#6101 |
Senior Enthusiast
Re: What did you do to your truck today?
Painted the front bumper which will go back on tomorrow. The bumper guards still need to be painted, but that's okay since they can't be added until after the bumper is back on the truck anyway. They end up very close to the Buick grille bar and if they were mounted to the bumper first, it's very likely the grille would get clobbered in the process.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502 |
#6102 |
started welding passenger door bottoms on.
#6103 |
`49 to 52 chevy pass, you can get them at
http://www.tanksinc.com/index.cfm/pa...rod/prd249.htm or http://www.bobdrake.com/ItemForm.aspx?Item=C4952-9200 slight differances in the filler neck design and tbe size, frame mods needed for both tanks.
`64 C10 vortec 350/350/373 posi `69 RS/SS 350/350/308 `37 Ford 406/350/324 traclock `68 Dart 370/904/323 suregrip |
#6104 |
Thanks!
Steven
“Life is and will ever remain an equation incapable of solution, but it contains certain known factors.” - Nikola Tesla Matt. 6:27 "Who of you by worrying can add a single hour to his life?” http://www.67-72chevytrucks.com/vboa...=507266&page=2 |
#6105 |
I picked up the steel plate and tubing for making custom exhaust brackets today. $10.
Steven
#6106 |
Senior Enthusiast
Mounted the front bumper with the help of my squeeze, then sanded/painted the bumper guards which will go back on tomorrow:
#6107 |
Painted one vent. Glad I already have the seals, they crumpled in my hands coming out.
![]() Posted via Mobile Device |
#6108 | |
Old and crusty
![]() Join Date: Jan 2009
Dean
65 Chevy long wide daily driver - SOLD! 64 Chevy Short Step LS |
#6109 |
First post on this forum. Just bought a 62. Went to having title issues so right now I am just sitting in it making vroom vrooom noises hoping to get them resolved soon!
#6110 | |
Senior Enthusiast
#6111 | |
Timmy D. "What that grinding noise?Don't worry about that it will eventually clearance itself!" 1966 chevy c10 Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=485977 1954 ford customline H.A.M.B 54 Build Thread:http://www.jalopyjournal.com/forum/s...d.php?t=622142 |
#6112 |
Old and crusty
Thanks Mark. Mine have two square holes and the remains of spring loaded captive nuts in one hole on each guard. I bought them used and they look old and original, but who knows for sure. Maybe the 60-62 used weld nuts and the later ones used removable nuts? The guards are at chrome along with my bumpers so this should dress up the front of my 65 pretty nice.
#6113 |
Picked up all new poly bushings for the rear suspension(autozone) and ordered a coil spring retainer kit from eckler's.
cleaned out all the parts stored in the cab and put them in labelled boxes. Finished removing the door post and cowl bubble from the salvage yard panel. Also, sat on the bare cab floor and acted like I was holding a steering wheel and made several vroom sounds before my son stopped me from looking like an idiot. ![]() Steven
#6114 |
Had some custom stainless exhaust installed in my 64 GMC.
Hooker headers, 2-1/2" S/S exhaust with "H" pipe, Flowmaster 70 series mufflers with tailpipes exiting in front of the rear tires. Looks and sounds fantastic, a nice throaty rumble without being too loud. |
#6115 |
Senior Enthusiast
Welcome to the forum. Hope the paperwork works out soon. Posts some pics when you can, everybody here loves photos.
#6116 |
Paint scheme is awesome, got more photos somewhere?
#6117 | |
was referring to your truck! |
#6118 |
Picked up the flatbed surround C channels my buddy fabbed up (didn't pay a dime for them).
They look great! 12 guage 5"x1.5". Four 8 foot pieces. Need to pie cut at the corners, bend and weld the surround together. I am so stoked! Also, did some more wire wheeling on the frame. With a little luck, The frame, rear axle housing and trailing arms will be painted this weekend. Steven
#6119 |
Got one trailing arm, track arm. both motor mount saddles and the clutch arm painted last night. installed bushings in trailing arm today.
Photos to follow... Steven
#6120 |
Unfortunately, my water heater burst so I spent most of the day cleaning up the mess and installing a new one.
But, I did get all of the suspension parts updated except the coils and installed the bushings. Here are a couple of pics: ![]() ![]() ![]() I really like the hammered look. Next up, painting the springs, rear frame half and rear end. Steven
#6121 |
Worked on the new wooden dash board/bezel and put the gauges back in, put in one of the new tail lights I just purchased to see how it looks... more to come.
http://67-72chevytrucks.com/vboard/s...d.php?t=538792 |
#6122 |
Well... I didn't make as much progress as I wanted to but I still got some things finished. I spent more time going back and forth to the parts house than anything else... O well, that's building cars/trucks I guess.
Anyway, I wire wheeled the whole crossmember, flattened the upper control arms and painted everything. I also replaced all the wheel bearings and seals, greased up all the grease points, put new rotors, calipers, and brake pads on. I also mounted the front bags and started on the rear brakes last night but I had a hard time finding the rear bearing seals and had to order them. They should be in tomorrow and I also dropped off the rear axles last Thursday to get drilled for 5 lug. Hopefully this week I can get the rear bags mounted and finish up the rear end and the rear brakes. If I can get all the finished I will be pretty happy because then I can load it up and take it over to my old mans house to start the body work and hopefully get it painted before it gets too cold outside. I also have to drop some parts off tonight to get blasted "hopefully it doesn't cost me a million bucks"... ![]() ![]() Last edited by zippeay; 09-17-2012 at 10:48 AM. Reason: forgot the pictures |
#6123 |
More body work.. I guess what they say is true.. You are finished with body work when you decide to stop working and put down some paint..
My Build CAPRICKUP 1964 Chevy SWB on a 94 Caprice http://67-72chevytrucks.com/vboard/s...d.php?t=492640 |
#6124 |
E911manager,
I agree. You can work yourself to death on it. I keep finding things I think need to be patched on my cab. Eventually, I will have to put down the sharpie and pick up the welder and get it done. ![]() Steven
#6125 |
Installed my offy intake, headers and carbs Saturday.
