes though. And the 2nd picture.. Well it dosent get any better then a good old fashioned bottle of coke while working on the classic Chevy Truck...
Old 09-03-2012, 09:38 PM   #6045
LDO
LDO's Avatar
Nothing to the 66 but cleaned up the TH350 on my wife's 57. New seals and a fresh coat of paint. She was happy...
LDO is offline
Old 09-03-2012, 10:23 PM   #6046
towersddg9
towersddg9's Avatar
Bout got my Dakota Digital VHX done, this thing is sweet has all the goodies of a new vehicle, very thin cat 5 cable to control box, has high speed and rpm recall, hour meter, can alternate speed and temp on LCD display, has a sending unit and wire vs. a spedo cable, I decided to add the GPS to it, sorry bout the glare in the IPhone photo, think I need some contrast in the instrument bezel, but not till I get this thing rolling.....
towersddg9 is offline
Old 09-03-2012, 10:53 PM   #6047
1enick72
1enick72's Avatar
Removed old ECM and started making room for the new PCM. The old one was much smaller and easy to find a spot for. Engine bay is primed painted and ready for the LT1, hope to be going in by the end of the week.
65 short step
edited by staff
1enick72 is offline
Old 09-03-2012, 11:30 PM   #6048
oem4me
Hey, I remember that face from the "why we do what we do" thread ...and Like mine, he's growin" up on ya.
oem4me is offline
Old 09-04-2012, 12:37 AM   #6049
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
I agree,
It looks like it belongs.
Originally Posted by glos55 View Post
Played around with some door art. It's going to be a vinyl magnetic decal
Originally Posted by markeb01 View Post
That really does look perfect on your truck.
66 C20 Service Truck:
LostMy65 is offline
Old 09-04-2012, 08:38 AM   #6050
dean jendro
Old and crusty
dean jendro's Avatar
Picture perfect weather for the long weekend. Logged about 1000 miles of drives. Turn signal mechanism broke but I swapped it out for a spare I had and was back on the road in an hour.
65 Chevy long wide daily driver - SOLD!
64 Chevy Short Step LS
dean jendro is offline
Closed Thread
