#6076 |
Re: What did you do to your truck today?
Big Rig,
Do you have a build thread? Steven
“Life is and will ever remain an equation incapable of solution, but it contains certain known factors.” - Nikola Tesla Matt. 6:27 "Who of you by worrying can add a single hour to his life?” http://www.67-72chevytrucks.com/vboa...=507266&page=2 |
#6077 |
I Got it BAD!
Went out for a drive. Dang Tailgaters!
Build Thread: http://www.chevyguys.com |
#6078 |
Took off the rear bumper and hitch. Removed exhaust manifolds and drilled out spot welds on replacement junkyard piece.
Steven
#6079 |
![]() Join Date: Sep 2006
My son (who is 9) and I tried bleeding the brakes. The fronts went easy but I am having trouble with the rears.
"A man and his truck, what a beautiful thing" 65 Short Fleetside BBC 65 Long Fleetside 283 3 on the tree for now. my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536 |
#6080 |
Senior Enthusiast
Pulled the front bumper to eliminate the fog light mounting holes and repair some blemishes in the 10 year old paint.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502 |
#6081 |
Painted my new/old front bumper. Can't wait to have one on that's not all twisted up!
#6082 |
Replaced some horribly burnt out bad wiring. Im about to start choppin up the harness in the interior so I can further diagnose where this "leak" is occurring so I can stop the battery from being drained.
#6083 |
r3skyline,
Are you sure there isn't a blown diode in the alternator? I had it happen and it drained the battery every night. Steven
#6084 | |
#6085 |
1966 C10 short stepper KMHK ![]() |
#6086 | |
Senior Enthusiast
Today I filled the fog light holes in mine and finished up with epoxy primer. Hopefully I'll get it sanded and painted tomorrow.
plainred65 your bumper turned out beautifully! Quote:
#6087 |
rewired all the guages that the PO installed, damm talk about a hack there was about 50ft of coiled up wire for 3 guages!
Bryan 1966 ![]() Accuair|Porterbuilt|Bodied|Shaved|Z'd|350 with minor goodies|5 lug|front disc|3.73 rear|CPP power steering/brakes|few more goodies| thanks to C10Clubapparel |
#6088 |
![]() Join Date: Nov 2010
I have the next five days off from work and the National Street Rod Show is Fri/Sat and Sun. They are allowing cars and trucks up to 1982 now!!! the cutoff year used to be 1948. This years show should be huge!
#6089 |
Having all new exhaust installed tomorrow morning.
#6090 |
Well getting there, too many things going on to get anything done...anyways tank area is done, setting up for rear sway bar install, I`ve looked at many threads, pics and webs devoted to sway bars....so it looks as if this install will be good to go, here`s a few pics with it tied into place.... final adjustment of end links will happen after I reinstall bed at ride height, I will also be changing rear springs to the Heavy Duty 4 inch drop springs from CPP. By the way anybody running CPP 4inch drop Heavy Duty rear springs..?
`64 C10 vortec 350/350/373 posi `69 RS/SS 350/350/308 `37 Ford 406/350/324 traclock `68 Dart 370/904/323 suregrip |
#6091 |
Took my 65 back to the muffler shop and had a pair of All Star exhaust manifolds put on. What a difference from the "rams horns"... Moose is the man. Great job again. Thank you...
#6092 |
Nice
1965 c-10 swb 1997 c-1500 extended cab 2004 tahoe 1993 mustang gt BUILD THREAD:http://67-72chevytrucks.com/vboard/s...d.php?t=336653 |
#6093 | |
#6094 |
Honestly, I took mine apart on a hunch and found it.
There should be an alternator/starter shop you can take it to. You could also go buy a new one, try it and see if it works. If not, take it back. If so, problem solved! Steven
#6095 |
Rich,
What gas tank is that? Steven
#6096 |
Senior Enthusiast
Beautiful engine compartment, and I love those exhaust manifolds.
#6097 |
![]() Join Date: Dec 2010
got the bugs out, panels and hood are done just need a paint booth
#6098 |
Wow the truck is really lookin good, the shifter looks a long ways away though, do you have long arms.
#6099 |
was installing headers than the bolt snapped flush with the block ashamed to admit but i used bailing wire and rtv to keep it from leaking for now then i rubbed her headlights so they wernt blemished
#6100 |
Sand blasted the back half today. Got black slag everywhere...wife is not impressed!
1965 Chevy Short Box Stepside, 230 - 3 speed, 4:11 gears, original paint rust free survivor. Now sporting a 383 SBC and TKO-600 |
